当前位置: 纺织原料 > 方案详情
蚕丝纤维蛋白改性粘性织物中蚕丝蛋白含量的检测
检测样品 纺织原料
检测项目 蚕丝蛋白
关联设备 共7种 下载方案
方案详情
使用朱蕉叶提取物制备的银纳米粒子赋予蚕丝纤维蛋白改性粘性织物,具有持久的抗菌性能Fabrication of Silver Nanoparticles Using Cordyline fruticosa L. Leave Extract Endowing Silk Fibroin Modified Viscose Fabric with Durable Antibacterial Property
使用朱蕉叶提取物制备的银纳米粒子赋予蚕丝纤维蛋白改性粘性织物,具有持久的抗菌性能Fabrication of Silver Nanoparticles Using Cordyline fruticosa L. Leave Extract Endowing Silk Fibroin Modified Viscose Fabric with Durable Antibacterial Propertypolymers Polymers 2022,14,24092 of 21 Citation: Nguyen,N.-T.; Vo, T.-L.-H.Fabrication of Silver Nanoparticles Using Cor d yline fruticosa L . Leave Extract Endowing Silk Fibroin Modified Viscose Fabric with Durable Antibacterial Property. Polymers 2022,14,2409. https://doi.org/10.3390/polym14122409 Academic Editors: Md. Amdadul Hug and Shahina Akter Received: 11 May 2022 Accepted: 12 June 2022 Published: 14 June 2022 Publisher's Note: MDPI stays neutral with regard to jurisdict i onal claims in published maps and institutiona l af fi l -iations. Copyright: @ 2022 by the authors.L i censee MDPI, Basel, Switzerland.This article is an open access article distr i buted under the terms and conditions of the Creative Commons Attribution (CC BY ) l icense (https://creativecommons.org/licenses/by/4.0/) Department of Textile Material and Chemica l Processing, School of T ext il e-Leather and Fashion,Hanoi University of Science and Technology, 1 Dai Co Viet , Hanoi 11615, Vietnam 2 Department of Fibre and Textile Technology, Hanoi Industria l Text i le Garment University,Hanoi 12411, Vie t nam; huongvtl@hict.edu.vn Correspondence: thang.nguyenngoc@hust .edu.vn; Tel.: +84-904309930 Abstract: The current work presented a green synthetic route for the fabrication of silver nanoparticles obtained from aqueous solutions of silver nitrate using Cordyline fruticosa L. leaf extract (Col) as a reducing and capping agent for t he f irst t i me. The bio-synthesized silver nanoparticles (AgCol)were investigated using UV-visible spectroscopy (UV-vis), t ransmission electron microscopy (TEM),X-ray dif f raction (XRD), Fourier transform infrared spectroscopy (FTIR), and thermal gravimetric analysis (TGA). The obtained data demonstrated that AgCol in spherica l shape with an average size of 28.5 nm were highly crystalline and well capped by phytocompounds f rom the Col extract.Moreover, the bio-synthesized AgCol also exhibited the effective antibacterial ac t ivities against six pathogenic bac t eria, i ncluding Escherichia coli (E . coli), Pseudomonas aeruginosa (P . aeruginosa), Salmonella enterica (S. enterica), Staphylococcus aureus (S. aureus), Bacillus cereus (B. cereus) and Enterococcus faecalis (E. faecalis). The AgCol were applied as an antibacteria l finishing agent for viscose fabric using a pad-dry curing technique. The AgCol-treated viscose fabrics exhibited a good synergistic antimicrobial activity against E. coli and S. aureus bacteria. Furthermore, the silk fibroin regenerated from Bombyx mori cocoon waste was utilized as an ecofriendly binder for the immobilization of AgCol on the viscose fabric. Thus, the antimicrobial efficacy of the AgCol and fibroin modified viscose fabric still reached 99.99% against the tested bacteria, even after 30 washing cycles. The colorimetric property, morphology, elemental composition, and distribution of AgCol on the treated fabrics were invest i gated using several analysis tools, including colorimetry, scanning electron microscopy (SEM),energy-dispersive X-ray spectroscopy (EDX), atomic absorption spectroscopy (AAS), Kjeldahl, and FTIR. Because of the excellent antimicrobial efficiency and laundering durability, as well as the green synthesis method , the AgCol and f ibroin modi f ied viscose fabric could be utilized as an antibacterial material in sportswear and medical texti l e applications Keywords: Cordyline fruticosa L .; silver nanoparticles; antibacterial activity; silk fibroin; viscose fabric 1. Introduction Cellulosic textiles, such as cotton and viscose, play key roles in the daily life of humans due to their excellent properties, including comfortability, water absorptivity, air permeabi l ity, and f lexibil i ty [1-3]. However, this natura l material also provides a favorable medium for the adsorption, survival, and growth of hazardous microorganisms owing to its moisture, oxygen, and nutrient retaining ability [2,4-6]. Infestation by microbes can cause detrimental effects for t he wearer and the t extile manufacturing process, such as the generation of unpleasant odor, health concerns, loss of fabric strength properties,and discoloration [2,6]. To overcome those problems, antibacteria l f inishing of cellulosic texti l e products is often inevitable. In addition, viscose fabric absorbs more sweat than cotton when worn next to the skin, providing a convenient environment for bacterial growth. Therefore, it is necessary to improve the antibacterial properties of viscose fabric in order to make this cellulosic material more attractive and to broaden i ts application fields. One of the utmost i mportant aspects for antibacterial textiles in terms of maintaining hygiene is laundering durability [1,3,17]. Thus, strategies for the immobilization of AgNPs on cellulosic textiles have been a fashion research trend in the modification of textiles. Numerous techniques for this purpose have been developed, including ex situ and in situ fabrication of AgNPs onto the fabric surfaces with the assistance of crosslinking agents or polymer binders [5,22-32]. Among polymer binders, natural polymers, such as chitosan and i ts derivatives, and starch, gelatin, alginate, pectin, guar gum, and rubber are reported to be very effective and ecofriendly for adhering AgNPs onto cellulosic fabric surfaces [5,27-29,31,32].Interestingly, these polymers have great capacity to suffer bounding to the cellulose molecules of cellulosic fabrics even in very small added amounts. Therefore, they enhance the non-leaching of AgNPs during washing cycles. Beyond the above knowledge in mind, the present work proposed a new strategy to impart antibacterial functionality to viscose fabric using bio-synthesized AgNPs and regenerated silk fibroin as an eco-friendly polymer binder. Firstly, a green synthesis of AgNPs from a water-based solution of silver nitrate utilizing Cordyline fruticosa L. leaf extract as a reducing and capping agent was reported for the first time. Cordyline fruticosa L.comprises of more than 480 species distributed mostly in tropical and subtropical regions of the world [33-35]. I t can be found in gardens as an ornamental plant, as its leaves are very conspicuous and attractive. It has been used as a traditiona l medicinal plant for centuries in Vietnam. According to the literature, the major constituents present in the Cordyline fruticosa L. lea f extract are reported to contain anthocyanin, saponin, f lavonoids, f lavonols,chlorophyll, glycoside, etc., which possess strong reducing power [33-39]. The reduction reaction of silver ions was controlled using