EcoTech易科泰生态技术 EcoTech易科泰生态技术易 科泰生态技术有有限 公 司Ecotech Ecological Technology Ltd. 易 科泰生态技术有有限 公 Ecotech Ecological Technology Ltd. 易科泰土壤呼吸与碳通量专题快讯- 欧洲最先进的高通量堆肥/土壤呼吸测量系统助力生态系统生物降解研究 英国开放大学(The Open University,简称OU)是一所公立研究型大学,也是国际知名的远程教育大学。OU大学的环境、地球和生态系统科学学院拥有7套独立的16通道SSI模块式堆肥/土壤呼吸测定系统(相关链接参见 https://www. open. ac.uk/stem/environment-earth-ecosystem- sciences/research/analytical-facilities/ecosystems-laboratories),可处理和分析—-系列环境材料,包括土壤、水、大气气体、植物、堆肥和可生物降解废物等。 Home > Research > Analytical Facilities > Ecosystems Laboratories 该高通量土壤呼吸测定系统允许在特定环境条件下(如处理温度和曝气)在线记录和测定二氧化碳、氧气和甲烷。作为欧洲领先的呼吸测量设施之一,用于研究废物和塑料材料的生物降解性测定(例如:用于机械分拣生物处理 (Mechanical Biological Treatment, MBT)评估的持续4天动态呼吸 (Dynamic respiration over 4 days,DR4)测试,堆肥质量标准PAS100 稳定性测试,用于塑料的 BS14855 生物降解标准等))。 Figure 1 Respirometer photos.Left hand side picture shows the back of a respirometer test rig; with the analysers and flow barsstacked up on the left, the condensers (used to keep the moisture within the vessels) and multiplexers on the right. The top rightphoto shows what a typical test sample would look like inside a vessel. The pipe is this photo is the air inlet that is secured to thebottom of the vessel to produce upwards aeration. The bottom right photo show 15 vessels in one respirometer. Time (Days) Figure 3 Percentage carbon loss of cellulose and PVOH test material.Vertical dashed line signifies 45 days. This time is a requireddata point for determining the validity of the test (>70% after 45 days). 如 Figure3 所示纤维素和 PVOH测试材料的碳损失量。 180天后,纤维素的降解率为100%, PVOH的降解率为7%。结果表明,在模拟工业堆肥条件下,本实验所测试的 PVOH 薄膜材料不能进行生物降解。 Figure 4 Average cumulative COz fluxes from each treatment group with the blank subtracted. A geom_smooth (R) function wasused to plot the graph. This is a smoothed conditional mean representation of the data set. The dashed line represents 90% carbonloss. 如 Figure4 所示在改良接种菌堆肥实验中,实验装置再次使用了 BS EN ISO 14855- 1:2012作为指导,但是使用的不是绿色垃圾,而是新鲜的食物垃圾。人工饲料堆肥由白菜10%、苹果10%、去核苹果0.7%、木屑28%、兔球 25.3%、绿色废弃物26%组成。当建立理想的堆肥条件时,所有的塑料材料开始降解。在所有的塑料处理中,可降解塑料表现出最快的 Ecotech Ecological Technology Ltd. 降解率,在第45天达到了90%的降解率(与纤维素相同)。从实验中可以看出,可降解的塑料具有高度的可生物降解性,其最终降解水平远远超过 100%。 需要说明的是,上述高通量堆肥/土壤生物降解呼吸测定系统由北京易科泰生态技术有限公司提供的 SSI 模块式呼吸代谢技术独家定制,为国内外客户提供欧盟最先进的生物降解全面技术方案。 ( 参考资料 ) ( 1、Aspray T J ,Dimambro M E,Wallace P, et al. Static,dynamic and inoculum augmented respiration b ased t est a ssessment f or determining i n -vessel c o mpost stability[J]. Waste Management,2015,, 42(aug.):3-9. ) ( 2、Ecotoxicological E ffects a nd Biodegradability of Aquapak's PVOH in theManaged and N atural E nvironment E c otoxicological. http://randd. def r a. gov. uk/Document.aspx?Document=14526 DEFRAFINALREPORT171214 WE0113.pdf ) ( 3、 J ose Maria R odrigues d a L uz,Sirlaine Albino Paes,Denise Bazzolli,Marcos Totola.Abiotic and B iotic Degradation o f Oxo-Biodegradable Plastic Bags b y Pleurotus o streatus.PLoS ONE, 2014,9(11):e107438. ) ( 4、Luz J, Paes SA, Ri b eiro K , et al . Degradation of Green Polyethylene by Pleurotus ostreatus[J]. Plos O ne, 2 015, . 