2021年12月第42卷第23期食品研究与开发应用技术 DOI:10.12161/j.issn.1005-6521.2021.23.016 茶多酚处理对玫瑰香葡萄保鲜效果的研究 石飞,李洋洋,王君 (山西农业大学食品科学与工程学院,山西晋中030801) 摘 要:采用不同浓度的茶多酚对新鲜的玫瑰香葡萄葡行喷涂处理,(20+1)℃放置,每隔2d测定其硬度、腐烂率、失重率、可滴定酸含量、维生素C(Vc)含量、可溶性固形物含量等品质指标,研究其对玫瑰香葡萄货架品质的影响。结果表明:一定浓度的茶多酚溶液处理可以降低果实腐烂率、失重率,延缓可溶性固形物含量、硬度值、可滴定酸以及维生素C含量的降低,浓度为1.5%和2.0%茶多酚溶液处理组可较好地保持葡萄果实的品质。 关键词:茶多酚;喷涂处理;玫瑰香葡萄;常温货架期;品质 Effects of Tea Polyphenol Treatment on Storage Quality of Muscat Grape SHI Fei, LI Yang-yang, WANG Jun (College of Food Science and Engineering, Shanxi Agricultural University, Jinzhong 030801, Shanxi, China) Abstract:Newly picked Muscat grapes were sprayed with different concentrations of tea polyphenols and storedat room temperature (20+1) ℃. The hardness, decay rate, weight loss rate, titratable acid content, vitamin C(Vc) content and soluble solids content were measured every two days, the effect of tea polyphenol on the Mus-cat grape in the shelf life was studied. The results showed that the fruit decay rate and weight loss rate decreasedafter being with a certain concentration of tea polyphenol solution, the hardness, the content of soluble solids,titratable acid and Vc increased, and the 1.5% and 2.0% tea polyphenol treatment had a better effect on main-taining fruit quality. Key words: tea polyphenol; spraying treatment; Muscat grapes; room temperature shelf life; quality 引文格式: 石飞,李洋洋,王君.茶多酚处理对玫瑰香葡萄保鲜效果的研究[J].食品研究与开发,2021,42(23):102-106. SHI Fei, LI Yangyang, WANG Jun. Effects of Tea Polyphenol Treatment on Storage Quality of Muscat Grape[J]. Food Researchand Development,2021,42(23):102-106. 玫瑰香葡萄,欧亚种,是世界上著名的鲜食和酿酒兼用葡萄,成熟时果皮紫中带黑,颜色诱人,且有浓郁的玫瑰香味,含糖量较高,但甜而不腻,深受消费者的喜爱11-2。玫瑰香葡萄中含有很多人体必需的营养成分,如萜类化合物、糖类化合物、多酚化合物、微量元素以及大量的维生素,食用有助于保持人体活力,增强体质,但其易变软、腐烂、掉粒,因此不能长时间贮藏保存,每年中秋节前后是玫瑰香葡萄的成熟时期,市场销售期很短。如何延长其市场销售期,保持其贮藏保鲜品质是目前急需解决的关键问题。