UV-vis spectroscopy to optimize the synthesis parameters of the AgNPs. The obtained AgNPs were examined using HR-TEM, XRD, FTIR,and TGA analyses. The antibacterial action of the bio-synthesized AgNPs was evaluated against six pathogenic bacteria, including Escherichia coli (E. coli), Pseudomonas aeruginosa (P. aeruginosa), Salmonella enterica (S. enterica), Staphylococcus aureus (S. aureus), Bacillus cereus (B. cereus), and Enterococcus faecalis (E. faecalis). Afterwards, the bio-synthesized AgNPs were applied as an antibacterial finishing agent for viscose fabrics using a pad-dry curing technique. In order to enhance the laundering durability, silk fibroin regenerated from Bombyx mori cocoon waste was used as an ecof r iendly binder for the pre-modification of viscose fabric and subsequent loading of the AgNPs using the pad-dry curing technique,under different treatment conditions. Finally, the antibacterial activity of the functionalized viscose fabrics against both the gram-negative bacteria E. coli and gram-positive S. aureus bacteria were assessed after washing cycles. The mechanism of the modification of viscose fabric was suggested. To the best of our knowledge, the regenerated silk fibroin combined with AgNPs in the antimicrobial finishing of viscose fabric has not yet been reported. 2. Materials and Methods 2.1. Materials Cordyline f ruticosa L. leaves (Col) were collected from a locality of the Hoai Duc district,Hanoi, Vietnam, in October 2019. First of all, the Col leaves were washed with disti l led water, before being dried at 60C for 48 h. The dried leaves were thinly chopped into small pieces (5 ×5 mm) and kept in a sealable plastic bag for further study. Bombyx mori cocoon waste was collected from the village of Vong Nguyet, Bac Ninh province, Vietnam. Plain woven viscose fabric (staple viscose, Ne30/1, 68 ends/cm, 68 picks/cm) was scoured and supplied by the Nam Dinh Textile Garment Co., Ltd.,Nam Dinh, Vietnam. Silver nitrate (AgNO3, 99.99%), sodium carbonate, ethanol, acetic acid, l ithium bromide, and aluminum sulfate octadecahydrate were purchased from the Aladdin Shanghai Biochemical Technol-ogy Co. Ltd.,Shanghai, China. The solvent used in all experiments was double distilled water from an EYELA Still Ace SA-2100E. Six types of bacteria, including Escherichia coli (ATCC 8739), Pseudomonas aeruginosa (ATCC 27853), Salmonella enterica (ATCC 2162), Staphy-lococcus aureus (ATCC 25923), Bacillus cereus (ATCC 11778), and Enterococcus faecalis (ATCC 29212) were obtained from t he Center for Research and Development in Biotechnology HUST, Hanoi, Vietnam. 2.2. Preparation of Cordyline fruticosa L. Leaf Extract Ultrasonic Cleaner centrifuge extract Figure 1. Schematic representation of the Cordyline fruticosa L. leaf extraction by the maceration method and t he phytochemical-mediated synthesis of AgCol from the extract. 2.3. Synthesis of Silver Nanoparticles The silver nanoparticles were prepared by adding 1 mL of aqueous silver nitrate solutions at varying concentrations (6, 10, 14, and 18 mM) to 10 mL of the diluted Col extract (10 mg/L anthocyanin) in Falcon tubes. The reaction mixtures were kept in the dark at 50 °C with different incubation t imes (2, 4, 6 and 8 h). After the passage of t ime, the synthesized nanoparticles were centrifuged at 15,000 rpm for 30 min at 5C. The solution was discarded, and t he obtained pellet was re-dispersed in t he double distilled water using a sonication bath (UT-106H Ultrasonic Cleaner, Japan). This step was repeated two times to remove residual reagents, and the purified nanoparticle solution (AgCol) was stored at 4°C prior to analysis. A schematic i ll ustration of the phytochemical-mediated synthesis of AgCol from Col extrac t was i l lustrated i n Figure 1. 2.4. Dissolution of Silk Fibroin The dissolution of silk f ibroin procedure was reported in our previous work [41]. In a typical experiment, Bombyx mori cocoons were degummed by boiling in an aqueous solution containing 5 g/L NazCO3 at a liquor ratio of 1:20 (mass in gram per volume in mL) for 30 min. The silk fibroin was rinsed several times using warm and cold distilled water, and then neutralized with acetic acid (2 mL/L). The sample was washed again in plenty of distilled water and dried at 60 °C until at a constant weight. After that, 2.8 g degummed silk fibroin was dissolved in a glass f lask containing 10 mL solution of lithium bromide/ethanol/water (LiEtW) with a mass ratio of 45:44:11 at 80 °C for 60 min. The obtained fibroin solution was diluted 15 times with double distilled water to reduce the viscosity. Excess LiBr and ethanol were then removed f rom the f ibroin solution through microfiltration and ultrafiltration systems with hollow-fiber cartridges in the QuixStand Benchtop system (GE Healthcare, Chalfont Saint Gi l es, UK). In the f irst stage of the f iltering process, 0.2 um hollow-fiber cartridge was used to remove impurities and high molecular weight fibroin segments. In the next stage, the fibroin solution was subsequently filtered through a 10,000 NMWC (nominal molecular weight cutoff) hollow fiber ultrafiltration cartridge to get the fibroin segments with molecular weight over 10 kDa retaining inside the filter tube. The solution passed through the ultrafiltration system contained low molecular weight f ibroin segments, excess LiBr, ethanol, and water. The fibroin content in the obtained solution was measured using an infrared moisture analyzer (MA35,Sartorius AG, Gott i ngen, Germany). The scheme of degumming, dissolving, and f iltering silk fibroin was illustrated in Figure 2. Figure 2. Schematic illustration of degumming, dissolving, and filtering silk fibroin 2.5. Modification of Viscose Fabrics with Silk Fibroin and Silver Nanoparticles Silk f ibroin treated viscose fabric (VisFib) was prepared following our previously reported method [41]. Briefly, the viscose fabric samples with size of 35 ×35 cm were padded twice using an Atlas D394A laboratory padder to achieve a wet pickup of 80% with the 2.5% fibroin solutions (Fib > 10 kDa). The fabrics were then dried a t 110 ±3°℃for 2 min using SDL mini-drier 398 l aboratory thermo-fixation. Subsequently, the dried samples were soaked in a 10 g/L aluminum sulfate solution, padded at 80% wet pickup,and cured at 110 ±3 °C for 5 min to regenerate and fix silk f ibroin onto viscose fabrics. The samples were rinsed to remove unfixed and excess reactants and dried again. In the next step, the untreated and treated viscose fabrics were individually immersed in serial AgCol solutions with different concentrations of 80, 40, and 20 ug/mL for 15 min at a liquor-to-fabric ratio of 5:1 (w/w) and squeezed using the Atlas D394A laboratory padder to al l ow various wet pickups of 70%, 80%, and 90%. After that , the padded fabrics were dried at 110 ±3 °C for 2 min using SDL mini-drier 398 laboratory thermo-f ixation.The dipping-padding-drying processes of the fabric samples were repeated two times. The name of AgCo l embedded fabric samples was denoted in Table 1. The process of viscose fabrics treated with silk fibroin and AgCol was depicted in Figure 3. Table 1. The codes of fabric samples with different treatments. Sample Silk Fibroin (%) AgCo (ug/mL) Wet Pickup (%) 70 80 90 Viscose fabric 0 80 VisAg11 VisAg21 VisAg31 0 40 VisAg12 VisAg22 VisAg32 (Vis) 0 20 VisAg13 VisAg23 VisAg33 Fibroin treated viscose fabric 2.5 80 VisFibAg11 VisFibAg21 VisFibAg31 (VisFib) 2.5 40 VisFibAg12 VisFibAg22 VisFibAg32 2.5 20 VisFibAg13 VisFibAg23 VisFibAg33 Figure 3. Scheme of modification of viscose fabrics with silk f ibroin and AgCol. 