1 1 0. ) ( 5、M.F. Guigueno, J. A. Head, R .J. Letcher,N. Karouna-Renier,L. Peters, A. M. . H anas, K. J . Fernie.Early life exposure t o t riphenyl p hosphate: E f fects o n t h yroid function, growth, and resting metabolic r ate of Japanese quail ( C oturnixjaponica) chicks. Environmental Pollution, Volume 253,2019,Pages 8 99-908 ) 6、Pries C H, Angert A, Castanha C , et al. Using respiration quotientsStotrack changing sources of soil respiration seasonally and with experimentalwarming[JJ. Biogeosciences,2020,17(12):3045-3055. 7、什么是可堆肥降解塑料?堆肥降解检测标准有哪些? https://baijiahao.baidu.com/s?id=1690765926491109439&wfr=spider&for=pc Sign in | Contact the OU |Accessibility Search the OU QCourses Postgraduate International Research About News & media Business & apprenticeships北京市海淀区高里掌路号院号楼单元( Tel.: +ttp://www.eco-tech.com.cn Email: sales@eco-tech.com.cn 北京市海淀区高里掌路号院号楼单元( Tel.: +ttp://www.eco-tech.com.cn Email: sales@eco-tech.com.cn 英国开放大学(The Open University,简称OU)是一所公立研究型大学,也是国际知名的远程教育大学。OU大学的环境、地球和生态系统科学学院拥有7套独立的16通道SSI模块式堆肥/土壤呼吸测定系统(相关链接参见https://www.open.ac.uk/stem/environment-earth-ecosystem-sciences/research/analytical-facilities/ecosystems-laboratories), 可处理和分析一系列环境材料,包括土壤、水、大气气体、植物、堆肥和可生物降解废物等。该高通量土壤呼吸测定系统允许在特定环境条件下(如处理温度和曝气)在线记录和测定二氧化碳、氧气和甲烷。作为欧洲领先的呼吸测量设施之一,用于研究废物和塑料材料的生物降解性测定(例如:用于机械分拣生物处理(Mechanical Biological Treatment,MBT)评估的持续4天动态呼吸(Dynamic respiration over 4 days,DR4)测试,堆肥质量标准PAS100稳定性测试,用于塑料的BS14855生物降解标准等)。 180天后,纤维素的降解率为100%,PVOH的降解率为7%。结果表明,在模拟工业堆肥条件下,本实验所测试的PVOH薄膜材料不能进行生物降解。 如Figure4所示在改良接种菌堆肥实验中,实验装置再次使用了BS EN ISO 14855-1:2012作为指导,但是使用的不是绿色垃圾,而是新鲜的食物垃圾。人工饲料堆肥由白菜10%、苹果10%、去核苹果0.7%、木屑28%、兔球25.3%、绿色废弃物26%组成。当建立理想的堆肥条件时,所有的塑料材料开始降解。在所有的塑料处理中,可降解塑料表现出最快的降解率,在第45天达到了90%的降解率(与纤维素相同)。从实验中可以看出,可降解的塑料具有高度的可生物降解性,其最终降解水平远远超过100%。需要说明的是,上述高通量堆肥/土壤生物降解呼吸测定系统由北京易科泰生态技术有限公司提供的SSI模块式呼吸代谢技术独家定制,为国内外客户提供欧盟最先进的生物降解全面技术方案。 参考资料1.Aspray T J,Dimambro M E,Wallace P, et al. Static,dynamic and inoculum augmented respiration based test assessment for determining in-vessel compost stability[J]. Waste Management,2015, 42(aug.):3-9.2.Ecotoxicological Effects and Biodegradability of Aquapak's PVOH in the Managed and Natural Environment Ecotoxicological. http://randd.defra.gov.uk/Document.aspx?Document=14526_DEFRAFINALREPORT171214WE0113.pdf3.José Maria Rodrigues da Luz,Sirlaine Albino Paes,Denise Bazzolli,Marcos Totola.Abiotic and Biotic Degradation of Oxo-Biodegradable Plastic Bags by Pleurotus ostreatus.PLoS ONE,2014,9(11):e107438.4.Luz J , Paes S A , Ribeiro K , et al. Degradation of Green Polyethylene by Pleurotus ostreatus[J]. Plos One, 2015, 10.5.M.F.Guigueno,J.A.Head, R.J. Letcher,N.Karouna-Renier,L.Peters,A.M. Hanas, K.J. Fernie.Early life exposure to triphenyl phosphate: Effects on thyroid function, growth, and resting metabolic rate of Japanese quail (Coturnix japonica) chicks. Environmental Pollution, Volume 253,2019,Pages 899-908.6.Pries C H , Angert A , Castanha C , et al. Using respiration quotients to track changing sources of soil respiration seasonally and with experimental warming[J]. Biogeosciences, 2020, 17(12):3045-3055. 7.什么是可堆肥降解塑料?堆肥降解检测标准有哪些?https://baijiahao.baidu.com/s?id=1690765926491109439&wfr=spider&for=pc
关闭还剩1页未读,是否继续阅读?
北京易科泰生态技术有限公司为您提供《土壤中碳通量检测方案(土壤碳通量)》,该方案主要用于土壤中其他检测,参考标准《暂无》,《土壤中碳通量检测方案(土壤碳通量)》用到的仪器有土壤碳通量自动监测站、W.E.T土壤水分、温度、电导率测量仪、Hood IL-2700 自动采集土壤入渗仪、SC-900土壤紧实度仪。
