celan
第1楼2009/06/05
1 GHz NMR Spectrometer
Bruker BioSpin launches a breakthrough one Gigahertz (1 GHz = 1,000 MHz) Ultra-High field AVANCE™ 1000 MHz NMR spectrometer. It incorporates the world’s first 23.5 Tesla standard-bore (54 mm) superconducting NMR magnet.
After many years of development, Bruker BioSpin has successfully energized and brought to its full magnetic field of 23.5 Tesla the world’s first, standard-bore, high homogeneity 1 GHz NMR persistent magnet. The high field strength and high field stability in combination with the first 5mm triple-resonance CryoProbe™ enables unique 1 GHz NMR applications. The 1 GHz NMR spectra demonstrate the enormous capabilities of this new high-end AVANCE 1000 instrument, which can be beneficial for all UHF high-resolution and solid-state NMR experiments.
This highest field strength 23.5 Tesla NMR magnet highlights a series of our new technology developments and Bruker is proud to be able to provide such an outstanding instrument to NMR researchers who wish to push the frontiers in biochemistry, structural biology and other molecular research.
