中国调味品China Condiment第46卷第10期2021年10月分析检测 基于人工感官、电子舌和 和-t 法研究食品甜香成分对甜味的相互作用规律 张翼鹏,张伟,吴家灿,马宁,王明锋” (云南中烟工业有限责任公司技术中心,昆明 650231) 摘要:甜味是风味的重要味觉指标,不仅受葡萄糖等糖类甜味物质的影响,也受添加的甜香物质的影响。文章对甜香成分与甜味物质间是否存在协同作用进行了研究。采用电子舌技术结合人工感官探究了6种香气物质(苯甲醇、苯乙醇、肉桂醛、香兰素、呋喃酮、y-癸内酯)对葡萄糖溶液甜味的影响效果。运用o-t 图法进行分析,结果表明:单一的葡萄糖水溶液在电子舌上响应值随着浓度变化呈现正相关,即随着浓度增加,甜味值也增加,但是浓度较高时增加趋势趋于平缓;而在6种香料的研究中,发现苯甲醇和苯乙醇的增甜效果最好,肉桂醛和Y-癸内酯的增甜效果则在指定浓度范围内有所提高,香兰素和呋喃酮则对甜味有减弱作用。该研究成果可广泛应用于饮料、烘焙、冰淇淋等领域,为实现“减糖不减味”的目标提供一定的借鉴意义。 关键词:甜味;甜香;电子舌;协同作用;0-t图法 中图分类号:TS207.3 文献标志码:A doi:10.3969/j.issn. 1000-9973.2021.10.030 文章编号:1000-9973(2021)10-0152-08 Study on the Synergistic Effect of Sweet and Aroma Components in Foodon Sweetness Based on Sensory Analysis, Electronic Tongueand o-t Method ZHANG Yi-peng, ZHANG Wei, WU Jia-can, MA Ning,WANG Ming-feng (Technology Center of China Tobacco Yunnan Industrial Co., Ltd., Kunming 650231, China) Abstract: Sweetness is an important taste index of flavor, it is not only affected by sugar sweetsubstances such as glucose, but also affected by added sweet and aroma substances. Whether sweetand aroma components and sweet substances have synergistic effect or not is studied in this paper.The effect of six aroma substances (benzyl alcohol, phenyl alcohol, cinnamaldehyde, vanillin,furanone, y-decalactone) on the sweetness of glucose solution is investigated by using the electronictongue technique combined with artificial senses. The analysis is carried out by o-t diagram method,the results show that the response value of single glucose solution on the electronic tongue ispositively correlated with the concentration, that is with the increase of concentration, the sweetnessvalue also increases, but the increase trend tends to be smooth when the concentration is higher. It isfound that the sweetening effect of benzyl alcohol and phenyl alcohol is the best, the sweetening effectof cinnamaldehyde and y-decalactone is increased in the specified concentration range, vanilline andfuranone have the effect of reducing sweetness.TThe research results can be widely used in beverage, ( 收稿日期:2021-04-20 ) ( 基金项目 : 中国烟草总公司科技项 目 “ 烟气 香 与 味的感官交互作用研究及在 卷烟 调香 中 的应 用 ”(110201802001) ) ( 作者简介:张翼鹏(1986一) , 男,工 程师 , 硕 士,研究方 向: 香精香料开发, ) ( * 通讯作者: 王 明明(1975 一 ) ,男 ,白 族, 研究 员 ,硕 士 , 研 究方向 : 卷烟调香。 ) ( 引文格式: 张 翼鹏.张伟,吴家灿,等.基 于 人工感官、 电 子舌 和 o-r法研究食品甜香成分对甜味的相互作用 规 律[J]. 中 国调味品, 2021,46(1 0 ): 1 5 2 -1 5 9. ) baking, ice cream and other fields, providing a certain reference for the goal of “reducing sugarwithout reducing taste". Key words: sweetness; sweet and aroma; electronic tongue; synergistic effect; o-t diagram method 电子舌作为一种快速检测食品风味的仪器,能够解决人工感官评价中耗时、耗成本的缺点,客观地评价了食品的风味。其原理是电子舌中的味觉传感器阵列部分对待测样品进行响应,将响应值转化为电信号,而电信号会进人到模式识别系统中,通过该系统的处理和转化,会将电信号输出为相对应的味觉结果。电子舌技术发展迅速,传感器的组成阵列由几个增加到数十个,代表着电子鼻技术愈发成熟,检测准确度与灵敏度越来越高。目前电子舌技术已经被运用到黄酒、葡萄酒、橙汁、茶饮料、肉类等食品中,可以用来分析食品中的感官值,建立模型,用来寻找最佳工艺条件或进行样品比对 目前关于甜味的相关研究可以分为三类:一类是关于甜味物质的测定,该方面研究主要是基于色谱法鉴定单一甜味物质及测定其含量,注重的是鉴定种类和测定含量,可以将香气物质与味觉物质之间的相互作用分为3种,即协同作用、掩盖作用和无作用。香气物质与味觉物质混合在一起时,感官属性增强,则它们之间的相互作用称为协同作用;感官属性减弱,则它们之间的相互作用称为掩盖作用;感官属性强度未发生变化,则它们之间的相互作用称为无作用4-51 o-t模型是通过二元混合物的混合感官强度值,研究二元混合物之间的相互作用关系。Laing 等”通过 o-t图法研究得出,当混合物亡小于0.5时,混合物主要在低加成区域。但当当大于0.5时,大部分混合物会出现在折中区域; Cometto 等以感官强度尺度评价16种不同比例的乳酸和甲醛混合物的嗅觉刺激强度,发现两者存在相互叠加作用:Nahon 等在黑加仑饮料中加入甜味剂,结果发现:其对果香有促进作用,对酸香有抑制作用;该方法主要对二元香气物质之间的相互作用进行了研究,并没有涉及到香气物质与甜味成分间的相互作用关系。 近年来,随着生活水平的提高,人们的饮食模式也朝着高脂肪、高热量、高糖膳食摄入的方向发展,更易引发慢性疾病,对健康产生不良影响。目前减少添加糖的摄入日益受到世界范围的关注,很多国家和地区均已将降糖提升到国家强制管控层面。全球政策的引导加快了减糖食品产业的发展和新产品的上市,满足了人们对健康食品的需求,低糖食品正在成为新的趋势。如何科学地打造配方,在保障健康饮食的同时,满足人们挑剔的味蕾,“减糖不减味”成为食品行业面临的共同问题。 运用“多感官融合”的原理,通过增强其他感官感 受以同步增强甜味的感知,是一种“减糖不减味”的有效方式。研究表明,通过在浮制甜品中加入香草香气,实现了在不影响甜味强度的前提下,使蔗糖含量降低30%~40%001。利用香气作为“减糖”工具,其机制可能是利用人们先前对甜味与特定香气组合获得的美好体验,给大脑提供了积极信号,增强了对甜味的感受。 通过多感官融合技术,添加特定的香气成分可以有效增强甜味剂的甜味属性。如肉桂醛具有肉桂香气,使用含有肉桂醛的调味品能够改善卤制品的辛甜风味"。苯乙醇具有玫瑰花花香和甜香,在玫瑰醋类似产品中合理使用苯乙醇,能够增加其玫瑰的清甜特征香气21。添加呋喃酮类化合物能够赋予酱油焦甜香气13-141。该技术可以广泛应用于饮料、烘焙、冰淇淋等领域中,添加特定的香气成分,保持风味的完整性,满足味蕾的需求。 因此,本文通过人工感官评价结合电子舌味觉分析系统和o-t法对甜香物质与甜味之间的相互作用规律进行研究,使香气物质与味觉感官联系起来,旨在更加安全合理地使用这些物质,尽可能地减少甜味剂的添加,符合人们对美好生活的追求11,对安全健康食品的开发具有重要的指导意义。 L 材料与方法 1.1 材料与仪器 葡萄糖、肉桂醛、y-内内酯、香兰素、喃酮、苯乙醇、苯甲醇、乙醇(99.5%)、酒石酸、氯化钾:以上原料均属食品级,均购自上海泰坦科技股份有限公公;超纯水:广州屈臣氏食品饮料有限公司。 