LiveBandit
第3楼2009/01/13
Analysis of Naphtha
Introduction
Naphtha is commonly used as a fuel in gas turbines. The presence of certain elements, such as
Ca, Pb, V and the alkali elements, can cause the formation of hard deposits which significantly
shorten the lifetime of the turbines. The detection limit capability of an axial plasma is an excellent
match for the requirements of this analysis.
Elements
Ag, Al, As, B, Ba, Ca, Cr, Cu, Fe, K, Mg, Mn, Mo, Na, Ni, Na, Ni, P, Pb, Se, Si, Sn, Ti, V, Zn
Instrumentation
Leeman Labs Prodigy High Dispersion ICP
• State-of-The-Art, Large Format, Programmable
Array Detector (L-PAD)
• Long Focal Length Optical System
• Temperature Controlled Optical System
• Image-Stabilized ICP Source
• Computer Controlled Source Mirror
• Operator Selectable Input Slit
• Axial, Radial or Dual View
Conclusion
The Teledyne Leeman Labs Prodigy ICP is able to provide direct analysis of highly volatile organic
solvents, such as naphtha. Because of the robust plasma generated by the free-running 40.68 MHz
generator, no dilution of the solvent is necessary. As a result, excellent detection limits are achieved,
minimal sample preparation is required and sample throughput is maximized.
