电解液中硼酸含量的测定 应用资料电解质溶液中的硼酸含量根据JIS K8863-2007硼酸(试剂)进行定量分析。向样品中加入甘露醇和纯水后,用0.1mol/L氢氧化钠滴定至终点。终点是滴定曲线上的最大拐点。硼酸的浓度是根据滴定体积计算得出的。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIO-94008enL Application Memo Boric Acid in Electrolyte 1.Overview Boric acid in the electrolyte solution i s quantified according to J IS K 8863-2007 Boric acid (Reagent). After mannitol and pure water are added to the sample, it is titrated with 0.1mol/L sodium hydroxide up to the endpoint. The endpoint is the maximum i nflexion point on the titration curve. The concentration of boric acid is calculated from the titration volume. 2. Apparatus Main unit Automatic potentiometric t itrator (preampli f ier STD) Electrode pH glass electrode Ceramic reference electrode 3. Reagents Titrant 0.1 mo1/L sodium hydroxide Solvent Pure water, Mannitol Sample Concentration (mL) (g/L) 1 2.0 43.976 2 2.0 44.658 3 2.0 44.469 Average 44.368 SD 0.352 RSD(%) 0.794 Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《电解液中硼酸含量的测定 应用资料》,该方案主要用于其他中含量分析检测,参考标准《暂无》,《电解液中硼酸含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