目前,保持葡萄果实品质的贮藏保鲜方法较多,如辐射保鲜、气调保鲜、热激保鲜、低温高湿保鲜、化学保鲜剂保鲜、微生物 保鲜等。葡萄保鲜剂种类也有很多,如常用二氧化硫类防腐杀菌剂、乙醛类、CT型葡萄专用保鲜剂、JG葡蔔保鲜剂等,直接使用保鲜剂处理是最常用的保鲜方法,但化学保鲜剂的使用对人体的健康有潜在的危害,近年来天然保鲜剂受到研究者的密切关注,主要有壳聚糖、蜂胶、茶多酚等3-5。 茶多酚是从茶叶中提取得到的多酚类物质的总称,具有很好的抗氧化作用和抑制微生物生长的作用,作为一种新型的天然食品抗氧化剂广泛用于食品工业以及保健品工业16-8。近年来,茶多酚因具有抑菌、抗氧化、护色等功能而作为一种新型保鲜剂应用于水果的贮藏保鲜。研究表明,茶多酚与壳聚糖复配剂能 ( 基金项目:山西农业大学科技创新基金(2018YJ01);山西省青年自然科学基金(201901D211379) ) ( 作者简介:石飞(1988一),女(汉),讲师,博士研究生,研究方向:农产品贮藏与加工。 ) 有效抑制微生物的生长,从而有效延缓水果的衰老和腐败,延长果品的保鲜时间,如草莓、葡萄、樱桃、圣女果等9-12。但与壳聚糖形成复配剂涂膜处理仍存在一些问题,比如膜的强度、韧性不够,易断裂破碎,涂膜不均等。茶多酚易溶于温水,稳定性极强,因此将茶多酚溶于水直接喷洒于水果果实表面,也可以达到很好的保鲜效果[13-17。因此,本文以玫瑰香葡萄为试验材料,研究经不同浓度的茶多酚溶液喷洒处理后葡萄果实常温(20+1)℃货架期间品质和生理指标的变化,探讨茶多酚溶液喷洒处理对葡萄果实的保鲜效果,为其在果品采后贮藏保鲜中的应用提供理论依据。 1 材料与方法 1.1 材料与仪器 玫瑰香葡萄:采自本地葡萄园,采收后立即装入塑料筐,当天运回实验室进行相关处理,易除腐烂果、破裂果、机械损伤果,挑选果粒完好、大小一致、色泽均匀、成熟度相似的葡萄果实为试验材料;茶多酚(食品级):上海瑞祥生物科技有限公司;草酸:天津市申泰化学试剂有限公司;2,6-二氯酚靛酚:北京华越洋生物科技有限公司。以上试剂均为分析纯。 JM—B10002 电子分析天平:赛多利斯科学仪器(北京)有限公司;TMS-PRO 型质构仪:美国FTC公司;LB32T型手持糖度计:河北慧采科技有限公司。 1.2 试验方法 1.2.1 茶多酚溶液的制备及喷洒处理 茶多酚溶液有一定的茶叶苦味,因此配制茶多酚溶液时浓度不宜过高,以免果实表面会有茶叶的苦味残留。设定茶多酚溶液的浓度为 0.5%、1.0%、1.5%和2.0%进行试验,以不加茶多酚的蒸馏水溶液为对照组(CK)。 将挑选好的玫瑰香葡萄均匀分为5组,第1组用蒸馏水喷洒于葡萄表面,第2、3、4、5组分别用配制好的0.5%、1.0%、1.5%和2.0%的茶多酚溶液喷洒于葡萄表面,并保证葡萄表面均覆盖液体,置于实验室阴凉通风处晾干后放于聚乙烯保鲜袋中并封口,每个保鲜袋扎相同数量的小孔,于室温(20±2)℃下放置,每隔2d取样1次测定其各项指标。 1.2.2 指标测定方法 1.2.2.1 失重率的测定 采用称重法测定玫瑰香葡萄的失重率",计算公式如下。 式中:W为玫瑰香葡萄的原始质量(第1次为处 理前样品质量,第2次及以后为上一次放置时的样品质量),g;W2为取样当天样品质量,g。 1.2.2.2 腐烂率的测定 采用计数法测定腐烂率率,计算公式如下。 式中:M为每次取样果实总粒数;Mz为每次取样中腐烂果实的总粒数。 1.2.2.3 果实硬度的测定 采用质构仪测定果实硬度。探头为针形;测试条件:力量感应元量程100N,起始力0.4N,检测速率为60 mm/min,则测后速率为200 mm/min,挤压距离 6 mm。每组中随机取3个果粒完好、没有腐烂的葡萄果实,利用质构仪测量其硬度,求得其平均值即为该处理组的硬度值,单位为N。 1.2.2.4 果实中可滴定酸含量的测定 采用酸碱中和滴定法测定可滴定酸含量。用氢氧化钠标准溶液滴定玫瑰香葡萄提取液,向其中滴加1滴~2滴酚酞指示剂,通过计算消耗的氢氧化钠体积得到葡萄提取液中可滴定酸含量,以酒石酸计I。可滴定酸含量的计算公式如下。 式中:c为氢氧化钠溶液的浓度,0.01 mol/L;V为消耗的氢氧化钠体积,mL;V为玫瑰香葡萄汁的总体积,mL;V样为滴定时所取玫瑰香葡萄汁上清液的体积,mL;m 为玫瑰香葡萄质量,g。 