2.6. Analytical Methods 2.6.1. The Total Anthocyanin Content of the Col Extract The total anthocyanin content (TAC) of the Col extract was measured via the pH differen-tial method using two buffer systems of pH 1.0 (KCl+HCl) and pH 4.5(KHCgH4O4+HCl).T Sr he absorbance of the samples was recorded between 400 and 700 nm in a UV-vis spec-trophotometer (UV-1800, Shimadzu,Japan) at a resolution of 1 nm, in 10 mm optical path length quartz cuvettes. The TAC (mg cyanidin-3-glucoside (C3G)/L) of samples was calculated via the following Equation (1) [33,40]: where M (molecular weight)=449.2 g/mol for C3G; DF (dilution factor);1000 = conversion from g to mg;e (molar absorptivity coefficient in L/mol/cm for C3G)=26,900;d (path length)=1cm. 2.6.2. Characterization of the AgCol The optical absorption spectra of t he AgCol were observed using a UV-vis spectropho-tometer (UV-1800, Shimadzu, Japan) between 300 and 700 nm. T ransmission electron microscopy (TEM, JEOL JEM-1400, Tokyo, Japan) was employed to identify the morphology and size of the AgCol. The XRD patterns of nanoparticles were recorded on a powder X-ray diffractometer (XRD, Oxford I nstruments, Oxford, UK) using CuKo radiation (入=1.541 A), operating at 40 kV and 40 mA, in the range of 10°≤ 20 ≤ 80°. The particle size of AgCol was calculated using the Debye-Scherrer Equation(2). Fourier t ransform infrared spectra of the Col extract and the AgCol were obtained with a FTIR spectrometer (Nicolet 6700, Thermo Scientific, Waltham, MA, USA) in the range of 4000-500 cm-.1 Thermogravimetric analysis of t he AgCol was carried out on a thermo gravimetric analyzer (TGA-209F, Netzsch, Selb, Germany). The sample was heated to temperature ranging from 40 °C to 800 °C under N2 atmosphere, at 10 °C/min heating rate. 2.6.3. Characterization of the Modified Viscose Fabrics A scanning electron microscope (SEM, SM-6510LV JEOL, Japan) coupled with an energy dispersive X-ray spectroscope (EDX, Oxford EDS Microanalysis System, Oxford,UK) was used to determine the morphologies and elemental compositions of the untreated and treated viscose fabrics with Fib and AgCol after platinum sputtering. The FTIR measurements of the untreated and treated viscose fabrics with Fib and 使用凯氏定氮法用格哈特公司 VAPODEST维普得凯氏定氮仪检测改性粘胶织物中Fib蚕丝 蛋白的含量,转化系数为6.25 The Kjeldahl method (Gerhardt Vapodest Kjeldahl Analysis System, Germany) was employed to detect the content of Fib in the modified viscose fabrics according to the [42]. Silver contents in the modified viscose fabrics were measured using a Atomic Absorp-tion Spectrometer (AAS, PinAAcle 900T, PerkinElmer, Waltham,MA, USA). Color changes of the modified viscose fabrics, in terms of L*, a*, and b* values,and color differences (AE*) were determined using a reflectance spectrophotometer (Ci4200,X-rite, USA) with D65 illumination, and a 10°observer. In the CIELab color space, L*represents lightness, while a* and b* represent chromaticity parameters. The average color parameter values were evaluated at three positions for each sample. The overall color change was calculated based on the following Equation (3): where AL*, Aa*, and Ab* represent the changes i n L*, a* and b* between the initial and three values, respectively. 2.7. Antibacterial Activities 2.7.1. Bio-Synthesized Silver Nanopart i cles (AgCol) The antibacterial activities of the AgCol against three gram-negative bacteria (E. coli,P. aeruginosa and S. enterica) and three gram-posi t ive bacteria (S. aureus, B. cereus and E. faecalis) were studied by using well diffusion assay with the Clinical Laboratory Standard Institute guidelines [43]. In a typical experiment, each bacterial strain was sub-cultured in nutrient broth at 37 C unti l it reached a count of approximately 10° colony-forming units (CFU) per mL in sterile screw-cap test tubes. Afterwards, each bacteria l suspension was spread uniformly on the i ndividual agar petri plates by using sterile cotton swabs. Seven wells with the diameter of 6 mm were aseptically punched using a sterile cork borer, and then 30 uL of Col extract (10 mg C3G/L), AgCol solutions at different concentrations (120,60, 30 and 15 ug/mL), a standard antibiotic (Chloramphenicol , 200 ug/mL) as positive control, and double distilled water as a negative control were poured into their respective wells. These plates were incubated at 37 °C for 24 h, and the obtained zones of i nhibition (ZOI) were measured using the following Equation (4): where W: width of clear zone of inhibition,mm; T: total diameter of the test specimen and clear zone, mm; D: diameter of the test specimen, mm. 2.7.2. The Modified Viscose Fabrics with AgCol and Silk Fibroin The antibacterial activities of the untreated and treated fabrics with AgCol and silk fibroin against both E . coli and S. aureus were evaluated qualitatively and quantitatively according to the establ i shed protocols to test the antibacteria l activity of textiles. The following methods were used: AATCC 147-2004 and ASTM E2149-10 test methods. For the parallel streak method AATCC 147-2004, the rectangular fabric samples (15×55 mm) were prepared and pasteurized by the autoclave at 121 C for 20 min. About 1 mL of each strain culture grown overnight brain heart infusion broth (BHI), at approx-imately 10°CFU/mL, was mixed with 9 mL of sterile dist i lled water. Then, one loopful of diluted inoculum was transferred to the surface of the sterile agar plate by making five streaks, approximately 60 mm in l ength, spaced 10 mm apart and covering the central area of a standard petri dish. The prepared fabric samples were gently pressed by contact across the five inoculum streaks on the agar surface and incubated at 37°C for 24 h. The width of the clear zone of inhibition was used to determine the antimicrobial activity. For the dynamic shake flask method ASTM E2149-10, about 1 g of each fabric sample was cut into small pieces and transferred into individua l sterile glass f lasks containing 50 mL of bacterial suspension with a concentration of 105 CFU/mL. All flasks were loosely capped, placed in an incubator, and shaken at 37 °C and 120 rpm using an incubator shaker for 1 min and 1 h. Af t erwards, a series of dilutions of the bacterial sample solutions using a buffer solution and 100 uL was spread over the agar plate. Bacteria recovery at after 1 min (zero contact time) and 1 h were determined. The inoculated plates were then incubated at 37°C for 24 h and the surviving bacteria were counted. The percent reduction of bacteria was calculated using the following Equation (5): where R: the bacterial reduction percentage,%; A and B: the number of bacteria recovered for the flasks containing test samples and without samples (blank), respectively. Each experiment was performed in triplicates and the final values were presented as the mean ± standard deviation (SD). 