我在故我思 2009/04/10
[B]楼主,你好!以下是全部的油墨国家现行标准,如果有您需要,可以在论坛求助,看看是否能有全文。[/B] 1 GB/T 15962-2008 油墨术语 Glossary of printing ink terms 现行 2009-05-01实施,代替GB/T 15962-1995 2 GB/T 18724-2008 印刷技术 印刷品与印刷油墨耐各种试剂性的测定 Graphic technology - Prints and printing inks - Assessment of resistance to various agents 现行 2009-09-01实施,代替GB/T 18724-2002 3 GB/T 22770-2008 印刷技术 用落棒式粘度计测定浆状油墨和连接料的流变性 Graphic technology - Determination of rheological properties of paste inks and vehicles by the falling rod viscometer 现行 2009-09-01实施 4 GB/T 22771-2008 印刷技术 印刷品与印刷油墨用滤光氙弧灯评定耐光性 Graphic technology - Prints and printing inks - Assessment of light fastness using filtered xenon arc light 现行 2009-09-01实施 5 GB/T 6753.1-2007 色漆、清漆和印刷油墨 研磨细度的测定 Paints 、varnishes and printing inks - Determination of fineness of grind 现行 2008-04-01实施,代替GB/T 6753.1-1986 6 GB/T 12911-1991 纸和纸板油墨吸收性的测定法 Paper and board--Determination of the ink absor-bency 现行 1992-03-01实施 7 GB/T 13217.1-1991 凹版塑料油墨检验方法 颜色检验 Test method for colour of plastics gravure printing inks 现行 1992-08-01实施 8 GB/T 13217.2-1991 凹版塑料油墨检验方法 光泽检验 Test method for gloss of plastics gravure printing inks 现行 1992-08-01实施 9 GB/T 13217.3-1991 凹版塑料油墨检验方法 细度检验 Test method for fineness of grind of plastics gravure printing inks 现行 1992-08-01实施 10 GB/T 13217.3-2008 液体油墨细度检验方法 Test method for fineness of grind of liquid ink 现行 2009-09-01实施 11 GB/T 13217.4-1991 凹版塑料油墨检验方法 粘度检验 Test method for viscosity of plastics gravure printing inks 现行 1992-08-01实施 12 GB/T 13217.4-2008 液体油墨粘度检验方法 Test method for viscosity of liquid ink 现行 2009-09-01实施 13 GB/T 13217.5-1991 凹版塑料油墨检验方法 初干性检验 Test method for initial dryness of plastics gravure printing inks 现行 1992-08-01实施 14 GB/T 13217.5-2008 液体油墨初干性检验方法 Test method for initial dryness of liquid ink 现行 2009-09-01实施 15 GB/T 13217.6-1991 凹版塑料油墨检验方法 着色力检验 Test method for relative tinting strength of plastics gravure printing inks 现行 1992-08-01实施 16 GB/T 13217.6-2008 液体油墨着色力检验方法 Test method for relative tinting strength of liquid ink 现行 2009-09-01实施 17 GB/T 13217.7-1991 凹版塑料油墨检验方法 附着牢度检验 Test method for adhesion to substrate of plastics gravure printing inks with tape 现行 1992-08-01实施 18 GB/T 13217.8-1991 凹版塑料油墨检验方法 抗粘连检验 Test method for blocking resistance of plastics gravure printing inks 现行 1992-08-01实施 19 GB/T 14624.1-1993 油墨颜色检验方法 Test method for colour of printing inks 现行 1994-05-01实施 20 GB/T 14624.2-1993 油墨着色力检验方法 Test method for colour strength of printing inks 现行 1994-05-01实施 21 GB/T 14624.2-2008 胶印油墨着色力检验方法 Test method for colour strength of offset ink 现行 2009-09-01实施 22 GB/T 14624.3-1993 油墨流动度检验方法 Test method for fluidity of printing inks 现行 1994-05-01实施 23 GB/T 14624.3-2008 胶印油墨流动度检验方法 Test method for fluidity of offset ink 现行 2009-09-01实施 24 GB/T 14624.4-1993 油墨结膜干燥检验方法 Test method for drying time of film formation of printing inks 现行 1994-05-01实施 25 GB/T 14624.4-2008 胶印油墨结膜干燥检验方法 Test method for drying time of film formation of offset ink 现行 2009-09-01实施 26 GB/T 14624.5-1993 油墨粘性检验方法 Test method for tack of printing inks 现行 1994-05-01实施 27 GB/T 14624.6-1993 油墨粘性增值检验方法 Test method for increase in value of tack of printing inks 现行 1994-05-01实施 28 GB/T 15962-1995 油墨术语 Glossary of printing ink terms 现行 1996-12-01实施 29 GB/T 17001.1-1997 防伪油墨 第一部分:紫外激发荧光油墨(胶版、凸版印刷)技术条件 Anti-counterfeiting ink--Part 1:Technical requirement of ultraviolet fluorescent ink 现行 1998-05-01实施 30 GB/T 17934.3-2003 印刷技术 网目调分色片、样张和印刷成品的加工过程控制 第3部分: 新闻纸的冷固型油墨胶印 Graphic technology--Process control for the manufacture of half-tone colour separations,proofs and production prints--Part 3: Coldset offsetlithography on newsprints 现行 2003-12-01实施,代替GB/T 14705-1993 31 GB/T 18723-2002 印刷技术 用黏性仪测定浆状油墨和连接料的黏性 Graphic technology--Determination of tack of paste inks and vehicles by a rotary tackmeter 现行 2003-01-01实施 32 GB/T 18724-2002 印刷技术 印刷品及印刷油墨的耐酸性测定 Graphic technology--Prints and printing inks--Determination of resistance of prints to acids 现行 2003-01-01实施 33 GB/T 18751-2002 磁性防伪油墨 Magnetic anti-counterfeiting printing ink 现行 2003-01-01实施 34 GB/T 18752-2002 热敏变色防伪油墨 Heating color variable printing ink 现行 2003-01-01实施 35 GB/T 18753-2002 日光激发变色防伪油墨 Sunlight excitation color variable printing ink 现行 2003-01-01实施 36 GB/T 18754-2002 凹版印刷紫外激发荧光防伪油墨 UV-excitation fluorecent anti-counterfeiting intaglio printing ink 现行 2003-01-01实施 37 GB/T 20216-2006 有效残余油墨的测定 Determination of effective residual ink 现行 2006-10-01实施 38 GB/T 22467.2-2008 防伪材料通用技术条件 第2部分:防伪油墨和印油 Universal technical requirements of anti-counterfeiting material - Part 2: Anti-counterfeiting printing inks and anti-counterfeiting stamp inks
樱桃小丸子 2009/04/10
楼主想要哪类的油墨标准啊?好多类的
我在故我思
第3楼2009/04/10
