【求助】Thermogravimetric analysis of solid refuse-derived fuels and coal
  • 归林之鹰
    2008/03/06
文献检索-互助
  • 【作者】:Hathaway,S. A. ; Lin,J. S.
    【题名】:Thermogravimetric Analysis of Solid Refuse-Derived Fuels and Coal
    【期刊,年卷期】:MAR 1979
    【全文链接】:无
    谢谢大家了。
  • 海之巅
    第1楼2008/03/07
    Accession Number : ADA067829
    Title : Thermogravimetric Analysis of Solid Refuse-Derived Fuels and Coal.
    Descriptive Note : Technical rept.,
    Corporate Author : CONSTRUCTION ENGINEERING RESEARCH LAB (ARMY) CHAMPAIGN ILL
    Personal Author(s) : Hathaway,S. A. ; Lin,J. S.
    Report Date : MAR 1979
    Pagination or Media Count : 28
    Abstract : The ignition and combustion rates of three types of densified refuse-derived fuel (DRDF) and low-volatile Illinois bituminous coal were investigated at temperatures ranging from 600 C to 1000 C and residence times ranging up to 120 sec. It was found that DRDF ignition time is up to 12 times less than that of coal, that the temperature required for coal ignition at a given residence time is greater than that needed for DRDF ignition, and that the DRDF:coal time to ignition ratio is expressible as a linear function of furnace temperature. It was also found that DRDF produced from mixed municipal-residential solid waste has a slower combustion rate than that produced from homogeneous heavy paper stock, and that the combustion rates of all types of DRDF are significantly greater than that of the coal tested at a 99.9 percent level of confidence. (Author)
    Descriptors : *FUELS, *SOLID WASTES, *THERMOGRAVIMETRIC ANALYSIS, TEMPERATURE, EFFICIENCY, COMBUSTION, IGNITION, BURNING RATE, ENERGY CONSERVATION, SAVINGS, COAL.
    Subject Categories : PHYSICAL CHEMISTRY
    CIVIL ENGINEERING
    FUELS
    Distribution Statement : APPROVED FOR PUBLIC RELEASE
    只有摘要了
  • 归林之鹰
    第2楼2008/03/08
    谢谢楼上的朋友,79年的文献了,不好找了 不过还是希望能找到全文。
