辣椒属果实中含有的刺激性成分(导致“辣”)统称为辣椒类。辣椒中的辣椒素和二氢辣椒素构成了80-90%的辛辣成分;这些化合物目前广泛应用于医药产品和保健食品中。众所周知,辣椒素以不同的量存在于辣椒果实的各个部位。本实验测定了四种辣椒(辣椒、塞拉诺辣椒、芬格辣椒和哈瓦那辣椒)果皮、种子和胎盘中的类辣椒素含量。表1.辣椒各部位的辣椒素和二氢辣椒素含量Application Note742025H 2/4Application Note Analysis of Capsaicin an d D Dil ihydrocapsaicin in Capsicum Introduc t ion The pungent components (which are responsi b le for t h e ‘hotness')conta i ned i n the fru it of the genus Capsicum a r e collectively refe r red to as the Capsaicinoids. Capsaicin and d ih ydrocapsaic i n in Capsicums constitute 80-90% of the pungent components; these compounds are now widely used i n medical products and health foods. It is known that t h e capsaicino i d s a r e presen t i n differ in g amounts i n the various pa r ts of the Capsicum f r uit. In this experimen t the Capsa i c in oid content of t h e pericarp,seed and place n ta from each of four types of capsicum was measured-Capsicum frutescens, Se r rano, F i nger hot and Habanero. LC-4000 Series H PLC Syst em E xper i men t al Equipment Conditions Pump PU-4180-LPG Column CrestPak C18S (4.6 mmlDx150 mmL, 5mm) Column Oven CO-4061 Eluent A 1% Acetic acid/Acetonitrile (50/50) Autosampler AS-4050 Eluent B Acetonitrile Detector MD-4010 Gradient (A/B), 0 min (100/0) --> 15 min (100/0) Condition -->15.05 min (0/100)-->20.00 min (0/100)--> 20.05 min(100/0)1 cycle; 35.5 min Flow Rate 1.0 mL/min Standard Sample Powdered Coptis japonica (0.5 g/50 mL in methanol/10%hydrochloric acid (100/1)) Column Temp 40°C Wavelength 280nm Injection Volume 20mL Standard Sample Capsaicin 10, 50, 100 mg/mL in Methanol Dihydrocapsaicin10, 50, 100 pg/mL in Methanol R esul t The chromatograms of t h e 10 ug/mL each of Capsaicin a n d Dihydrocapsaicin stand a rd sample are shown i n Fig. 1. Good separat i on was obtained within 12 m i nutes. The sam p l i ng p rocedure of the actu a l samples is shown i n Fig . 2. Figure 1. Ch r omatogram of C apsaicin a n d Di hy dr oc ap s a i c in sta n d ard Figure 2. Sa m pl e p r ep ara ti o n The chromatograms for eac h 4 kinds of Caps i cum are shown i n Fig. 3. In T able 1 the Capsa i c i n and Di h ydrocapsa i cin content in the eac h Capsicum sample (wet we i g h t) are shown. I t is known that the contents are ve r y different depending on each p art and for the al l capsicum , Placenta part contai n s Capsaici n and Dihydrocapsaicin the most. JASCO INC. 28600 Mary's Cour t , E a s to n , M D 21601US A T el : (800) 333-5272, Fa x : (410) 822-7526 A ppl ic a tio n Lib r ary: ja s c o i n c.com /appli c a t i o ns 100000 a) 50000 0 0.0 21 40 6.0 80 100 120 140 160 100000 b) 50000c 2 0 一 0.020 4.0 6.0 8N 10.0 12.0 14.0 16.0 100000 c) 50000 2 0 0.02.0 40 6.0 00 10.0 120 14.0 16.0 Reten t ion Ti m e [m i n] 10000 a) 三 5000c a 0 一——一 0.0 U 4.0 6.0 8.0 10.0 12.0 14.0 16.0 10000- b) 5000 0 0.0 2. 4.0 6.0 8.0 10.0 12.0 14.0 16.0 10000 c c) 2 5000 0 0.0 2.0 40 6.0 8.0 10.0 12.0 14.0 16.0 Re t en t ion T ime [mi n] Figure 3. Chromat o gr a ms f o r e a c h o f t h e f our sp e c i es o f C a psic um measured . T ab l e 1 sh o ws t h e Cap sa i c i n a n d Dihy dr o capsa i c i n con ten t f o r e a c h C a ps i c um s a mple (wet weight ). I t i s w e l l know n t ha t t h e a mount of c a ps ai c in o i d s pres e nt is v e r y different d ep e nd i n g on t he pa r t o f t h e capsic um f r u it an d is wid ely d if feren t b et ween s p ecies ; t h e p l ace n ta con ta ins the majori t y of capsaic i n a n d di h ydro c apsaic i n , fol l o w ed b y t h e s eed a n d t he n the p er icar p whic h may con t a i n l i tt le o r no capsa i c i n oi ds . JASCO INC. 28600 Mary's Cour t , E a s to n , M D 21601US A T el : (800) 333-5272, Fa x : (410) 822-7526A ppl ic a tio n Lib r ary: ja s c o i n c.com /appli c a t i o ns Sample Contents in each sample [ug/g] Capsaicin Dihydrocapsaicin Capsicum Frutescens Pericarp 154 120 Seed 713 542 Placenta 9540 7410 Serrano Pericarp 7.64 4.47 Seed 387 229 Placenta 1080 644 Finger Hot Pericarp Not Detected Not Detected Seed 2.89 2.87 Placenta 217 160 Habanero Pericarp 134 43.2 Seed 297 92.5 Placenta 8720 2750
关闭还剩2页未读,是否继续阅读?
佳士科商贸有限公司为您提供《辣椒中辣椒素和二氢辣椒素的高效液相色谱分析》,该方案主要用于保健食品中辣椒素、二氢辣椒素检测,参考标准《暂无》,《辣椒中辣椒素和二氢辣椒素的高效液相色谱分析》用到的仪器有JASCO高效色谱仪LC-4000。