1.2 实验方法 1.2.1 溶液配制 不同浓度葡萄糖溶液的配制:在超纯水中加入5%乙醇、0.045g酒石酸、2.24g氯化钾,定容至1L,此溶液作为溶剂。使用该溶剂配制样品,浓度见表1,待检测用。 表1 不同浓度葡萄糖样品 Table 1 The glucose samples with different concentration 序号 1 2 3 4 5 6 7 8 9 葡萄糖(PTT) /(g/kg) 5 10 20 50 60 80 100 150 200 不同浓度单一香料溶液的配制:在超纯水中加人5%乙醇、0.045g酒石酸、2.24g氯化钾,定容至1L,此溶液作为溶剂。使用该溶剂配制不同浓度原料溶液样品,浓度见表2,待检测用。不同浓度单一香料与 50 g/kg 葡萄糖的混合物溶液的配制:在超纯水中加入5%乙醇、0.045g酒石酸、2.24g氯化钾、50.g葡萄糖,定容至1L,此溶液作为溶剂。使用该溶剂配制不同浓度原料溶液样品,香料浓度见表2,待检测用。 表2不同浓度单一香料样品 Table 2 The single aroma material sampleswith different concentration 序号 2 3 4 5 6 7 8 9 苯甲醇(BJC) /(mg/kg) 0.1 0.5 1 5 10 20 30 40 50 苯乙醇(BYC) /(mg/kg) 0.1 0.5 1 5 10 20 30 40 50 Y-癸内酯(GNZ) /(mg/kg) 0.1 0.5 1 5 10 20 30 40 50 肉桂醛(RGQ) /(mg/kg) 0.1 0.5 5 10 20 30 40 50 香兰素(XLS) /(mg/kg) 0.1 0.5 5 10 20 30 40 50 呋喃酮(FNT) /(mg/kg) 0.5 1 5 10 20 50 100 2000 500 1.2.2 电子舌分析 实验中使用的是日本 Insent 公司的 TS-5000Z 型电子舌,其传感器类类有AEl 传感器(检测涩味)、C00 传感器(检测苦味)、GL1传感器(检测甜味)、CTO传感器(检测则味)、AAE传感器(检测鲜味)、CAO传感器(检测酸味). 使用GL1 传感器检测所有样品的甜味值,在检测前需要对电子舌进行稳定性自检,待自检通过后就能进行样品的检测,分别检测不同浓度的葡萄糖溶液、单一香料、葡萄糖和不同浓度单一香料混合物的甜味值,每个样品共测5次,取后3次测定数据的平均值为样品的甜味值。 1.2.3 人工感官评价 人工感官评价人员应符符以下要求:身体健康,嗅觉、味觉正常,具有较高的感官灵敏度;通过专业训练与考核,掌握品评规程及品评方法;不易受个人情绪及外界因素影响,判断评价客观公正;评价人员若出现感冒、疲劳等症状则不宜进行评价,评价前不宜吃刺激性强的食物,也不宜使用带有香气的化妆品,评价过程中不宜吸烟,否则会影响评价的结果。 本实验的感官评价人员共10名(均为上海应用技术大学研究人员,年龄在20~30周岁,男女各5位),所有评价人员都经过长期的训练,无不良嗜好,评价前均无不良症状等。评价实验是在专门的感官评价室进行,装样品的杯子都统一采同一规格的品尝杯,并且随机编号(三位数的编号,如“212”),分批次呈现样品给感官人员,为了避免人员疲劳,每轮次中间休息10~20 min。评价标准以10%的蔗糖水溶液的品尝甜度 为1,对样品进行相应的甜度打分,若无甜度,则为0016。重复3次,结果取平均值。 1.2.4 o-t分析 Pattet 在前人的基础上通过研究二元混合物的混合感官,提出了 o-t强度模型。通过对A,B化合物单独存在时的甜度值与它们混合物的甜度值进行比较来判断A,B之间甜度值的关系和影响。混合物甜度值与单独组分甜度值之和的比值定义为o.计算公式为:o=I/(I+Ig);单独组分甜味值与单独组分甜度值之和的比值定义为tx 或者Tn·计算公式为tx=I/(I+I ),tn=In/(I+In)。其中IAn 是A和B昆合物的整体感知甜度值,I、和I是A和B组分在单独品尝时的甜度值。组分间的5种相互作用关系见图1。若混合物的甜度值大于各组分单独存在时的甜度值之和,即o>1时,表现为超加成或协同作用效果;若混合物的甜度值等于各组分单独存在时的甜度值之和,即o=1时,表现为完全加成效果;若混合物的甜度值小于各组分单独存在时的甜度值之和,即o≤1时,表现为低加成作用效果。低加成作用还分为以下3种情况:①当max(tA·Tg)
还剩6页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《食品甜香成分中相互作用规律检测方案(感官智能分析)》,该方案主要用于其他食品中其他检测,参考标准《暂无》,《食品甜香成分中相互作用规律检测方案(感官智能分析)》用到的仪器有电子舌、日本INSENT味觉分析系统(电子舌)。
