pp6600
第9楼2008/03/10
EN1103 这是我唯一可以想到的办法了,就是直接贴在这了,大家凑合着看吧:》
Foreword
This European Standard (EN 1103:2005) has been prepared by Technical Committee CEN/TC 248 “Textiles
and textile products”, the secretariat of which is held by BSI.
This European Standard shall be given the status of a national standard, either by publication of an identical
text or by endorsement, at the latest by June 2006, and conflicting national standards shall be withdrawn at
the latest by June 2006.
This European Standard supersedes EN 1103:1995.
According to the CEN/CENELEC Internal Regulations, the national standards organizations of the following
countries are bound to implement this European Standard: Austria, Belgium, Cyprus, Czech Republic,
Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Iceland, Ireland, Italy, Latvia, Lithuania,
Luxembourg, Malta, Netherlands, Norway, Poland, Portugal, Slovakia, Slovenia, Spain, Sweden, Switzerland
and United Kingdom.
pp6600
第10楼2008/03/10
This European Standard specifies a procedure to determine the burning behaviour of textiles for apparel –
other than protective clothing – before and after cleansing, when tested using the surface ignition test in
EN ISO 6941.
2 Normative references
The following referenced documents are indispensable for the application of this European Standard. For
dated references, only the edition cited applies. For undated references, the latest edition of the referenced
document (including any amendments) applies.
EN ISO 3175-2, Textiles — Dry-cleaning and finishing — Part 2: Procedure for tetrachloroethene (ISO 31752:
1998)
EN ISO 3175-3, Textiles — Professional care, drycleaning and wetcleaning of fabrics and garments — Part 3:
Procedure for testing performance when cleaning and finishing using hydrocarbon solvent (ISO 3175-3:2003)
EN ISO 3175-4, Textiles — Professional care, drycleaning and wetcleaning of fabrics and garments — Part 4:
Procedure for testing performance when cleaning and finishing using simulated wetcleaning (ISO 31754:
2003)
EN ISO 6330:2000, Textiles — Domestic washing and drying procedures for textile testing (ISO 6330:2000)
EN ISO 6941:2003, Textile fabrics — Burning behaviour — Measurement of flame spread properties of
vertically oriented specimens (ISO 6941:2003)
Materials without care labelling instructions shall be washed once in accordance with EN ISO 6330:2000,
procedure 6A at (40 ± 3) °C and dried in accordance with EN ISO 6330:2000, procedure E (tumble-drying).
Materials that may not be tumble-dried shall be dried in accordance with procedure A (line dry).
Materials which are labelled as "dry clean only" shall be dry-cleaned once in accordance with the appropriate
part of EN ISO 3175 as given in Clause 2.
The materials shall be washed once in accordance with the procedure of EN ISO 6330, corresponding to their
care labelling.
4 Cleansing (pre-conditioning)
material separating from the specimen during the test procedure, falling below the initial edge of the specimen
and igniting a filter paper
3.2
flaming debris
rapid spread of flame over the surface of a material without ignition of its basic structure, reaching the first
marker thread, which may or may not be severed, or either vertical edge of the test specimen
3.1
surface flash
For the purpose of this European Standard, the terms and definitions given in EN ISO 6941:2003 and the
following apply.
3 Terms and definitions
pp6600
第11楼2008/03/10
4
EN 1103:2005 (E)
NOTE This washing or dry cleaning procedure is not intended as a durability test for flame retardant treatments.
Conditioning
The dried test specimens and filter paper shall be conditioned for at least 24 h in the standard atmosphere of
(23 ± 2) °C and (50 ± 5) % relative humidity.
If the test is not to be carried out immediately after conditioning, the individual specimens and filter papers
shall be placed in sealed containers until the start of the test. Each specimen shall be tested within 3 min of
removing it from either the conditioning chamber or the sealed container.
Cut six specimens, representative for the fabric as manufactured, each 560 mm long and 170 mm wide. Three
with the longer dimensions in the length direction and three with the longer dimension in the width direction.
Number of specimens
Test specimens for clothing may consist of one or more layers of materials according to the construction of the
clothing. In this case the combination of materials as worn shall be tested.
