核桃
第1楼2009/05/27
BILL NUMBER: AB 1953 CHAPTERED
BILL TEXT
CHAPTER 853
FILED WITH SECRETARY OF STATE SEPTEMBER 30, 2006
APPROVED BY GOVERNOR SEPTEMBER 30, 2006
PASSED THE ASSEMBLY AUGUST 30, 2006
PASSED THE SENATE AUGUST 29, 2006
AMENDED IN SENATE AUGUST 28, 2006
AMENDED IN SENATE JUNE 14, 2006
AMENDED IN ASSEMBLY MAY 25, 2006
AMENDED IN ASSEMBLY MAY 1, 2006
AMENDED IN ASSEMBLY MARCH 15, 2006
INTRODUCED BY Assembly Member Chan
(Coauthors: Assembly Members Koretz and Lieber)
(Coauthor: Senator Kuehl)
FEBRUARY 2, 2006
An act to amend, repeal, and add Section 116875 of the Health and
Safety Code, relating to lead plumbing.
LEGISLATIVE COUNSEL'S DIGEST
AB 1953, Chan Lead plumbing.
Existing law prohibits the use of any pipe, pipe or plumbing
fitting or fixture, solder, or flux that is not lead free in the
installation or repair of any public water system or any plumbing in
a facility providing water for human consumption, except as
specified.
Existing law prohibits the introduction into commerce of any pipe,
pipe or plumbing fitting, or fixture that is not lead free, except
for a pipe that is used in manufacturing or industrial processing.
This bill would, commencing on January 1, 2010, revise this
prohibition to apply to any pipe or plumbing fitting, or fixture
intended to convey or dispense water for human consumption, but would
exclude from this prohibition specified devices.
Existing law defines lead free as not more than 8% lead when used
with respect to pipes and fittings and not more than 4% by dry weight
with respect to plumbing fittings and fixtures.
This bill would, commencing on January 1, 2010, revise the term
"lead free," for purposes of manufacturing, industrial processing,
and conveying or dispensing water for human consumption, to refer not
to the lead content of pipes and pipe fittings, plumbing fittings,
and fixtures but to a weighted average lead content of the wetted
surface area of the pipes, fittings, and fixtures of not more than
0.25%, to be determined pursuant to a prescribed formula.
Existing law requires the State Department of Health Services to
adopt building standards to implement the above prohibitions.
Appropriate state and local building and health officials are
required to enforce these standards.
By increasing the duties of local officials, this bill would
impose a state-mandated local program.
The California Constitution requires the state to reimburse local
agencies and school districts for certain costs mandated by the
state. Statutory provisions establish procedures for making that
reimbursement.
This bill would provide that, if the Commission on State Mandates
determines that the bill contains costs mandated by the state,
reimbursement for those costs shall be made pursuant to these
statutory provisions.
核桃
第2楼2009/05/27
THE PEOPLE OF THE STATE OF CALIFORNIA DO ENACT AS FOLLOWS:
SECTION 1. Section 116875 of the Health and Safety Code is amended
to read:
116875. (a) No person shall use any pipe, pipe or plumbing
a facility providing water for human consumption, except when
necessary for the repair of leaded joints of cast iron pipes.
(b) No person shall introduce into commerce any pipe, pipe or
plumbing fitting, or fixture, that is not lead free, except for a
(c) No person engaged in the business of selling plumbing
supplies, except manufacturers, shall sell solder or flux that is not
lead free.
(d) No person shall introduce into commerce any solder or flux
that is not lead free unless the solder or flux bears a prominent
label stating that it is illegal to use the solder or flux in the
installation or repair of any plumbing providing water for human
consumption.
(e) For the purposes of this section, "lead free" means not more
than 0.2 percent lead when used with respect to solder and flux and
not more than 8 percent when used with respect to pipes and pipe
fittings. With respect to plumbing fittings and fixtures, "lead free"
means not more than 4 percent by dry weight after August 6, 2002,
unless the department has adopted a standard, based on health
effects, for the leaching of lead.
(f) This section shall remain in effect only until January 1, 2010,
and as of that date is repealed, unless a later enacted statute,
that is enacted before January 1, 2010, deletes or extends that date.
SEC. 2. Section 116875 is added to the Health and Safety Code, to
read:
(b) (1) No person shall introduce into commerceany pipe, pipe or
plumbing fitting, or fixture intended to convey or dispense water for
human consumption through drinking or cooking that is not lead free,
as defined in subdivision (e). This includes kitchen faucets,
bathroom faucets, and any other end-use devices intended to convey or
dispense water for human consumption through drinking or cooking,
but excludes service saddles, backflow preventers for nonpotable
services such as irrigation and industrial, and water distribution
main gate valves that are two inches in diameter and above.
(2) Pipes, pipe or plumbing fittings, or fixtures that are used in
manufacturing, industrial processing, for irrigation purposes, and
any other uses where the water is not intended for human consumption
through drinking or cooking are not subject to the requirements of
paragraph (1).
(3) For all purposes other than manufacturing, industrial
processing, or to convey or dispense water for human consumption,
"lead free" is defined in subdivision (f).
lead free.
consumption.
not more than a weighted average of 0.25 percent when used with
respect to the wetted surfaces of pipes and pipe fittings, plumbing
fittings, and fixtures. The weighted average lead content of a pipe
and pipe fitting, plumbing fitting, and fixture shall be calculated
by using the following formula: The percentage of lead content within
each component that comes into contact with water shall be
multiplied by the percent of the total wetted surface of the entire
pipe and pipe fitting, plumbing fitting, or fixture represented in
each component containing lead. These percentages shall be added and
the sum shall constitute the weighted average lead content of the
pipe and pipe fitting, plumbing fitting, or fixture.
(f) For the purposes of paragraph (3) of subdivision (b), "lead
free," consistent with the requirements of federal law, means not
more than 0.2 percent lead when used with respect to solder and flux
and not more than 8 percent when used with respect to pipes and pipe
(g) This section shall become operative on January 1, 2010.
SEC. 3. If the Commission on State Mandates determines that this
act contains costs mandated by the state, reimbursement to local
agencies and school districts for those costs shall be made pursuant
to Part 7 (commencing with Section 17500) of Division 4 of Title 2 of
the Government Code.
beake_huang
第11楼2010/01/18
需要标准的朋友,请来涵索取!联系方式如下:
www.global-cert.org
厦门博测商务服务有限公司
Xiamen Botest Business Services Co., Ltd.
黄水龙/Buick Huang M.B.: 13696922466
Tel: 86-592-5522220 Fax: 86-592-5596933
中国福建省厦门市湖里区马垄路17号B903室
QQ: 909203163 MSN: buick.huang@hotmail.com
E-mail: buick.huang@hotmail.com;buick.huang@global-cert.org
Room B903, No.17, Malong Road, Huli District, Xiamen, Fujian, China
水暖卫浴&洁具&阀门&建筑五金产品认证;机械产品认证;消防及安防产品认证;磨料磨具认证;
CNAS认可咨询;CE,CB,UL,CSA,ETL,PSE,VCCI,SAA,C-Tick,GS,GOST,CCC,SRRC,RoHS,Energy
Star,etc;性能;可靠性;ISTA等测试及认证业务.