1.2.2.5 果实中可溶性固形物含量测定 采用手持糖度计测定可溶性固形物含量。每组中随机取6颗葡萄果实放入研钵中,磨碎后4500 r/min离心 5 min,取上清液进行测定8。 1.2.2.6 果实中Vc含量的测定 采用2,6-二氯酚靛酚滴定法测定 Vc含量。取10.0g葡萄果实,放入研钵中,加少量草酸溶液(20 g/L)研磨成匀浆后转移至100 mL容量瓶中,并用草酸溶液定容至100 mL,过滤后取 10 mL 滤液用2,6-二氯酚靛酚溶液滴定,根据消耗的2,6-二氯酚靛酚溶液体积计算葡萄果实中Vc含量。 式中:V为滴定时消耗的2,6-二氯酚靛酚溶液体积,mL;T为2,6-二氯靛酚的滴定度,即1毫升此液所相当于还原型抗坏血酸的毫克数,0.1 mg/mL;m 为测定时样液中样品质量,mg;取用倍数为样品定容体积与测定体积之比。 1.3 数据统计分析 各组试验每次测试取3个平行样,3次重复试验。 采用 SPSS 19.0软件进行数据处理分析,利用 Origin8.0 软件进行作图。 2 结果与分析 2.1 不同浓度的茶多酚溶液处理对玫瑰香葡萄失重率的影响 葡萄果实采摘后进行蒸腾作用消耗大量的水分及营养物质,从而造成失重现象的发生,这在一定程度上影响葡萄的经济价值。不同浓度茶多酚溶液对玫瑰香葡萄失重率的影响见图1. 图1 不同浓度茶多酚溶液对玫瑰香葡萄失重率的影响 Fig.1.1Effect of different concentrations tea polyphenol on weightloss rate ofmuscat grape 如图1所示,常温货架时间越长各组葡萄果实的失重率越高。在前4d,各组葡萄果实的失重率没有明显的差异,但在第6天之后4个处理组明显低于对照组。在整个常温货架期过程中,2.0%处理组失重率最低,其次为1.5%茶多酚处理组,而1.0%茶多酚处理组失重率高于0.5%处理组。由此可知,茶多酚溶液喷洒处理可延缓葡萄果实在常温货架中水分的损失,保持葡萄果实的品质。 2.2 不同浓度的茶多酚溶液处理对玫瑰香葡萄腐烂率的影响 鲜食葡萄在贮存过程中受到病原菌以及致腐因子的侵染会发生腐败现象,从而影响葡萄的商业价值。腐烂率是衡量葡萄贮藏保鲜效果的一个重要指标,不同浓度茶多酚溶液对玫瑰香葡萄腐烂率的影响见图2。 由图2可知,在葡萄果实常温货架期各组果实的腐烂率呈现逐渐上升的趋势,并且未经茶多酚处理的对照组腐烂率增加速度最快。前6d,对照组的腐烂率与各处理组无显著差异,且2.0%处理组腐烂率最低。在第8天至第12天,0.5%处理组与1.0%处理组无明显差异,均低于对照组,高于1.5%和2.0%处理组,2.0%处理组腐烂率最低,明显低于对照组。综上,不同浓度的茶多酚溶液处理可以有效减少葡萄果实的腐 图2 不同浓度茶多酚溶液对玫瑰香葡萄腐烂率的影响 Fig.2Effect of different concentrations tea polyphenol on decayrate of muscat grape 烂,且浓度为2.0%的茶多酚处理效果最好。 2.3 不同浓度的茶多酚溶液处理对玫瑰香葡萄果实硬度的影响 不同浓度茶多酚溶液对玫瑰香葡萄硬度的影响见图3. 图3 不同浓度茶多酚溶液对玫瑰香葡萄硬度的影响 Fig.3 Effect of different concentrations tea polyphenol on hardnessof muscat grape 果实硬度直观体现了葡萄果实质量的变化。由图3可知在常温货架期,各组葡萄果实硬度呈现下降的趋势,浓度为 0.5%处理组葡萄果实的硬度值最低,1.5%和2.0%的处理组果实硬度值最高,1.0%的处理组的果实硬度高于对照组。在第12天时,1.5%和2.0%的处理组硬度为 4.78 N,而0.5%的处理组和对照组硬度降到了 4.42N。结果表明喷洒高于0.5%浓度的茶多酚溶液可以减小葡萄果实贮藏期间硬度的降低程度,浓度为1.5%和2.0%的茶多酚溶液处理可较好地延缓葡萄果实的硬度下降,且无显著差异。 2.4 不同浓度的茶多酚溶液处理对玫瑰香葡萄可滴定酸含量的影响 不同浓度茶多酚溶液对玫瑰香葡萄可滴定酸含量的影响见图 4。 