1.P. Castro-Borges and P. Helene Service Life of Reinforced Concrete Structures. New Approach 9-14 http://ecsdl.aip.org/getpdf/servlet/GetPDFServlet?filetype=pdf&id=ECSTF8000003000013000009000001&idtype=cvips&prog=normal
2.M. Prieto, A. Muñoz Noval and M. Andrade Perdrix Structural Assesment of Corroded Beams 15-28 http://ecsdl.aip.org/getpdf/servlet/GetPDFServlet?filetype=pdf&id=ECSTF8000003000013000015000001&idtype=cvips&prog=normal
3.A. Muñoz Noval, C. Andrade, A. Torres and J. Rodríguez Relation between Crack Width and Diameter of Rebar Loss Due to Corrosion of Reinforced Concrete Members 29-36 http://ecsdl.aip.org/getpdf/servlet/GetPDFServlet?filetype=pdf&id=ECSTF8000003000013000029000001&idtype=cvips&prog=normal