Pre-testing shall be carried out as indicated in Clause 7.
The dimensions of the specimens for pre-testing shall be as indicated in 6.2. Both length and width direction
shall be tested.
Only the outer surface of the fabric, as worn in garment form, shall be tested. If the outer surface cannot be
identified only the surface which is shown by pre-testing to present a surface flash shall be tested. If surface
flash is not present on either surface, the surface that spreads flame at a higher rate shall be tested.
All materials or material combinations shall be tested both before and after the cleansing procedure as
indicated in Clause 4.
6
6.1
6.2
General
Test specimens
7
Test procedure
7.1 Carry out the test in accordance with the test procedure prescribed in EN ISO 6941:2003, 10.1 surface
ignition, with the following modifications and/or limitations:
. flame application time 10 s;
. commercial gas: propane;
. the first and the third marker thread shall be used.
7.2 Specimen preparation and mounting (for pile fabrics only)
hold the specimen at the short edge and raise the pile of the fabric by shaking the test specimen
once. This should be a sharp shake so the fabric cracks like a whip. This will ensure that all loose cut
loops are removed;
when tested in the length direction, position the specimen with the pile downward on the pin frame.
EN 1103:2005 (E)
EN 1103:2005 (E)
Position horizontally, below the test specimens, at a distance of (50 ± 5) mm from the lower edge of the
specimen, on a flat surface, a piece of filter paper, with the following characteristics:
. dimensions: at least 150 mm × 100 mm;
. mass per unit area: (80 ± 20) g/m2;
. thickness: (0,20 ± 0,05) mm;
. alpha-cellulose content: ≥ 95 %.
7.4
Measure and note for each specimen tested:
. the time in seconds from the start of the application of the igniting flame to the severance of the first
marker thread;
. the time in seconds from the start of the application of the igniting flame to the severance of the third
marker thread;
. if surface flash has occurred;
. if the filter paper ignites or not.
7.5 If the first or the first and the third marker threads are not severed, the after-flame time in seconds shall
be noted for each specimen.
pp6600
第12楼2008/03/10
Test report
The test report shall include the following information:
a)
reference to this European Standard;
b)
identification of the fabric tested;
c)
cleansing and drying procedure used;
d)
date of test;
e)
which surface was tested;
f)
for each test specimen (before and after cleansing) the information itemized in 7.4 and 7.5;
g)
if all the specimens burn: the mean flame spread time (in s) from the first marker thread to the third
marker thread for each direction;
h) any deviations from this procedure.
NOTE The method specified has been found to give poor repeatability and reproducibility when certain knitted fabrics
are tested. These knitted fabrics sag when mounted as specified in EN ISO 6941, making it difficult to hold the specimen
in a vertical plane and to control the distance from the burner to the specimen. If specimen sagging problems are
encountered they should be reported. (The specimen mounting technique may have to be modified and slight tension
applied to knitted specimens to hold them flat).
6
blank
blank
BS EN 1103:2005
BSI
389 Chiswick High Road
London
W4 4AL
BSI — British Standards Institution
BSI is the independent national body responsible for preparing
British Standards. It presents the UK view on standards in Europe and at the
international level. It is incorporated by Royal Charter.
Revisions
British Standards are updated by amendment or revision. Users of
British Standards should make sure that they possess the latest amendments or
editions.
It is the constant aim of BSI to improve the quality of our products and services.
We would be grateful if anyone finding an inaccuracy or ambiguity while using
this British Standard would inform the Secretary of the technical committee
responsible, the identity of which can be found on the inside front cover.
Tel: +44 (0)20 8996 9000. Fax: +44 (0)20 8996 7400.
BSI offers members an individual updating service called PLUS which ensures
that subscribers automatically receive the latest editions of standards.
Buying standards
Orders for all BSI, international and foreign standards publications should be
addressed to Customer Services. Tel: +44 (0)20 8996 9001.
Fax: +44 (0)20 8996 7001. Email: orders@bsi-global.com. Standards are also
available from the BSI website at http://www.bsi-global.com.
In response to orders for international standards, it is BSI policy to supply the
BSI implementation of those that have been published as British Standards,
unless otherwise requested.