可滴定酸含量是葡萄中影响果实风味和品质的 图4 不同浓度茶多酚溶液对玫瑰香葡萄可滴定酸含量的影响 Fig.4 Effect of different concentrations tea polyphenol ontitratable acid content of muscat grape 重要成分之一。如图4所示,在整个货架期间,对照组和不同浓度的茶多酚溶液处理组的葡萄果实的可滴定酸含量呈现出下降的趋势。在前6d,茶多酚溶液处理组果实的可滴定酸含量均低于对照组,仅在第6天时1.5%的处理组略高于对照组,可滴定酸含量为0.48%。在第8至第10天,1.0%处理组果实中可滴定酸的含量最高,第12天时,对照组的可滴定酸含量最低为 0.32%,2.0%茶多酚溶液处理组果实中可滴定酸含量最高,为0.36%。从整个货架期来看,1.0%和 2.0%茶多酚溶液喷洒处理可抑制葡萄果实中可滴定酸降解,较好地保持葡萄果实的风味。 2.5 不同浓度的茶多酚溶液处理对玫瑰香葡萄可溶性固形物含量的影响 不同浓度茶多酚溶液对玫瑰香葡萄可溶性固形物含量的影响见图5。 图5 不同浓度茶多酚溶液对玫瑰香葡萄可溶性固形物含量的影响 Fig.5 Effect of different concentrations tea polyphenol on solublesolids content of muscat grape 可溶性固形物含量是影响果实口感和品质的主要指标之一。由图5可知,葡萄果实在常温货架期间,可溶性固形物含量整体呈现出先升高后降低的趋势。整体来看对照组果实的可溶性固形物含量最低,在第12天时对照组可溶性固形物含量最低,为13.8%,茶 多酚浓度为1.5%和2.0%处理组葡萄果实中可溶性固形物含量均较高,明显高于对照组果实中可溶性固形物含量。1.0%的茶多酚溶液处理组果实中可溶性固形物含量低于 1.5%和2.0%的处理组果实,高于0.5%的处理组果实。这些结果表明,不同浓度的茶多酚溶液喷洒处理减少了葡萄果实中糖类的消耗,维持了果实良好的口感品质。 2.6 不同浓度的茶多酚溶液处理对玫瑰香葡萄Vc含量的影响 不同浓度茶多酚溶液对玫瑰香葡萄Vc含量的影响见图6。 图6不同浓度茶多酚溶液对玫瑰香葡萄Vc含量的影响 Fig.66Effect of different concentrations tea polyphenol on Vecontent of muscat grape 贮藏过程中果实自身氧化及受温度氧气等环境因素的影响,果实维生素含量会逐渐降低,而果实中的Vc含量是体现水果品质的重要指标之一。由图6可知,在货架期间葡萄果实的Vc含量总体上呈现下降的趋势,采摘后葡萄果实的Vc初始含量为 0.86 mg/100 g,在整个货架期对照组果实中的Vc含量最低,不同浓度的茶多酚溶液处理后葡萄果实中的Vc含量均有所增加。在第6天时,浓度为1.5%的处理组Vc含量为0.68mg/100 g,明显高于对照组果实;在第8天时,浓度为2.0%的处理组Vc含量最高,明显高于对照组,与1.5%处理组无明显差异。在第12天,2.0%处理组维生素C含量最高,为 0.37 mg/100 g,其次为1.5%处理组(0.36mg/100g)。由此,一定浓度的茶多酚溶液喷洒处理有利于贮藏期葡萄果实营养品质的保持,可以减少贮藏期间Vc的损失,保持其商品价值,且浓度为1.5%和2.0%处理时效果较好。 3 结论 通过对常温货架期玫瑰香葡萄各项理化品质指标的测定得出,一定浓度的茶多酚溶液喷洒处理对保持葡萄果实品质具有良好的保鲜效果,能够有效减少 果实的失重率、腐烂率,保持果实的硬度,同时可以延缓葡萄可滴定酸含量、可溶固形物含量以及Vc含量的降低程度。茶多酚溶液处理浓度为2.0%和1.5%时保鲜效果较低浓度处理组好。综上,低浓度的茶多酚溶液喷洒处理对葡萄果实的保鲜效果不明显,浓度适度增加可实现较好的保鲜效果。 ( 参考文献: ) ( [1]核 杨立鹏,马巧玲,李金红.玫瑰香葡萄贮藏保鲜技术[J].