ASTM E10-01 ASTM E92-03 ASTM E384-99 ASTM E18-05 ISO 14577-1/02
UMT上运行的微观和钠观硬度测试
ASTM D 2240-00 Test Method for Measuring the Durometer of Soft Materials Using the UMT
ASTM D 2509–03
Measurement of Load-Carrying Capacity of Lubricating Grease Using Macro-Tribometer mod. UMT-3
ASTM D 2981-94 (reapproved 1998) and ASTM D 3704-96 (reapproved 2001) 使用微米摩擦测试仪模块UMT进行的的块-震动环测试
ASTM D3702-94 (Reapproved 1999)
使用微米摩擦测试仪UMT-2进行的自润滑滑动接点和推力垫圈下材料的磨损率和摩擦系数的标准测试
ASTM D 5706–97 (Reapproved 2002) Standard Test Method for Determining Extreme Pressure Properties of Lubricating Greases using the UMT-3 in a High Frequency, Linear Reciprocating configuration
ASTM D 6078–99 Standard Test Method for Evaluating Lubricity of Diesel Fuels using the UMT in a ball-on-cylinder configuration
ASTM D 6079-02
Standard Test Method for Evaluating Lubricity of Diesel Fuels using the UMT in a Fast Reciprocating configuration
