sslin
第2楼2008/10/03
帮大家整理一下思绪.
分子式同, 但原子在空间的排列结构不同的就叫 "同分异构物" (isomer).
分成下面两大类/再各自 3 小类.
(1). 结构异构物 (structural isomer): 分子式同, 原子相连的次序异, 下分:
1. skeletal isomer (架构): 例如正丁烷/异丁烷
2. positional isomer (位置): 例如正丁醇/异丁醇 [涉及官能基的位置, NMR 很容易区分]
3. functional isomer (官能): 例如正丁醇/乙醚 [已是不同的化合物]
(2). 光学异构物 (stereo isomer), 分子式同, 原子相连的次序同, 空间排列异, 下分:
1. geometric isomer (几何): 例如顺丁烯二酸/反丁烯二酸 [常见的顺反异构物核磁判断, 可能得涉及 noe / hmbc 等精彩检测分析]
2. optical isomer (光学): enantiomer (对映体)/diastereomer (非对映体) [对映体给予手性环境形成非对映体可能判断, 涉及手性位移试剂/手性溶剂/手性衍生试剂等方法]
3. conformational isomer (枸象): 涉及 Newman projection 的skew/anti 等角度旋转 [能差极小, 一般不考虑此]
guowindy
第7楼2008/10/09
1: Magn Reson Chem. 2007 Apr;45(4):283-8.
Selective excitation of overlapping multiplets; the application of doubly selective and chemical shift filter experiments to complex NMR spectra.
Duncan SJ, Lewis R, Bernstein MA, Sandor P.
AstraZeneca R&D Charnwood, Loughborough, UK, UK. sara.duncan@astrazeneca.com
Standard 1D TOCSY and NOE experiments have limitations where signals are severely overlapped. Here, two recently published selective excitation methods are evaluated, the first of which uses a chemical shift selective filter to select a single resonance based on its chemical shift, and the second of which is a doubly selective experiment comprising a 1D TOCSY preparation step and subsequent 1D NOE. We also demonstrate the improvement in spectral quality obtained by the use of the zero quantum filter, which is incorporated into both of these experiments. The application of these different methods of selectively exciting overlapped multiplets, to different types of samples is considered.
找不到这篇的可看http://www.rsc.org/ej/OC/2008/b801271g.pdf 中的Fig1.
http://nmr.chem.ualberta.ca/nmr_news/2008-01.htm#new%201D%20techniques 中的new 1D techniques: CSSF 1D-TOCSY and CSSF 1D-NOESY
希望这篇文献和链接对你的问题,或遇到类似问题的各位有帮助。