保鲜与 加工 , 2001,1(6):29. YA N G Li p eng, MA Qiaoling, LI J inhong. Sto r age and pre s er v ationtechnology o f r ose grape[J]. Storage and Process, 2001,1(6):29. ) ( [2] 赵猛,冯志宏,王春生.国内外葡萄贮藏保鲜技术及山西省葡萄 产业化贮藏技术进展[].山西果树,2016(2):21-23. ZHAO Meng, F ENG Z h ihong, W ANG Chunsheng. A d vances in grape storage and preservation te c hnology at home and a broad a nd industrialized grape storage technology in Shanxi Province[J]. Shanxi Fruits, 2016(2):21-23. ) ( [3] 田 静,薛美昭,仪慧兰.SO,保鲜剂对玫瑰香葡萄灰霉菌的抑制 作用[J].食品工业科技,2018 , 39(10):298-302. T IAN J i ng, XUE Meizhao, YI H u i lan. Inhibitory ac t ivity of sulfur dioxide preservative on B otrytis c i nerea o f M uscat H a mburg table grapes[J]. Science and Technology of F ood Industry, 2018, 39(10): 298-302. ) ( [4] M ENG X H, TI A N S P. Eff e cts of preharvest appli c ation of antago- nistic yeast combined with chitosan on decay and quality of h arvestedtable grape fruit[J]. Journal of the Sc i ence of F ood and Ag r icult u re, 2009, 8 9(11): 1 838-1842. ) ( [5] 陶诗雨,李忠明,李蓓蓓. 巨 峰葡萄采后贮藏保鲜技术研究进 展[J].食品工业, 2 01 6 , 37(11):240-243. T A O Shiyu, L I Zhongming, L I Beibei. Research progress on posthar- ve s t prese r vation technology o f kyoho grape[J]. The Food Ind u stry, 2016, 3 7(11):240-243. ) ( [6] 周玲.天然抗氧化剂——茶多酚的应用[.中国食品添加剂,2005(4): 96-99.95. ZHOU Li n g. The natural antioxidant-tea polyphenol[J]. China FoodAdditives, 2005(4):96-99,95. ) ( 7 ] 陈丹丹. 茶 多酚抗氧化作用的应用研究进展[J].中药与临床, 201 4 , 5 (3):59-60,64. CHEN Da n dan. The pro g ress of a nti -o x idant ap p lication o f t e apolyphenols[J]. Pharmacy a nd C l inics of Chinese M ateria Medica, 2014, 5 (3):59-60,64. ) ( [8] HUA N G Z A , Y A N LK , ZHA N G Y H, et al. R esearch on a new composite h y drogel i n hibitor o f t e a p o l yphenols mod i fied wit h polypropylene and mixed with halloysite nanotubes[J]. Fuel, 2 0 1 9, 253:527-539. ) ( [9] 邬兆凯.