funkite
第5楼2009/01/03
手边刚好有些相关数据,仅供参考,一般普通高倍显微镜用的
• Indoor use.
• Altitude: Max. 2000 meters
• Ambient temperature: 5° to 40°C (41° to 104° F)
• Maximum relative humidity: 80% for temperatures up to 31°C (88°F), decreasing linearly
through 70% at 34°C (93°F), 60% at 37°C (99°F), to 50% relative humidity at 40°C (104°F).
另一个量测显微镜数据则为下:
Operating environment should be of room temperature of 10∼30 °C and humidity of 30∼70%.
Measuring environment should be of room temperature of 17∼26 °C with temperature change of ±1 °C and humidity of 40∼60%.
Storage environment should be of room temperature of -5∼40 °C and humidity of 10∼80%. (However, no drew is allowed).
