醉卧古隆中
第3楼2007/09/28
Santo V. Salinas, Chew W. Chang, and Soo C. Liew
Multiparameter retrieval of water optical properties from above-water remote-sensing reflectance using the simulated annealing algorithm
APPLIED OPTICS 46 (14): 2727-2742 MAY 10 2007ApplOptics46-2727
我在故我思
第6楼2007/09/28
jzhiquan朋友的资料:
Jeong Ho Ryu, Bong Geun Choi, Jong-Won Yoon, Kwang Bo Shim, Kinuyo Machi and Kenji Hamada
Synthesis of CaMoO4 nanoparticles by pulsed laser ablation in deionized water and optical properties
JOURNAL OF LUMINESCENCE 124 (1): 67-70 MAY 2007
Soon-Chang Yoon, Sang-Woo Kim, Jiyoung Kim, Byung-Ju Sohn, Anne Jefferson, Suk-Jin Choi, Dong-Hyun Cha, Dong-Kyou Lee, Theodore L. Anderson, Sarah J. Doherty and Rodney J. Weber
Enhanced water vapor in Asian dust layer: Entrainment processes and implication for aerosol optical properties
ATMOSPHERIC ENVIRONMENT 40 (13): 2409-2421 APR 2006Enhanced water vapor in Asian dust layer Entrainment processes and implication for aerosol optical properties.pdf
Synthesis of CaMoO4 nanoparticles by pulsed laser ablation in deionized water and optical properties.pdf