茶多酚对鲜切水果保鲜的影响--以对苹果的作用为例 [J].轻 工 科技,2019, 35 ( 2):17-18,20. WU Z h aokai. Ef f ect of t e a polypheno l s on fr e sh-keeping of fresh cutfruits -- Taking the effe c t on appl e s as an example[J]. L ight Indus- try S c ience and Technology , 2019, 35(2):17-18,20. ) ( [10]冯文婕,阙斐,陈岭, 等 .茶多酚-壳聚糖复合涂膜液对草莓保 鲜效果的研究[J.现代农业科技,2016(22):260-262. FENG W e njie, QUE Fei, CH E N Ling , et al. Study on effects o f coating c o mposite o f t ea p olyphenol - chitosan o n preservation f or strawberry[.Modern Agricultural Science and Technology, 2016(22): 260-262. ) ( [11]曹 婷 ,朱明,丁莎莎, 等 .茶多酚复配剂对新美人指葡萄贮藏品 质的影响[J].江苏农业科学,2016, 44(5):336-339. CAO Ting, Z H U Ming, DIN G S h asha, et al. E ffects o f tea p o lyphe- nols on storage quality of new Meirenzhi grape[J]. Jiangsu A gricul- tural S c iences , 2016, 44(5):336-339. ) ( [12]陶永元,舒康云,张春梅 ,等 .茶多酚与壳聚糖复配溶液对樱桃的保鲜效果研究[J].食品研究与开发,2014, 35(8) : 115-119. T AO Yongyuan, SHU Kangyun, ZH A NG C h un m ei, et a l . Using the tea polyphenol a nd chitosan to preserve c herry a nd t h e s t udy o n their preservation eff e ct[J]. Food Research and D evel o pment, 20 1 4, 35(8):1 1 5-119. ) ( [13]刘开华,张宇航,淑淑婕.含茶多酚的壳聚糖涂膜对圣女果保 鲜效果的影响[J].食品研究与开发,2014, 3 5(2):109-112. LIU K aihua, Z HANG Yuhang, XING Shujie. Stud y on the effe c t of tea polyphenol -incorporated ch i tosan antibacterial fil m s on f resh preservation of cherry tomatoes[J]. Food Research and Development, 2 014, 3 5(2): 1 09-112. ) ( [ 1 4] JU J, LI A O L, Q IAOY, et al. The ef f ec t s of vacuum package com-bined w ith tea polyphe n ols ( V+TP) treatment o n quality enhance-ment o f weever (Micropterus salmoides) stored a t 0 ℃ and 4 ℃ [J ] . L W T-Food Science and Technology, 2018, 9 1: 4 84-490. ) ( [15]王佩华,赵大伟,迟彩霞,等.天然 抗 氧化剂茶多酚在食品贮藏 保鲜中的应用[J].