学校图书馆关了 不太好查文献了 麻烦哪位兄台帮忙查点文献呵 谢谢了 [1] Shetty C S, Nikolov A D,Wasan DT.Demulsification of water in oil emulsions using water soluble demulsifiers[J].J Dispersion Sci Tech,1992,13(2):121-133.
[2] Bhardwaj A, Hartland S. Study of demulsification of water-in-crude oil emulsion [J]. J Dispersion Sci Tech, 1993, 14(5):541-547.
[3] Urdahl O,Sjoblom J. Water-in-crude oil emulsions from the Nownegian continental shelf A:stabilization and destabilization study[J]. J Dispersion Sci Tech, 1995, 16(7):557-574.
[4] Kirn Y H,Nikolov A D, Wasan D T, et a1. Demulsification of water in crude oil emulsions: effects of film tension, elasticity, diffusivity and interfacial activity of demulsifier individual components and their blends[J]. J Dispersion Sci Tech,1996,17(1):33-53.
[5] Mohammed R A, Beiley A I, Luckham P F, et a1. Dewatering of crude oil emulsions 3. Emulsion resolution by chemical means [J]. Colloids and Surfaces A: Physicochem Engng Aspects, 1994, 83:261- 271.
[6] Goldszal A, Bourrel M. Demulsification of crude oil emulsion:correlation to microemulsion phase behavior[J]. Ind Engng Chem Res,2000,39:2746-2751.
[7] Kim Y H, Wasan D T.Effect of demulsifier partitioning on the destabilization of water-in-oil emulsions[J]. Ind Engng Chem Res, 1996, 35:l14l-1149.
[8]Mark A K, Darsh T W, Chandrashekar S S. Chemical demulsification of petroleum emulsions using oil-soluble demulsifiers [J].Ind Engng Chem Res,1991,30:367-375.
[9] Klot J V,Schramm L L,Shelfantook B.Application of the hydrophilelipophile balance concept to the classification of demulsifiers and bituminous froth and its components [J]. Fuel Processing Tech,2002,75:9-26.
