偶氮染料在NanoChrom BP-5MS上的分离与检测 Column: NanoChrom BP-5MS Dimension: 30mx0.25mmx0.25um Carrier: Hydrogen, constant flow 1.5ml/min Inlet: Split, 275℃, split ratio 60:150°C (hold 0.5 min.) to 150°C (hold 8 min) at 20°C/min to 230°C (hold 20 Oven:min ) at 20°C/min to 260 °C (hold 5 min ) Inject volume::偶氮染料1ul Detector: FID 325℃ Peak Compound Chinese Name Elution Time Resolution 1 1,4-benzendiamine 苯胺 4.243 2 2.4.5-Trimethylaniline 1,4-苯二胺 4.989 3 2.4-Toluylenediamine 邻甲苯胺 5.704 4 2.4-Diaminoanisole 2.4-二甲基苯胺 5.715 0.86 5 2.4-Xylidine 2.6-二甲基苯胺 5.767 3.61 6 2.6-Xylidine 邻氨基苯甲醚/2-甲氧基苯胺 5.994 7 p-Cresidine 对氯苯胺 6.472 8 2-Naphthylamine 2-甲氧基-5-甲基苯胺 6.614 9 4.4'-Methylene-bis-(2-Chloroaniline) 2.4.5-三甲基苯胺 6.814 10 3.3'-Dichlorobenzidine 4-氯邻甲苯胺 6.912 4.95 11 3.3'-Dimethyl-4.4'- diaminobiphenylmethane 2.4-二氨基甲苯 7.896 12 3.3'-Dimethylbenzidine 2.4-二氨基苯甲醚 9.341 13 3.3'-Dimethoxybenzidine 2-萘胺 11.185 14 4.4'-Diaminobiphenylmethane 4-氨基联苯 15.9 15 4.4'-Thiodianiline 4.4'-二氨基二苯醚 19.262 16 4.4'-Oxydianiline 联苯胺 19.356 3.71 17 4-Aminobiphenyl 3.3'-二氯-4.4'-二氨基二苯甲烷 19.451 3.92 18 4-Chloro-o-toluidine 4.4'-二氨基二苯甲烷 21.576 19 p-Chloroaniline 3.3'-二甲基-4.4'-二氨基二苯甲烷 21.934 20 Benzidine 3.3'-二甲基联苯胺 22.776 21 Aniline 4.4'-二氨基二苯硫醚 24.685 22 o-Anisidine/ 2-Methoxyaniline 3.3'-二氯联苯胺 24.796 2.50 23 o-Toluidine 3.3'-二甲氧基联苯胺 25.05 5.52 Column: NanoChrom BP-5MSDimension: 30mx0.25mmx0.25um
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《偶氮染料中组分检测方案 》,该方案主要用于染料中含量分析检测,参考标准《暂无》,《偶氮染料中组分检测方案 》用到的仪器有纳谱分析 BP-5MS气相柱 弱极性毛细管柱。