2.7.3. Durability of the Antimicrobial Treatment against Washing To evaluate the durability of the antimicrobia l treatment, the washing fastness test on the modified viscose fabrics was carried out in accordance with the AATCC 61-2013(2A)standard , which simulates five home laundering cyc l es. The stability of the treated viscose fabric with AgCol and Fib was examined through antibacterial tests against E. coli and S. aureus after 5, 10, 20, and 30 washes in the presence of a non-ionic detergent 3. Results and Discussion 3.1. Synthesis and Optimization of AgCol from Col Extract Previous reports confirmed that biological compounds existing in plant extracts, such as alkaloids, flavonoids, polysaccharides, anthocyanins, glycosides, proteins, could played a dual role of both reducing and stabilizing agents for the synthesis of AgNPs [18,20,44-46]. In addition, the size, shape, and yield of bio-synthesized AgNPs depend not only on the content of bio-compounds but also on the type of compounds present in the plant extract [45,46].The Cordyline fruticosa L. leaf was reported to contain anthocyanin, saponin, flavonoids,flavonols, chlorophyll, glycoside, etc., in which anthocyanin was one of t he major compounds of i t s aqueous extract [33-39]. The primary molecule struc t ure of anthocyanin is cyanidin-3-glucoside, which was depicted in Figure 4a. Based on the data obtained from the UV-vis spectra of Col extract at pH= 1.0 and pH = 4.5 (Figure 4b), the TAC of the Col extract was calculated to be 109.72±0.63 mg C3G/L. Anthocyanin belongs to polyphenol compounds,which have inherent reduction property. In this research, the anthocyanin content of the Col extract was adjusted to control the reducing power of the Col extract in the green synthesis reaction. For the AgNPs synthesis, the Col extract was diluted to a fixed concentration of 10 mg C3G/L, mixed with the silver nitrate solution a t various concentrations, and kept at 50 C for different periods of reac t ion time. (d) oc -2h -4h -6h -8h 700 Wavelength (nm) Figure 4. (a) The molecular structure of anthocyanin,(b) UV-vis spectrum of Col extract, UV-vis spec t ra of AgCol synthesized at (c) di f ferent AgNO3 concentrations, and (d) reaction times. Real images of the samples are shown as insets in (b-d). 3.2. Morphological and Structural Characterization of AgCol The TEM measurement was carried out to study the morphology and size of the AgCol. Figure 5a,b revealed spherical-shaped nanoparticles with a size of 10-50 nm in diameter wi t h an average size of 28.5 nm. The spherical-shaped nanoparticles produced in the current study are in line with the expected shapes for AgCol. This result is consistent with the UV-vis observation and previous reports [44,45,48]. The crystalline structure of the AgCol was studied by recording the XRD pattern. As shown in Figure 5c, the XRD pattern of the AgCol revealed both the diffraction peaks of AgNPs and silver chloride nanoparticles. The diffrac t ion peaks were observed at 20=38.18°(111),43.72°(200), 64.45° (220), and 77.72° (311), confirming that the AgNPs were crystalline in nature and had the face center cubic (FCC) structure of metallic silver [45,51]. Other diffraction peaks at 20=27.90°(111),32.30°(200), and 46.00°(220) were corresponded to silver chloride nanoparticles (JCPDS No.: 85-1355) with FCC geometry [52-54]. These silver- based nanoparticles are often found in the final product of plant-mediated green synthesisolW of AgNPs [52-54]. The average size of AgCol was estimated using the Debye-Scherrerequation to be about 19.3 nm [46,53]. This observation of the XRD analysis supported the UV-vis and TEM measurements that the bio-constituents in the Col extract played a crucial role in the spherical AgCol stability. Temperature (℃) Figure 5. (a) TEM micrographs of AgCol with different magnification ×40 k and x500 k (inset),(b) histograms of the AgCol size distribution; (c) XRD pattern of AgCol, (d) FTIR spectra of Col and AgCol, and (e) TGA of AgCol. An FTIR analysis was used to confirm the possible interaction between AgCol and the functional groups of capping agents presented in the Col extract. The FTIR spectrum of the Col extrac t (Figure 5d) reflected i ntensive peaks of O-H(3261.8 cm-1), C-H of alkanes (2925.6 cm-1), C=O of esters and ketones (1592.6 cm-1), C-O of esters (1394.9 cm-1),and C-O of phenolic compounds (1039 cm-) [33]. These charac t eristic peaks i n the Col spectrum were typical of f lavonoid compounds, specific anthocyanin molecules. The FTIR spectrum of the AgCol also presented similar absorption peaks at 3437.7, 2925.6,1629.1,1383.4, and 1057 cm-1, confirming the presence of residual phytochemicals on the surface of the nanoparticles. However, shifts of peaks upon AgCol formation when compared to the Col could be attributed to the reduction of corresponding functional groups. In addition, a marked decrease in the peak intensity was observed at 1057 cm-1, indicating a possible involvement of the flavonoid compounds in the reduction process. The FTIR results confirmed that different functional groups of the phytocompounds of the extract were responsible for the formation and stabilization of AgCol , as presented in the previous studies [18,20]. To further confirm the crucial role of bio-compounds in stabilizing and capping the AgCol , TGA was carried out. This authentic technique is often used to determine the thermal stability and decomposition of a sample [19,49]. The TGA thermogram of the AgCol (Figure 5e) exhibited three identical weight loss stages over a wide temperature range from room temperature to 800 ℃. The i ni t ial weight loss (1.12%) at 200 ℃ could be involved in t he evaporation process of the physically bound water in the AgCol sample.The second weight loss (16.99%) occurred between 200 °C and 600 °C, which could be correlated to decomposition of the bio-organic compounds bound on the surface of the AgCol. The last weight loss at higher t emperature could be corresponded to the degradation and evaporation of the metallic silver [55]. Hence, the purity percentage of the AgCol was calculated to be about 81.89 wt% pure silver. The TGA data further confirmed that the presence of organic compounds over the AgCol surface could not only control the rate of reaction but also effectively prevented the agglomeration of nanoparticles, thus,stabilizing them. According to the above analyses, we propose a possible mechanism for bio-synthesis of AgCol using Col leaf extract as shown in Figure 6. Anthocyanin was used as a model molecule because many of bio-molecules existing in the Col leaf extract have similar chemical structures in terms of the presence of hydroxyl groups linked with aromatic rings.The biological compounds that act as a reducing agent may be not necessarily the same which play a role as capping agents. The mechanism of AgCol formation mainly consists of the following three steps: reduction of silver ions to obtain metallic silver atoms, the nucleation of some silver atoms to build up small clusters which act as a template for AgCol formation, and the growth of these clusters and the stabilization of formed AgCol by capping agents to prevent aggregation. This proposed mechanism of AgCol bio-synthesis in the presence of Col leaf extract is in good agreement with previous reports [56-58]. HC Figure 6. Proposed mechanism for bio-synthesis of AgCol using Col leaf extract. 