检测样品 生物药品原料
检测项目 抗凝剂,PDA检测器,ELSD,黄连素,阿片醇,ursodeoxycholic acid,硬脂酸
药物含有各种活性成分,并且为了同时分析这些成分,需要高灵敏度检测的梯度洗脱方法。当以梯度模式分析药物时,蒸发光散射检测器(ELSD)是有用的,因为它可以以高灵敏度检测除挥发性成分外的几乎任何化合物,并提供稳定的基线。在本报告中,使用ELSD和PDA检测来分析抗胀气中所含的一些成分。硬脂酸被用作片剂的润滑剂,ursodeoxycholic acid 对改善消化和吸收有效,阿片醇被用作消毒剂,黄连素具有抗菌、抗炎和保护胃粘膜的作用。Application Note 2/3Application NoteAnalysis of Anti-flatuents using HPLC-ELSD Analysis of Anti-flatuents using HPLC-ELSD Medicines contain various active i ngredients and for analyz i ng such ingredients simultaneously, a gradient elution method requiring high sensitive detection is required. When analyz i ng medicines in gradient mode an evaporative light scattering d e tector (ELSD) is useful because it can d etect almost any compound with the exception volatile components with high sensitivity and provides a stable baseline. In this report, some ingredients contained in an anti -flatulent were analyzed using ELSD and PDA d e tection. Ste a ric acid is used as a lubricant for forming tablets, ursodeoxycholic acid is effective for improving digestion and absorption, acrinol is used as a disinfectant and berberine has antibacterial.ant i -inflammatory and gastric mucosa l protect i on effects. Keyword : Antiflatuent , C18 col u mn, PDA det e ctor,ELSD, berberine, acrinol , ursodeoxycholic acid,Stearic acid PU-2089 Experimental Equipment: Conditions: P u m p : PU-2089 Autosampler: AS-2057 Column oven: CO-2060 Detector: E L S-2040 Column: CrestPak C18S (4.6 mmlDx150 mmL, 5 pm) Eluent A: 10 mM Ammonium acetate in Acetonitrile Eluent B: 10 mM Ammonium acetate Gradient condition: (A/B), 0 min (5/95) ,15 min (70/30),15.05 min (95/5) 20 min (95/5),20.05 min (5/95) 1 cycle: 35 min Flow rate: 1.0 mL/min Column temp.: 40°℃ ELSD condition: Nebulizer temp.: 30℃ Evaporator temp.; 60℃ Gas flow rate; 1.0 SLM PDA wavelength: 200-650nm Injection volume: 10 pL Standard sample: Stearic acid, Acrinol, Ursodeoxycholic acid, Berberine Figu r e 1 s h ows s tr u c tu ra l f o r m ul a o f t h e in gr e d i e n t s c o n ta i n e d i n t h e a n t i-f latu en t. Fig ure 1. S t ru c tural formula o f t h e i n gr edients c o nta i ned i n an t i -f latue n t. Re sults Figu r e 2 s h ows c h r o ma to g r a m o f t h e sta n da r d m i xt ure w h ile f i g ure 3 sh o w s c h r o m a t o gr a m o f a n t i-f l at u e n t . Th e t op c h r oma to gr a m i s f r om th e EL S D a n d th e bott om ch r oma t o g ram is f r o m th e PD A (a t 220n m ). O n ly two i n g red i e n t s we r e de t e c t e d by t h e P D A, w h i l e a l l fou r i n g r e d ie n t s w e r e c l ea r l y d e t e c ted b y t h e EL SD . Figure 2. Ch romatog r am o f t h e standard mixt u re. 1: S tear i c a c id [0.5 mg/m L],2: A crinol [0.1 m g/mL], 3: B erberine [0.1 m g/m L], 4:Ursodeoxychol i c acid [0.1 mg/mL] F igure 3. C h romatogram of t h e anti -flatuent.1: Stear i c acid, 2: Ac r inol , 3: B e rbe r i n e, 4:U rs o d e oxy chol ic acidPr e p a ration : A 1.0 m g/mL so l u t ion was p rep a red by di ssolv i ng t he powder f r om t he crushed ant i -f l a t uen t i nto m ethanol and sent t h r oug h t he 0.45 p m membrane f i l ter.
关闭还剩1页未读,是否继续阅读?
佳士科商贸有限公司为您提供《HPLC-ELSD法分析抗胀气化合物》,该方案主要用于生物药品原料中抗凝剂,PDA检测器,ELSD,黄连素,阿片醇,ursodeoxycholic acid,硬脂酸检测,参考标准《暂无》,《HPLC-ELSD法分析抗胀气化合物》用到的仪器有JASCO高效色谱仪LC-4000。
