panyb15715 2008/02/28
111ok [img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=80074]An improved program for searching and matching of X-ray powder diffraction patterns[/url]
海之巅 2008/02/28
不过明天试一下EBSCO数据库,今天没有时间了,呵呵,不好意思! [img]https://ng1.17img.cn/bbsfiles/images/2008/02/200802281709_80064_1637963_3.jpg[/img]
大陆 2008/02/28
附件暂不能显示,不过别急,相信很快有路过的管理员验证我的附件。
海之巅
第1楼2008/02/28
1.
J. Appl. Cryst. (1983). 16, 150-154 [ doi:10.1107/S0021889883010146 ]
Lin Tian-Hui, Zhang Sai-Zhu, Chen Li-Jun and Cai Xin-Xing
Abstract: Two major improvements have been made in the present program: (1) a so-called `substance-type discrimination' has been introduced into the searching process, which can reduce missearching remarkably; (2) a new method for quantitative intensity matching has been proposed and can give reasonable results.
海之巅
第3楼2008/02/28
3.
Journal of Applied Crystallography
Volume 10 Issue 3 Page 147-150, June 1977
To cite this article: L. S Zevin (1977) A method of quantitative phase analysis without standards
Journal of Applied Crystallography 10 (3) , 147–150 doi:10.1107/S0021889877013144
Prev Article Next Article
Abstract
L. S.Zevin Abstract
It is shown that to determine the quantitative phase composition of n samples each of which contains n phases it is sufficient to obtain a set of n2 intensities values of analytical lines, Iij, where 1 ≤ i ≤ n is the phase number in a sample of number 1 ≤ j ≤ n. It is supposed that in every sample the complete phase composition is determined. To calculate concentrations in one sample a system of consisting of n linears equations was obtained: where s is the number of the sample, the mass absorption coefficient of the phase to be determined, x_is the weight fraction of the ith phase in the analysed sample. This system is modified if there are additional data on the samples, e.g. values of mass absorption coefficients. The use of this method excludes measurement of analytical line intensity in the pure phase or mixture of pure phases. Experimental verification of the method with two- and three-phase artificial mixtures gave satisfactory results. The necessary conditions for the application of this method are essential differences in the quantitative phase composition of the samples analysed.
海之巅
第5楼2008/02/28
2.
Volume 7 Issue 6 Page 519-525, December 1974
To cite this article: F. H Chung (1974) Quantitative interpretation of X-ray diffraction patterns of mixtures. I. Matrix-flushing method for quantitative multicomponent analysis
Journal of Applied Crystallography 7 (6) , 519–525 doi:10.1107/S0021889874010375
Abstract
F. H.Chung Abstract
A matrix-flushing method for quantitative multicomponent analysis by X-ray diffraction is reported. It is simpler and faster than, yet as reliable as, the conventional internal-standard method. In this new method, the calibration-curve procedure is shunted; a more fundamental `matrix-flushing' concept is introduced. The matrix-flushing theory gives an exact relationship between intensity and concentration free from matrix effect. Contrary to most theoretical methods the working equation is very simple, no complicated calculations are involved. The matrix-flushing theory and the analytical procedure are presented. Eight illustrative examples are drawn to demonstrate how this theory is applied to multicomponent analysis and amorphous-content determination. A novel `auto-flushing' phenomenon of binary systems was observed which appears to make the analysis of any binary system a simple matter.
This article is cited by:
A. Hein, P. M. Day, P. S. Quinn and V. Kilikoglou. (2004) The geochemical diversity of neogene clay deposits in Crete and its implications for provenance studies of Minoan pottery*. Archaeometry 46:3, 357–384
Abstract Abstract and References Full Text Article Full Article PDF
A. Sáez and L. Cabrera. (2002) Sedimentological and palaeohydrological responses to tectonics and climate in a small, closed, lacustrine system: Oligocene As Pontes Basin (Spain). Sedimentology 49:5, 1073–1094
Lia A. Stanciu, Joanna R. Groza, and Vladimir Y. Kodash,Maria Crisan and Maria Zaharescu. (2001) Electric-Field Effects on Sintering and Reaction to Form Aluminum Titanate from Binary Alumina–Titania Sol–Gel Powders. Journal of the American Ceramic Society 84:5, 983–985
Abstract Abstract and References Full Article PDF
Darko Makovec and Miha Drofenik Andrej Žnidaršič. (1999) Hydrothermal Synthesis of Manganese Zinc Ferrite Powders from Oxides. Journal of the American Ceramic Society 82:5, 1113–1120
Michele Dondi, Giampaolo Ercolani, Bruno Fabbri, and Marco Marsigli,. (1999) Chemical Composition of Melilite Formed during the Firing of Carbonate-Rich and Iron-Containing Ceramic Bodies. Journal of the American Ceramic Society 82:2, 465–468
Richard E. Chinn, Michael J. Haun, Chan Young Kim, and David B. Price. (1998) Low-Temperature Transient Glass-Phase Processing of Monoclinic SrAl2Si2O8. Journal of the American Ceramic Society 81:9, 2285–2293
Wen Zhu, C. K. Kuo, and Patrick S. Nicholson. (1997) Kinetics and Formation of the 110 K Phase in the Bismuth–Lead–Strontium–Calcium–Copper–Oxygen System. Journal of the American Ceramic Society 80:8, 1975–1980
P. ANADÓN and R. UTRILLA. (1993) Sedimentology and isotope geochemistry of lacustrine carbonates of the Oligocene Campins Basin, north-east Spain. Sedimentology 40:4, 699–720
E. K. Beauchamp and M. J. Carr. (1990) Kinetics of Phase Change in Explosively Shock-Treated Alumina. Journal of the American Ceramic Society 73:1, 49–53
B. MARTINEZ, F. PLANA. (1987) Quantitative X-Ray diffraction of carbonate sediments: mineralogical analysis through fitting of Lorentzian profiles to diffraction peaks. Sedimentology 34:1, 169–174
Dana L. Hankey and James V. Biggers. (1982) Effect of Packing Pressures and Particle Size Variations on the Reaction Kinetics for PbTiO3 and PbZrO3 Formation. Journal of the American Ceramic Society 65:5, c74–c76
