LFV-20 LFV-50 LFV-100 LFV-200 LFV-500 LFV-1000 LFV-2000 最大动负荷(kN) 10、20 30、50 100 200 500 1000 2000 最大动扭矩(Nm) ±50;±100;±200;±500;±750;±1000;±1500; ±2000 最大振幅角 ±45° 静负荷误差 ±1%R.O.或±0.5%F.S. 试验频率 0.001—20(Hz) 试验波形 正弦波、三角波、矩形波、斜波、程序块波、随机波 主机重量 860kg 1350kg 1550kg 1860kg 2080kg 4080kg 7100kg 液压源 10l/min、30l/min、63l/min、160l/min、200l/min选配 Series LFV - T Upgrading the test system with torsional performance with customized torsional moment, angle and frequency range. Dynamic Biaxial Testing Systems The Series LFV-T can torsion loading be coupled with tension-compression. Both torsion and tension-compression can be loaded independently in phase or out of phase. With related accessories the LFV-T series of testing machines allows to perform a wide range of mixed-mode fatigue tests. Examples: Type LFV 100 kN - T 1'000 Nm Type LFV 600 kN - T 20’000 Nm Applications: Type LFV 5 kN - T 10 Nm for Testing of Implants in Salt .