贵州农业科学,2011,39(3):210-213. WA N G Pe i hua, ZH A O Dawei, CHI C aixia, et a l . Application of t e a polyphenols (a natural a n tioxidant) on food st o rage[J]. Guizhou Agri - culturalSc i enc es , 2011, 3 9(3):210-21 3 . ) ( [16]刘开华,叔淑婕.涂膜保鲜剂中添加茶多酚对黄花梨贮藏品质的影响[J.食品与机械,2012,28(1 ) :208-210. LIU K aihua, X I NG Shujie. Effect of t e a polyphenols in preservativecoating on the storage quality of Huanghua p e ar fr u it[J]. Food & Machinery, 2012,28(1) : 208-210. ) ( [17]张宇航,王荣荣,邢淑婕.茶多酚在果蔬贮藏保鲜中的应用研究 进展[J.食品研究与开发,2016,37(11):210-214. ZHANG Y u hang, W A N G Ron g rong, XI N G Shu j ie . R e search progress on application of te a polyphenol in storage and preservation of f resh f ruits and v egetable[J]. F ood Research and De v elopment, 2016,37(11):210-214. ) ( [18]曹建康,姜微波,赵玉梅 . 果蔬采后生 理 生化实验指导[M].北京: 中国轻工业 出 版社,2007:84-87. CA O J i ankang,J I A N G We i bo, ZHAO Y umei. Experimental guid-ance o n postharvest p hysiology and b i ochemistry of f r uits and v e g- etables[ M ]. Beijing: China Light Ind u stry Press, 2007:84-87. ) ( 加工编辑:冯娜 ) 数据 本文以玫瑰香葡萄为试验材料,研究经不同浓度的茶多酚溶液喷洒处理后葡萄果实常温(20+1)℃货架期间品质和生理指标的变化,探讨茶多酚溶液喷洒处理对葡萄果实的保鲜效果,为其在果品采后贮藏保鲜中的应用提供理论依据。果实硬度检测仪器:美国 FTC 公司不同浓度的茶多酚溶液处理对玫瑰香葡萄果实硬度的影响:果实硬度直观体现了葡萄果实质量的变化。 由图3 可知在常温货架期, 各组葡萄果实硬度呈现下降的趋势, 浓度为 0.5%处理组葡萄果实的硬度值最低,1.5%和 2.0%的处理组果实硬度值最高,1.0%的处理组的果实硬度高于对照组。在第 12 天时,1.5%和 2.0%的处理组硬度为 4.78 N,而 0.5%的处理组和对照组硬度降到了 4.42 N。 结果表明喷洒高于 0.5%浓度的茶多酚溶液可以减小葡萄果实贮藏期间硬度的降低程度,浓度为 1.5%和 2.0%的茶多酚溶液处理可较好地延缓葡萄果实的硬度下降,且无显著差异。结 论:通过对常温货架期玫瑰香葡萄各项理化品质指标的测定得出,一定浓度的茶多酚溶液喷洒处理对保持葡萄果实品质具有良好的保鲜效果,能够有效减少果实的失重率、腐烂率,保持果实的硬度,同时可以延缓葡萄可滴定酸含量、可溶固形物含量以及 VC 含量的降低程度。 茶多酚溶液处理浓度为 2.0%和 1.5%时保鲜效果较低浓度处理组好。 综上,低浓度的茶多酚溶液喷洒处理对葡萄果实的保鲜效果不明显,浓度适度增加可实现较好的保鲜效果。文献来源:山西农业大学
关闭还剩3页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《玫瑰香葡萄中保鲜效果研究检测方案(质构分析仪)》,该方案主要用于其他水果制品中理化分析检测,参考标准《暂无》,《玫瑰香葡萄中保鲜效果研究检测方案(质构分析仪)》用到的仪器有FTC-质构仪TMS-PRO。
