1.G1310A 1200单元泵(可升降为四元泵) 1200 Isocratic pump includes isocratic pump,solvent cabinet solvent bottle and CAN cable 2.01018-68722 密封圈冲洗件 active seal wash option 3.G1316A 柱温箱 1200 thermostatted column compartment 4.G1329A 自动进样器 1200 series autosampler 5.G1314B 可变波长紫外检测器 1200 series variable wavelength det.1200 series sensitive,reliable and cost-effective variable wavelength detector. 6.G1314B/018 流量池 standard flow cell 7.G2170BA 软件 HPLC 2D chemstation software 32bit for data acquisition,control and evaluation of chromatographic data from one liquid chromatograph. 8.5182-0554 样品瓶 screw cap and amber vial kit 100/PK
