镀铜溶液中游离氰化物的测定 应用资料在稀释后的样品中加入10%的碘化钾后,用0.1mol/L硝酸银溶液滴定法测定游离氰化物浓度。终点是滴定曲线上的最大拐点。根据硝化银溶液的滴定体积计算出游离氰化物的浓度。KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-94025enL-K-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD. Application Memo Determination of Free Cyanide in Copper Plating Solution 1.Overview After adding 10% potassium iodide to the diluted sample, free cyanide concentration ismeasured by titration with 0.1mol/L silver nitrate solution. The endpoint is the maximuminflexion on the titration curve. The free cyanide concentration is calculated from the titrationvolume of the silver nitrate solution. 2. Apparatus Main unitAutomatic potentiometric titrator (preamplifier STD) Electrode Silver electrode pH glass electrode 3. Reagents Titrant 0.1mol/L silver nitrate solution Solvent Pure water Additive 10% potassium iodide 4. Example -Measurement result- Sample Titrated Concentration (mL) (mL) (g/L) 1 10 24.9131 24.42 -Titration curve- Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《镀铜溶液中游离氰化物检测方案(自动电位滴定)》,该方案主要用于其他中含量分析检测,参考标准《暂无》,《镀铜溶液中游离氰化物检测方案(自动电位滴定)》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪。
