电镀溶液中重铬酸钠含量的测定 应用资料在样品中加入硫酸(1+1)和二苯胺后,用0.2mol/L硫酸亚铁铵滴定溶液滴定,测量电镀溶液中的重铬酸钠(二水合重铬酸钠,Na2Cr2O7)。终点是滴定曲线上的最大拐点。重铬酸钠浓度是根据硫酸亚铁铵的滴定体积计算得出的。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-94014enL Application Memo Sodium Dichromate in Plating Solution 1.Overview Sodium dichromate (sodium dichromate dihydrate, Na2Cr2Or) i n plating solution i s measured by t itration with 0.2mol/L ferrous ammonium sulfate after adding sul f uric acid (1+1) and diphenylamine to the sample. The endpoint is the maximum inflexion on t he t itration curve.The sodium dichromate concentration is calculated from the titration volume of ferrous ammonium sulfate. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode Platinum electrode Ceramic reference electrode 3. Reagents Titrant 0.2mol/L (0.2N) f errous ammonium sulfate Solvent Pure water Additive Sulfuric acid (1+1), 1% diphenylamine Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《电镀溶液中重铬酸钠含量的测定 应用资料》,该方案主要用于其他中化学性质检测,参考标准《暂无》,《电镀溶液中重铬酸钠含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