3.3. Antimicrobial Ac t ivity of AgCol To assess the antibacterial activity of the AgCol, six different bacterial strains including E. coli , P. aeruginosa, S. enterica, S. aureus, B. cereus, and E. faecalis were exposed to various AgCol concentrations (120, 60, 30, and 15 ug/mL) using the well diffusion method. As shown in Figure 7a-f , the double distilled water (a negative control) and Col extract did not display any antibacterial activity in terms of the ZOI, while the AgCol and the chloramphenicol (a standard antibiotic) demonstrated an obvious ZOI. I t was clearly observed that the AgCol possessed promising antimicrobial activities against the tested bacterial pathogens. As presented in Figure 7g, the antibacterial activity was dependent on the tested bacteria strain and the AgCol concentration. Among the tested isolates, the ZoI was found to be the highest against P. aeruginosa (16.6±0.27 mm) and the lowest against S. enterica (5.9 ±0.37 mm) at the highest t ested AgCol concentration (120 ug/mL). The antimicrobial ability of the AgCol against E. coli and S. aureus was quite good even at a low concentration (15 ug/mL), with the ZOI of 6.9±0.23 and 7.6±0.56 mm, respectively.Furthermore, the comparison of the ZOI against each bacterial pathogen exhibited the tendency of the enhancement in the antibacterial activity with the increase in AgCol concentration. These bactericidal properties of plant-mediated green synthesized AgNPs have been addressed in previous studies [50,59]. Figure 7. The photographs showing the zone of inhibition of the AgCol against (a) E. coli , (b) P. aeruginosa,(c) S. enterica, (d) S. aureus, (e) B. cereus, and (f) E . faecalis; negative control (H2O); positive control (chloramphenicol 200 g/mL);AgCol (120 ug/mL );1/2 AgCol (60 ug/mL );1/4AgCol (30 ug/mL ),1/8AgCol (15ug/mL) and Col extrac t (10 mg C3G/L);(g) quantitative evaluation of antibacterial activity of the AgCol against six pathogenic bacteria (±SD, n=3). 3.4. Coloration of the Modified Viscose Fabrics with AgCol and Silk Fibroin In order to evaluate the adsorption capacity of AgCol on the Vis and VisFib fabrics with change in the wet pickup and AgCol concentration, the colorimetric data (L*, a*, b*),color differences (AE*), and color strength (K/S) of the f abric samples were determined , as shown in Table 2. The colorimetric data of both the AgCol-treated Vis and AgCol-treated VisFib fabric samples had a high L* value, and positive a* and b* values, indicating the light browning effect of the AgCol on the fabrics. The AE* and K/S values of all AgCol-treated fabric samples increased with the lower wet pickup and the higher AgCol concentration.Furthermore, these values of the AgCol-treated VisFib samples were higher than that of the AgCol-treated Vis samples. This could be explained by the formation of coordination bonding between AgCol and electron-rich nitrogen atoms of amine groups i n the fibroin adhered on viscose fabric, which supplemented the l inkage of hydroxyl groups of cel l ulose in viscose fabric with the nanoparticles. Therefore, the fibroin modified viscose fabric could improve t he AgCol uptake to compare with the neat viscose fabric. I t might enhance antibacterial efficacy and the antibacterial durability of the modified fabrics. Table 2. Colorimetric data, color differences, K/S value, and images of the AgCol t reated and untreated viscose fabric samples, with change in the wet pickup and AgCol concentration. Wet Pickup (%) AgCol (ug/mL) L* a* b* AE* K/S Fabric images Vis 一 一 93.54 -0.96 4.32 0 0.06 VisFib 一 一 93.47 -0.98 4.93 0.48 0.07 VisAg11 70 85.16 3.86 8.95 8.39 0.19 VisAg21 80 80 84.32 4.55 9.08 9.17 0.2 VisAg31 90 85.12 4.1 8.77 8.49 0.18 VisAg21 80 84.32 4.55 9.08 9.17 0.20 VisAg22 80 40 85.65 3.15 6.34 6.33 0.15 VisAg23 20 89.58 1.11 5.75 3.53 0.11 VisFibAg21 80 79.95 4.31 6.72 8.91 0.28 VisFibAg22 80 40 83.99 2.85 5.90 6.44 0.19 VisFibAg23 20 87.73 1.56 5.22 4.33 0.13 3.5. Antibacterial Efficacy of the Modified Viscose Fabrics with AgCol and Silk Fibroin I t i s well known that AgNPs can endow cellulose fabrics with excel l ent antibacterial ac-tivity [1,3,5]. Thus, antibacterial tests were performed with the AATCC 147-2004 and ASTM E2149-10 methods to i nvestigate the antibacterial efficacy of t he AgCol-treated viscose fab-rics. As shown in Figure 8, all the AgCol-treated viscose fabrics and the chloramphenicol-treated fabrics revealed an obvious ZOI against E. col i and S. aureus, whi l e the Vis and VisFib fabrics exhibited no antibacterial activity. This confirms that AgCol-treated viscose fabrics possess antibacterial capability in this work. In addition, the ZOI of AgCol-treated fabric samples seem unchanged with t he altering wet pickup, and these were substantially larger with the higher AgCol concentration. Furthermore, these values for the AgCol-treated VisFib samples were higher than those of the AgCol-treated Vis samples. These results demonstrated that the higher the AgCol uptake on fabric samples, the better the antibacte-rial efficiency. The antibacterial results also gave additional evidence of the enhancement of the AgCol uptake on fabric by the fibroin modifying viscose fabric. The AgCol-treated fabric conditions were chosen to get a good antibacterial efficacy with the wet pickups of 80% and AgCol concentrations of 80 ug/mL. The obtained f abrics under this treatment condition were further evaluated in terms of antibacteria l durabi l ity against up to 30 home laundering cycles. Figure 8. The photographs showing the zone of inhibition of the Vis, VisFib, chloramphenicol-treated (200 ug/mL) Vis (Vis-Clp), and VisFib (VisFib-Clp), and the AgCol-treated fabric samples against E. coli and S. aureus, with change in the wet pickup and AgCol concentration. The durable antimicrobial activity of the AgCol-treated viscose fabrics was qualita-tively visualized i n Figure 9a, and then plotted in Figure 9b. As shown i n Figure 9b, the antibacterial rate (BR) of the VisAg and VisFibAg fabrics for both E. coli and S. aureus after a 1 h contact period were both 99.99%. This indicated that the AgCol-treated fabrics pro-vide excellent antibacterial properties. The BR values of the VisAg samples for E. col i and S . aureus were about 80% and 87% after 30 washing cycles, respectively, while t hese values for the VisFibAg samples still remained 99.99% for both E. coli and S. aureus. (b) Figure 9. (a) The photographs of bacterial growth in the BHI agar pla t es and (b) the antibacterial rate (BR) of the Vis, VisFib, and AgCol-treated fabric samples against E. coli and S. aureus after 10, 20,and 30 repeated washing cycles. 