流体中PIV检测方案(粒子图像测速)
检测样品
其他
检测项目
PIV
关联设备
共1种
下载方案
Numerical simulations of particle image velocimetry (PIV) experiments con-
ducted with vortex generating jets (VGJs) on a °at plate, at a Reynolds number
based on plate length of 50,000, were performed for three °ow conditions using a
time-accurate hybrid Navier-Stokes solver. Time-averaged steady blowing of angled
jets, subjected to a zero pressure gradient, yielded excellent agreement with the PIV
data in terms of vortex formation and strength. Observed °ow features include pri-
mary and secondary vortices, where the primary vortex eventually dominates the
downstream region. A shell wall structure, created by smaller vortical structures sur-
rounding the developing vortices, was also observed. A pulsed jet in a zero pressure
gradient was then initialized from a no-control case. A qualitative comparison be-
tween averaged experimental and instantaneous numerical results was performed with
good agreement in terms of the convected size and distance of the wake. Analysis
of the instantaneous numerical °ow ¯eld agreed well with various °ow visualization
experiments describing the formation of \kidney" vortices. Various indicators point
to the production of a primary vortex by the reduced mass °ow of the pulsed jet.
Finally, an adverse pressure gradient was applied, inducing a laminar separation zone
on the plate. A pulsed angled jet induced strong spanwise vortices in the separated
shear layer which appear to weaken the separation zone and allow the bulk jet °uid
to °ush the remaining low-momentum °uid out of the domain. It is reasonable to
assume that reduced blowing ratios and duty cycles would produce similar shear layer
vortices and comparable loss reductions. In°uences of both turbulent transition and
dominant vortical structures were observed, though the spanwise shear layer vortices
appear to be critical to the laminar separation reduction scenarios observed in this
study.
北京欧兰科技发展有限公司为您提供《流体中PIV检测方案(粒子图像测速)》,该方案主要用于其他中PIV检测,参考标准《暂无》,《流体中PIV检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
