文献检索-互助
dong3626
第1楼2008/07/30
1.Magnetic Behavior in Zinc Oxide Zigzag Nanoribbons
第2楼2008/07/30
2.Ni/Ni3C Core–Shell Nanochains and Its Magnetic Properties
第3楼2008/07/30
3.Fabrication of Nickel Hydroxide Microtubes with Micro- and Nano-Scale Composite Structure and Improving Electrochemical Performance
第4楼2008/07/30
4.Influence of Model Globular Proteins with Different Isoelectric Points on the Precipitation of Calcium Carbonate
第5楼2008/07/30
5.Synthesis and Evolution of PbS Nanocrystals through a Surfactant-Assisted Solvothermal Route
第6楼2008/07/30
6.PbS-Doped Mesostructured Silica Films with High Optical Nonlinearity
第7楼2008/07/30
7.Hierarchical, Star-Shaped PbS Crystals Formed by a Simple Solution Route
第8楼2008/07/30
8.Controlled Deposition of Oriented PbS Nanocrystals on Ultrathin Polydiacetylene Templates at the Air-Solution Interface