3.6. Characteristic s of the Modified Viscose Fabrics with AgCol and Silk Fibroin To obtain more evidence of the role of fibroin as an effective binder between the AgCol and cellulose fibers in viscose fabric, the fabric surface morphology, AgCol, and fibroin content on the fabrics before and after wash were investigated. The fabric surface morphologies of t he original viscose and AgCol-treated viscose fabrics before and after 30 washing tests were explored t hrough SEM at different magnifications, as shown in Figure 10. The untreated fabric displayed the smooth surface of the viscose fibers. Rougher surfaces were observed on the f ibers of AgCol-treated fabrics before and after 30 washes,indicating the occurrence of AgCol or/and Fib attached on surface of viscose fibers. The EDX spectra of those f abrics confirmed that the bright points in the SEM images were AgCol.Moreover, the bright points in the SEM micrographs of the VisFibAg fabrics were more than those of the VisAg samples, demonstrating higher AgCol uptake on the VisFibAg fabrics compared with the VisAg fabrics. After 30 washing cycles, the f ibroin l ayer covering the surfaces of viscose fibers was still observed directly in the SEM image of the VisFibAgW30sample. These results confirmed again that the fibroin acted as binding polymer to coat AgCol on the viscose surface. x10k Figure 10. The SEM micrographs at different magnifications of x50,×5000, and ×10,000, and EDX spectra of t he neat viscose f abric and t he AgCol-treated f abrics before and after 30 washing cycles. The interaction of AgCol and f ibroin on the modified fabrics were analyzed by mea-suring silver and fibroin contents in t he t reated viscose fabrics before and after 30 washes (Table 3). The silver content of the VisFibAg fabric before washing was 14.3% higher than that of the VisAg fabric . After 30 washing cycles, the loss of silver content was only 25.6%for the VisFibAg fabric, while about 51.2% of silver was released from the VisAg fabric. The fibroin content of t he modified fabrics decreased slightly during washing cycles. About 50%of si l k fibroin still remained on both the VisFib and VisFibAg fabric after 30 washes, owing to the role of Al3+ions in crosslinking between fibroin molecules and t he cellulose f ibers of the viscose f abric [41]. The strong linkage between the fibroin and viscose f ibers lead to an enhancement in the incorporation of AgCol into the modified fabrics. Due to the presence of numerous amine groups in f ibroin, it tends to bind with AgCol by coordination bonds.These results are in harmony and fit well with those illustrated in the SEM micrographs and the antibacterial ability of the AgCol-treated viscose fabr i cs. Table 3. The silver content, nitrogen content, and fibroin content on the AgCol-treated viscose fabrics before and after 30 washing cycles. No Washing AgCol Silver Content Nitrogen Fibroin a Fabric Sample Cycles (ug/mL) Fibroin (%) (mg/kg) Content (%) Content (%) 1 Vis 一 一 一 0.019 2 VisFibWO 0 一 2.5 一 0.244 1.406 3 VisFibW30 30 一 一 0.121 0.638 4 VisAgWO 0 80 一 642.02 一 5 VisAgW30 30 80 一 313.43 一 一 6 VisFibAgWO 0 80 2.5 734.05 0.242 1.394 7 VisFibAgW30 30 80 一 545.86 0.127 0.675 a The protein-to-ni t rogen conversion f actor is 6.25. In order to determine the possible interaction between the functional groups of fibroin on the modified fabric and AgCol, the FTIR measurements of viscose fabric (Vis), fibroin modif i ed viscose fabric (VisFib), AgCol-treated Vis fabric (VisAg), and AgCol-treated VisFib f abric (VisFibAg) samples were carried out , and the spectra were given in Figure 11.The characteristic peaks corresponding to cellulose in the Vis at 3331.9, 2887.5, 1638.6,1364.9, and 1017.9 cm- were assigned to the O-H, C-H, C=O,C-H, and C-O-H groups,respectively [41]. Compared to the neat viscose fabric, the VisFib spectrum revealed a fair similarity of these characteristic peaks, with the exception of the lower peak i ntensities at 3314.8 and 1636.5 cm-of the VisFib spectrum. It could be explained that the interactions might be occurring via the formation of hydrogen bonding between f ibroin's amide groups and viscose's hydroxyl groups, and/or via the complexation of Al+ions with appropriate functiona l groups of f ibroin and viscose [41,60]. The VisAg and VisFibAg spectra also exhibited similar characterist i c peaks to those in the Vis and VisFib spectra, respec t ively,suggesting that the chemical structure of the cellulose was mostly unchanged. However,the peaks of the functional groups in the VisFibAg shifted toward higher wavenumbers at 3316.2, 1639.9, and 1365.3 cm-, and the intensity of these peaks were significantly decreased in comparison with the spectra of the VisFib and VisAg fabrics. The shifting of these peaks occurred due to the interaction of heavy silver atom with amino and amide groups of f ibroin molecules, resul t ing in a decrement in the peak intensity with an ul t imate red frequency shi f t [1,5,31,41]. Figure 11. The FTIR spectra of the Vis, VisFib, VisAg, and VisFibAg fabrics. Figure 12. The proposed mechanism of fibroin regeneration and AgCol deposition onto viscose f abric. 4. Conclusions This research provided a novel approach for the fabrication of durable antibacterial viscose fabric modified with bio-synthesized AgCol and silk f ibroin as an eco-friendly binder. The AgCol were bio-synthesized using reducing and capping agents from hot water extract of Cordyline fruticosa L. leaves. The effect of the reaction conditions, such as the silver salt concentration and the reaction time, were investigated using several analytical techniques including UV-vis, TEM, XRD, FTIR, and TGA. The bio-synthesized AgCol were found to be effective antibacter i al activities against six pathogenic bacteria. The AgCol was employed as an antibacterial agent for the functionalization of viscose fabric combined wi t h si l k fibroin. The modi f ied viscose fabric with AgCol and fibroin exhibited a remarkable antimicrobial activity against E. col i and S. aureus bacteria even after 30 washing cycles, due to the presence of numerous amine and amide groups in fibroin, which might form coordination bonding with AgCol. The colorimetry, SEM, EDX, AAS, Kjeldahl, and FTIR analyses provided sufficient evidence for the role of the fibroin as an effective binder between the AgCol and cellulose f ibers in viscose fabric. The bio-synthesized AgCol and fibroin modified viscose fabric possessed superior durable antibacterial activity, which would meet the basic criteria for medical textile applications. Author Contributions: Conceptualization, N.-T.N.; methodology, N.-T.N. and T.-L.-H.V.; formal analysis,T.-L .-H.V.; investigation,N.-T.N. and T.-L.-H.V.; data curation, N.-T.N.; writing-original draft preparation, T.