阳线
第4楼2008/11/15
ASTM D 695-02a Standard Test Method for Compressive Properties of Rigid Plastics
http://www.instrument.com.cn/bbs/download.asp?ID=76475
阳线
第5楼2008/11/16
ASTM D 696-03 Standard Test Method for Coefficient of Linear Thermal Expansion of Plastics Between -30℃ and 30℃ with a Vitreous Silica Dilatometer
http://www.instrument.com.cn/bbs/download.asp?ID=59444
ASTM D 2259-02 Standard Test Method for Shrinkage of Yarns
http://www.instrument.com.cn/bbs/download.asp?ID=118378
ASTM C 518-04 Standard Test Method for Steady-State Thermal Transmission Properties by Means of the Heat Flow Meter Apparatus
http://www.instrument.com.cn/bbs/download.asp?ID=118382
ASTM C 423-02a Standard Test Method for Sound Absorption and Sound Absorption Coefficients by the Reverberation Room MethodASTM C 423-02a
ASTM E 756-04 Standard Test Method for Measuring Vibration-Damping Properties of MaterialsASTM E 756-04
没有找到ASTM D 1716-1962(1974),不知道是否还存在或被其他取代?
ASTM D 1716-62(R74) 试验方法标准 硝酸纤维素分级沉淀法测定纤维素链长均匀度
