26 PAHs在NanoChrom BP-5MS-PAH上的分离与检测 Column: NanoChrom BP-5MS-PAH Dimension: 30mx0.25mmx0.25um Carrier: Hydrogen, column flow 1.2ml/min Inlet: Split, 275 C, Split flow 50ml/min Oven: 100℃ (hold 1min) to 280℃ at 15℃/min to 340℃ (hold 10min) at 5℃/minInject volume: 1ul Detector: FID 350℃ 26 PAHs Peak# Compound Retention time(min) Resolution 1 Naphthalene(萘) 3.87 2 1-Methylnaphthalene(1-甲基萘) 4.61 3 2-Methylnapthalene(2-甲基萘) 4.82 4 Acenaphthylene(乙酰萘) 6.07 5 Acenaphthene (范) 6.23 6 Fluorene(芴) 6.88 7 Phenanthrene(菲) 8.34 8 Anthracene(蒽) 8.38 2.23 9 Fluoranthene(荧蒽) 10.07 10 Pyrene(芘) 10.56 11 Benzo[a]anthracene(苯并[a]蒽) 13.17 12 Chrysene(苯并菲) 13.39 13 Benzo[b]fluoranthene(苯并[b]荧蒽) 16.45 14 Benzo[k]fluoranthene(苯并[k]荧蒽) 16.55 2.65 15 Benzo[j]fluoranthene(苯并[]荧蒽) 16.66 3.03 16 Benzo[a]pyrene(苯并[a]芘) 17.78 17 3-Methylcholanthrene(3-甲基胆蒽) 18.56 18 Dibenzo[a,h]acridine(二苯并[a, h]吖啶) 20.74 19 Dibenzo[a,j]acridine(二苯并[a,j]吖啶) 20.86 2.58 20 Indeno[1,2,3-cd]pyrene(茚并[1,2,3-cd]芘) 21.31 21 Dibenz[a,h]anthracene(二苯千[a, h]蒽) 21.38 1.81 22 Benzo[ghi]perylene(苯并[ghi]花) 22.33 23 7H-Dibenzo[c,g]carbazole(7H-二苯并[c,g]咔唑) 23.25 24 Dibenzo[a,e]pyrene(二苯并[a,e]芘) 26.81 25 Dibenzo[a,i]pyrene(二苯并[a,i]芘) 27.30 26 Dibenzo[a,h]pyrene (二苯并[a, h]芘) 27.60 Peak#CompoundRetention time (min)Resolution1Naphthalene(萘)3.8721-Methylnaphthalene(1-甲基萘)4.6132-Methylnapthalene(2-甲基萘)4.824Acenaphthylene(乙酰萘)6.075Acenaphthene(苊)6.236Fluorene(芴)6.887Phenanthrene(菲)8.348Anthracene(蒽)8.382.239Fluoranthene(荧蒽)10.0710Pyrene(芘)10.5611Benzo[a]anthracene(苯并[a]蒽)13.1712Chrysene(苯并菲)13.3913Benzo[b]fluoranthene(苯并[b]荧蒽)16.4514Benzo[k]fluoranthene(苯并[k]荧蒽)16.552.6515Benzo[j]fluoranthene(苯并[j]荧蒽)16.663.0316Benzo[a]pyrene(苯并[a]芘)17.78173-Methylcholanthrene(3-甲基胆蒽)18.5618Dibenzo[a,h]acridine(二苯并[a,h]吖啶)20.7419Dibenzo[a,j]acridine(二苯并[a,j]吖啶)20.862.5820Indeno[1,2,3-cd]pyrene(茚并[1,2,3-cd]芘)21.3121Dibenz[a,h]anthracene(二苯并[a,h]蒽)21.381.8122Benzo[ghi]perylene(苯并[ghi]苝)22.33237H-Dibenzo[c,g]carbazole(7H-二苯并[c,g]咔唑)23.2524Dibenzo[a,e]pyrene(二苯并[a,e]芘)26.8125Dibenzo[a,i]pyrene(二苯并[a,i]芘)27.3026Dibenzo[a,h]pyrene(二苯并[a,h]芘)27.60
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《泥土,环境,水中26PAHs检测方案 》,该方案主要用于环境水(除海水)中有机物综合指标检测,参考标准《暂无》,《泥土,环境,水中26PAHs检测方案 》用到的仪器有纳谱分析 BP-5MS-PAH气相柱 弱极性毛细管柱。