-L.-H.V.; writing -review and editing, N.-T.N.; visualization, N.-T .N. and T.-L.-H.V.; supervision, N.-T.N.; project administration, N.-T.N.; funding acquisition, N .-T .N. All authors have read and agreed to the published version of the manuscript. Funding: This work was f unded by the Vietnam Ministry of Education and Training under Grant No.B2022-BKA-23. Institutional Review Board Statement: Not applicable Informed Consent Statement : Not applicable. Data Availability Statement : Not applicable. Acknowledgments: The authors also would l ike to thank colleagues from School of T extile-Leather and Fashion, Hanoi University of Science and Technology for their efforts in supporting this work Conflicts of Interest: The authors declare no conflict of interest. References 1. Xu, Q.; Zheng, W.; Duan, P.; Chen, J; Zhang, Y.; Fu, F; Diao, H.; Liu, X. One-pot fabrication of durable antibacterial cotton fabric coated with silver nanoparticles via carboxymethyl chitosan as a binder and stabilizer. Carbohydr. Polym. 2019, 204, 42-49.[CrossRef] [PubMed ] 2. Fahmy, H.M.; Eid, R.A.A.; Hashem, S.S.; Amr , A. Enhancing some functional properties of v i scose f abric. Carbohydr. Polym. 2013,92, 1539-1545. [CrossRef ] [PubMed ] 3. Xu, Q.; Xie, L.; Diao, H.; Li , F; Zhang, Y.; Fu, F; Liu, X. Antibac t erial cotton f abric with enhanced durability prepared using silver nanoparticles and carboxymethyl chitosan. Carbohydr. Polym. 2017, 177,187-193. [CrossRef ] [PubMed ] 4. Ibrahim, N.A.; El-Zairy, E.M.R.; Eid, B.M. Eco-f riendly modification and antibacterial functionalization of viscose fabric. J . Text .Inst . 2017,108,1406-1411.[CrossRef ] 5. Raza, Z.A.; Bilal, U.;Noreen, U .;Munim, S.A.; Riaz, S.; Abdullah, M.U.; Abid, S. Chitosan Mediated Formation and Impregnation of Silver Nanoparticles on Viscose Fabric in Single Bath for Antibacterial Performance. Fibers Polym. 2019, 20, 1360-1367.[CrossRef | 6. Mostafa, K.; El -Sanabary, A. Innovative ecological method for producing easy care characteristics and antibacterial activity onto viscose f abric using glutaraldehyde and chitosan nanoparticles. Pigment . Resin Technol. 2020,49,11-18. [CrossRef ] Emam, H.E. Antimicrobial cellulosic textiles based on organic compounds. Bio technology 2019,9, 29.[CrossRef ]8 Song, X.; Cvelbar, U.; Strazar, P.; Vossebein, L.; Zille, A. Antimicrobial Efficiency and Surface Interactions of Quaternary Ammonium Compound Absorbed on Dielectric Barrier Discharge (DBD) Plasma Treated Fiber-Based Wiping Materials. ACS Appl . Mater. Interfaces 2020, 12, 298-311. [CrossRef ] 9. Morais, D.S.; Guedes, R.M.; Lopes,M.A. Antimicrobial Approaches for Textiles: From Research to Market. Materials 2016,9,498.[CrossRef ][PubMed] 10. Hassabo, A.G.; El-Naggar, M.E.;Mohamed, A.L.; Hebeish, A.A. Development of multifunctional modified cotton fabric with tri-component nanoparticles of silver, copper and zinc oxide. Carbohydr. Polym. 2019,210,144-156.[CrossRef ] 11. Emam, H.E.; El-Hawary, N.S.; Ahmed , H.B. Green technology for durable f inishing of viscose f ibers via self-formation of AuNPs.Int. J. Biol. Macromol. 2017,96,697-705.[CrossRef ][P ubMed ] 12. Phan,D.-N.; Khan, M.Q.;Nguyen, N.-T.; Phan, T.-T.;Ullah, A.; Khatri, M.; Kien, N.N.; Kim, I .-S. A review on the fabrication of several carbohydrate polymers into nanofibrous structures using electrospinning for removal of metal ions and dyes. Carbohydr.Polym. 2021, 252,117175. [CrossRef] [PubMed ] 13. Edgar, K.J.; Zhang, H. Antibacterial modi f ication of Lyocell fiber: A review. Carbohydr. Polym. 2020,250,116932.[CrossRef ][PubMed ] 14. McQueen, R.H.; Vaezafshar, S. Odor in textiles: A review of evaluation methods, fabric characteristics, and odor control technologies. Text. Res. J.2019,90,1157-1173. [CrossRef ] 15. Nguyen, N.-T.; Liu, J .-H. A green method for in si t u synthesis of poly(vinyl alcohol)/chitosan hydrogel thin fi l ms with entrapped silver nanoparticles. J. Taiwan Inst. Chem. Eng. 2014,45,2827-2833.[CrossRef ] 16. Wu, Y.; Yang, Y.; Zhang, Z.;Wang, Z.;Zhao, Y.; Sun, L . Fabrication of cotton fabrics with durable antibacterial activ i ties f inishing by Ag nanoparticles. Text. Res. J. 2018,89,867-880. [CrossRef ] 17. Zhou, Q.; Lv, J.;Ren, Y.; Chen, J.; Gao, D.; Lu, Z.; Wang, C. A green i n situ synthesis of silver nanoparticles on cotton fabrics using Aloe vera lea f extraction for durable ultrav i olet protection and antibacteria l activity. Text. Res. J.2016,87,2407-2419.[CrossRef ] 18. Abdelghany, T.M.; Al-Rajhi, A.M.H.; Al Abboud, M.A.; Alawlaqi, M.M.; Ganash Magdah, A.; Helmy, E.A.M.; Mabrouk, A.S.Recent Advances in Green Synthesis of Silver Nanoparticles and Their Applications: About Future Directions. A Review.BioNanoScience 2018,8,5-16. [CrossRef ] 19. Thi Lan Huong, V.; Nguyen, N.T. Green synthesis, characterization and antibacterial activity of silver nanoparticles using Sapindus mukorossi fruit pericarp extract . Mater. Today Proc . 2020,42,88-93. [CrossRef ] 20. Vanlalveni, C.; Lallianrawna, S.; Biswas, A.; Selvaraj, M.; Changmai, B.;Rokhum, S.L. Green synthesis of silver nanoparticles using plant extracts and t heir antimicrobial activities: A review of recent l iterature. RSC Adv. 2021, 11, 2804-2837. [C rossRef ] 21. Ovais, M.; Khali l , A.T.; Raza, A.; Khan, M.A.; Ahmad, I.; Islam, N.U.; Saravanan, M.; Ubaid,M.F; Ali , M.; Shinwari, Z.K. Green synthesis of silver nanoparticles via plant extracts: Beginning a new era in cancer theranostics. Nanomedicine 2016,11,3157-3177.[CrossRef ][PubMed] 22. Heravi , M.E.M. Effects of Hydrodynamic Diameter of Nanoparticles on Antibacterial Activity and Durabi li ty of Ag-treated Cotton Fabrics. Fibers Polym. 2020, 21,1173-1179. [CrossRef ] 23. Rehan, M.; Mashaly, H.M.; Mowafi,S.; Abou El-Kheir, A.; Emam, H.E. Multi-functional textile design using in-situ Ag NPs incorporation into natural fabric matrix. Dyes Pigments 2015,118,9-17. [CrossRef ] 24. Zhang, D.; Chen, L.; Zang, C.; Chen, Y.; Lin, H. Antibacterial cotton fabric grafted with silver nanoparticles and its excellent laundering durabi l ity. Carbohydr. Polym. 2013, 92,2088-2094.[CrossRef ] 25. Zheng,J ; Song, F .; Wang, X.-L.; Wang, Y.-Z. In-situ synthesis, characterization and antimicrobial activity of viscose fiber loaded with silver nanoparticles. Cellulose 2014, 21,3097-3105.[CrossRef ] 26. Emam, H.E.; Saleh, N.H.; Nagy, K.S.; Zahran, M.K. Functionalization of medical cotton by direc t incorporation of silver nanoparticles. Int. J. Biol. Macromol. 2015, 78, 249-256. [CrossRef ] 27. Su, C.-H.; Kumar, G.V.; Adhikary, S.; Ve l usamy, P;Pandian, K.; Anbu, P. Preparation of cotton fabric using sodium alginate-coated nanoparticles to protect against nosocomial pathogens. Biochem. Eng. J. 2017, 117, 28-35. [CrossRef ] 29. Hanh, T.T.; Thu, N.T; Hien, N.Q.; An, P.N.; Loan, T.; Thi, K.; Hoa, P.T. Preparation of silver nanoparticles fabrics against multidrug-resistant bacteria. Radiat . Phys. Chem. 2016, 121,87-92. [CrossRef ] 30. Ibrahim, N.A.; Eid, B.M.; Abdel-Aziz,M.S. Effect of plasma superficia l treatments on antibacterial functionalization and coloration of cellulosic fabrics. Appl . Surf. Sci. 2017, 392,1126-1133. [CrossRef ] 31. Arif, D.; Niazi, M.B.K.; Ul-Haq, N.; Anwar , M.N.; Hashmi, E. Preparation of antibacterial cotton fabric using chitosan-silver nanoparticles. Fibers Polym. 