learner1999
第4楼2009/05/21
源自于下面:
NON-LATEX USERS: Editable source files must be uploaded at this stage. Tables must be on separate pages after the reference list, and not be incorporated into the main text. Figures should be uploaded as separate figure files.
LATEX USERS: For reviewing purposes you should upload a single .pdf that you have generated from your source files. You must use the File Designation "Main Document" from the dropdown box.
何当奇
第5楼2009/05/25
那感觉应该就是我看到的那种