2015,16,1519-1526.[CrossRef ] 32. Xu, Q.; Ke, X.; Shen, L.; Ge, N.; Zhang, Y.; Fu, F; Liu, X. Surface modi f ication by carboxymethy chitosan via pad-dry-cure method for binding Ag NPs onto cotton fabric. Int. J. Biol. Macromol. 2018,111,796-803. [CrossRef ] [PubMed ] 33. Nguyen, N.T; Hoang, T.T.L. Optimization of ultrasound-assisted extraction of natural colorant from Huyet du leaves using ethanol solvent. J. Sci. Technol. HaUI 2019,51,109-113. 34. Lim, T.K. (Ed.) Cordyline fruticosa. In Edible Medicinal and Non Medic i nal Plant s : Volume 9, Modified Stems, Roots, Bulbs; Springer:Dordrecht, The Netherlands, 2015. 35. Nguyen Thi , D.P.; Tran, D.L.; Le Thi, P.;Park, K.D.; Hoang Thi, T.T . Supramolecular Gels Incorporating Cordyline terminalis Leaf Extract as a Polyphenol Release Scaffold for Biomedical Applications . Int. J . Mol . Sci . 2021, 22, 8759. [CrossRef ] 36. Raslan, M.A.; Taher, R.F .; Al-Karmalawy, A.A.;El-Ebeedy, D.; Metwaly, A.G.; Elkateeb, N.M.; Ghanem, A.; Elghaish, R.A.; Abd El Maksoud, A.I. Cordyline fruticosa (L.) A. Chev. leaves: Isolation, HPLC/MS profiling and evaluation of nephroprotective and hepatoprotective activities supported by molecular docking. New J. Chem. 2021, 45, 22216-22233.[CrossRef ] 37. Siddiqi, K.S.; Husen, A.; Rao, R.A.K. A review on biosynthesis of silver nanoparticles and their biocidal properties. J . Nanobiotech-nol.2018,16,14. [CrossRef ] 38. Jadoun, S.; Arif, R.; Jangid, N.K.; Meena, R.K. Green synthesis of nanoparticles using plant extracts: A review. Environ. Chem. Lett.2021,19,355-374. [CrossRef ] 39. Al-Alwani, M.A.M.; Ludin, N.A.; Mohamad, A.B.; Kadhum, A.A.H.; Sopian, K. Extraction, preparation and application of pigments from Cordyline fruticosa and Hylocereus polyrhizus as sensitizers for dye-sensitized solar cells. Spectrochim. Acta Mol.Biomol. Spectrosc. 2017,179,23-31.[CrossRef ] 40. Lee,J.; Durst , R.W.; Wrolstad, R.E. Determination of Total Monomeric Anthocyanin Pigment Content of Fruit Juices, Beverages, Natura l Colorants, and Wines by the pH Di f ferential Method: Collaborative Study. J.AOAC Int . 2019,88,1269-1278.[CrossRef ] 41. Thang,N.N.;Huong, V.T.L. Enhancement of dye-ability of viscose fabric via modification with f ibroin regenerated from waste silk cocoons. Vlak. Text . 2021,28,100-107. 42. Thiex, N.J.; Manson, H.; Anderson, S.; Persson, J .-A. Determination of Crude Protein in Animal Feed, Forage, Grain, and Oilseeds by Using Block Digestion with a Copper Catalyst and Steam Distillation into Boric Acid: Collaborative Study. J. AOAC Int . 2019,85,309-317.[CrossRef 43. Wikler, M.A.; Low, D.E.; Cockerill, F.R.; Sheehan, D.J.; Craig, W.A.; Tenover, F.C. Methods for Dilution Antimicrobial Susceptibility Tests for Bacteria That Grow Aerobically: Approved Standard,7th ed.; Document M7-A7; CLSI : Wayne, PA, USA, 2006. 44. Ahmad, S.; Munir, S.; Zeb, N.; Ullah, A.; Khan, B.; Ali, J.; Bilal, M.; Omer, M.; Alamzeb, M.; Salman, S.M.; et al. Green 46. Hamidian, K.; Sarani , M.; Barani, M.; Khakbaz, F. Cytotoxic performance of green synthesized Ag and Mg dual doped ZnO NPs using Salvadora persica extract against MDA-MB-231 and MCF-10 cel l s. Arab. J. Chem. 2022,15,103792. [CrossRef ] 47. Tran, Q.H.; Nguyen, V.Q.; Le, A.-T. Silver nanoparticles: Synthesis, properties, toxicology, applications and perspectives. Adv.Nat . Sci . Nanosci. Nanotechnol. 2013,4,033001. [C rossRef ] 48. Kanniah, P.; Radhamani,J .; Chelliah, P.; Muthusamy, N.; Joshua Jebasingh Sathiya Balasingh Thangapandi, E.; Reeta Thangapandi,J.; Balakrishnan, S.; Shanmugam, R. Green Synthesis of Multifaceted Silver Nanoparticles Using the Flower Extract of Aerva lana t a and Evaluation of I t s Biological and Env i ronmental Applications. ChemistrySelect 2020, 5, 2322-2331. [CrossRef ] 49. Hemmati, S.; Rashtiani, A.;Zangeneh, M.M.; Mohammadi , P.; Zangeneh, A.; Veisi, H. Green synthesis and characterization of silver nanoparticles using Fritillaria flower extract and their antibacterial activity against some human pathogens. Polyhedron 2019,158,8-14.[CrossRef ] 50. Vishwasrao, C.; Momin, B.; Ananthanarayan, L. Green Synthesis of Silver Nanoparticles Using Sapota Fruit Waste and Evaluation of Thei r Antimicrobial Activ i ty. Waste Biomass Valorization 2019,10,2353-2363. [CrossRef ] 51. Srikar, S.K.; Giri, D.D.; Pal, D.B.; Mishra,P.K.; Upadhyay, S.N. Green synthesis of silver nanoparticles: A review. Green Sustain.Chem. 2016, 6,34-56. [CrossRef ] 52. Ravichandran, V.; Vasanthi , S.; Shalini , S.; Shah, S.A.A.; Tripathy, M.; Paliwal, N. Green synthesis, characterization, antibacterial,antioxidant and photocatalytic activity of Parkia speciosa leaves extract mediated silver nanoparticles. Results Phys. 2019, 15,102565.[CrossRef ] 53. Bagherzade, G.; Tavakoli , M.M.; Namaei, M.H. Green synthesis of silver nanoparticles using aqueous extract of saffron (Crocus sat i ous L.) wastages and i ts antibacteria l activity against six bacteria. Asian Pac. J . Trop. Biomed. 2017, 7, 227-233. [CrossRef ] 54. Duran, N.; Nakazato, G.; Seabra, A.B. Antimicrobial activity of biogenic silver nanoparticles, and silver chloride nanoparticles:An overview and comments. Appl. Microbiol. Biotechnol. 2016,100,6555-6570.[CrossRef ][PubMed ] 55. Asoro, M.; Damiano,J.; Ferreira, P.J. Size Effects on the Melting Temperature of Silver Nanoparticles: In-Situ TEM Observations.Microsc . Microanal. 2009,15,706-707. [CrossRef ] 56. Chugh, H.; Sood, D.; Chandra, I .; Tomar, V.; Dhawan, G.; Chandra, R. Role of gold and silver nanoparticles in cancer nano-medicine. Artif. Cells Nanomed. Biotechnol. 2018, 46,1210-1220. [CrossRef ] 57. Litvin, V.A.; Galagan, R.L.; Minaev, B.F. Kinetic and mechanism formation of silver nanoparticles coated by synthetic humic substances. Colloids Surf. Physicochem. Eng. Asp. 2012,414,234-243.[CrossRef ] 58. Alahmad , A.; Feldhoff, A.; Bigal l , N.C.; Rusch, P.; Scheper, T .; Walter, J.-G. Hypericum perforatum L.-Mediated Green Synthesis of Silver Nanoparticles Exhibi t ing Antioxidant and Anticancer Activities. Nanomaterials 2021,11,487.[CrossRef 59. Tripathi, D.; Modi, A.;Narayan, G.; Rai, S.P. Green and cost effective synthesis of silver nanopar t icles from endangered medicinal plant Withania coagulans and their potential biomedica l properties. Mater. Sci. Eng. 2019,100,152-164.[CrossRef ] 60. Ngo, H.-T.; Bechtold, T . Surface modification of textile material through deposit i on of regenera t ed si l k fibroin. J . Appl. Polym. Sci.2017,134,45098.[CrossRef ]
关闭
  • 1/21
  • 2/21
还剩19页未读,是否继续阅读?
继续免费阅读全文
产品配置单
中国格哈特为您提供《蚕丝纤维蛋白改性粘性织物中蚕丝蛋白含量的检测》,该方案主要用于纺织原料中蚕丝蛋白检测,参考标准《暂无》,《蚕丝纤维蛋白改性粘性织物中蚕丝蛋白含量的检测》用到的仪器有格哈特带自动进样器凯氏定氮仪VAP500C、格哈特快速干燥仪STL56、格哈特红外加热消解快速消化系统TTs125、格哈特自动升降凯氏定氮电热消解仪KT-L 20s、德国加液器MM、格哈特维克松废气实验室废物处理系统涤气VS、凯氏定氮催化剂5.0g K2SO4+0.5g CuSO4 x 5H2O。
我要纠错
推荐专场
相关方案
