第3楼2005/07/25
药物设计中的生物核磁共振技术
中国药科大学学报2004 Vol.35 No.5 P.387-392
核磁共振技术在方法学和硬件上的迅速发展,使其成为化学和结构生物学中最重要的波谱技术.特别是生物核磁共振技术在药物研发过程中,提供从药物设计结构信息到基于NMR技术进行配体的筛选的广泛应用,使得生物核磁共振技术在药物研究领域地位不断加强,成为药物研究的基础工具.本文综述了生物核磁共振技术在药物设计中的方法与应用
参考文献:
[1]Shuker SB,Hajduk PJ,Meadows RP,et al.Discovering high-affinity ligands for proteins:SAR by NMR[J].Science,1996,274(5292):1531-1536.
[2]Gargaro AR,Soteriou A,Frenkiel TA,et al.The solution structure of the complex of Lactobacillus casei dihydrofolate reductase with methotrexate[J].J Mol Biol,1998,277(1):119-134.
[3]Wlodawer A,Vondrasek J.Inhibitors of HIV-1 protease:a major success of structre-assisted drug design[J].Annu Rev Biophys Biomol Struct,1998,27:249-284.
[4]Stockmana BJ,Dalvit C.NMR screening techniques in drug discovery and drug design[J].Progress in Nuclear Magnetic Resonance Spectroscopy,2002,41:187-231.
[5]Bjerring M,Vosegaard T,Malmendal A,et al.Methodological development of solid-state NMR for characterization of membrane proteins[J].Concepts in Magnetic Resonance Part A,2003,18A(2):111-129.
[6]Bak M,Schultz R,Nielsen NC.Numerical simulations for experiment design and extraction of structural parameters in biological solid-state NMR spectroscopy.In:Kiihne SR,de Groot HJM,eds.Perspectives on Solid-State NMR in Biology.Dordrecht.Holland:Kluwer Academic Publishers,2001.95-109.
[7]Pochapsky SS,Pochapsky TC.Nuclear magnetic resonance as a tool in drug discovery,metabolism and disposition[J].Current Topics in Medicinal Chemistry,2001,1(5):427-441.
[8]Jardetzky O.Protein dynamics and conformational transitions in allosteric proteins[J].Prog Biophys Mol Biol,1996,65(3):171-218.
[9]Nieto PM,Birdsall B,Morgan WD.Frenkiel TA:correlated bond rotations in interactions of arginine residues with ligand carboxylate groups in protein ligand complexes[J].FEBS Lett,1977,405(1):16-20.
[10]Mark G,Echols N.Exploring the range of protein flexibility,from a structural proteomics perspective[J].Current Opinion in Chemical Biology,2004,8(1):14-19.
[11]Kay LE.Correlation between binding and dynamics at SH2 domain interfaces[J].Nat Struct Boil,1998,5:156-163.
[12]Ben Davis1,Mohammad Afshar1,Gabriele Varani.Rational design of inhibitors of HIV-1 TAR RNA through the stabilisation of electrostatic "hot spots"[J].J Mol Biol,2004,336(2):343-356.
[13]Gordon CK,Roberts.Applications of NMR in drug discovery[J].DDT,2000,5(6):230-240.
[14]Murray Coles,Heller M,Kessler H.NMR-based screening technologies[J].DDT,2003,8(17):803-810.
[15]Christopher A.Lepre,library design for NMR-based screening[J].DDT,2001,6(3):133-140.
[16]Maria van Dongen,Weigelt J.Structure-based screening and design in drug discovery[J].DDT,2002,7(8):471-478.
第5楼2005/07/25
The Application of NMR Prediction Algorithms to Developing Screening Sets for SAR by NMR
Abstract
SAR by NMR is fast becoming a general approach to identifying possible hits by utilizing NMR experimentation to monitor the binding of a small molecule to a protein. The general approach is to mix together a soup containing a target protein used for screening and a number of possible active pharmaceutical agents. Those moieties which bind to the protein have different diffusion dynamics and the resulting NMR spectra will exhibit the absence of resonances for the complexed molecules. The odious task of identifying the complexing molecule(s) generally requires visual interrogation. The comparison of the spectra of the individual mixture components are compared with the spectrum of the mixture after diffusion editing. This comparison process will allow the identification of those resonances in the individual materials which have been nulled in the mixture spectrum, thereby allowing identification of the binding species. With the intention to perform measurements on many mixtures in an automated fashion, once again the challenge is no longer the data acquisition. Experimental design is crucial to ensure that there is minimum overlap between the spectra for each of the mixture components. We will describe how NMR prediction algorithms can be used to optimize the experimental design process and introduce visualization tools which can dramatically aid the analysis process.
第9楼2005/07/28
新型天然活性成分构效关系研究取得新进展
由昆明植物所郝小江研究员主持的国家基金重点项目“新型天然活性成分构效关系研究”,最近由国家基金委组织进行了验收。项目经近4年的努力工作,取得了新的进展和突破。
该项研究对三类活性物质的构效关系进行了系统研究,总结了取代吡咯烷酮、二萜醌取代基分别对钙拮抗、抗肿瘤活性影响的规律;发现了高活性的三取代吡咯烷酮衍生物以及新的拓扑异构酶Ⅰ抑制剂;应用计算机辅助设计建立了结构优化模型,扩大了知识产权保护范围,为设计和研发同系列新药提供了理论依据。
项目构建了系列突变体,结合DNA合成及信号分子激活等功能分析,发现肝细胞生成素刺激细胞增殖的活性依赖其结构的完整性;克隆了一种新形式肝细胞生成素,具有较强刺激肝细胞增殖、活化信号分子的作用。在肝细胞生成素作用机制研究中发现肝细胞生成素可与JABI结合调控API活性,从而确定肝细胞生成素具有胞内信号途径。具有重要的理论意义。
上述研究以自主创新药物为基础,结合化学合成—生物活性—计算机辅助设计的现代研究模式,是开展具有我国自主知识产权创新药物发现阶段研究的成功模式。该项目是高起点结合现代构效关系研究体系开展的一项既有带动性、又有很强的应用前景的研究课题。项目在原有的基础上获得了新的突破,分别在化学结构与功能、新的活性物质、新的生物活性、新作用机制、计算机辅助设计分子模型方面具有创新性,并具有较高的学术价值,其学术水平已达到国际同类研究的先进水平。
第10楼2005/07/28
重要生理活性的天然产物的合成和构效关系研究;(主要研究者:秦东光、文石军、查慧艳)
1998年,日本科学家Umezawa等在微生物发酵液中获得两种新的化合物polyoxypeptin A和B,它们的特殊性就是能够诱导胰腺癌细胞AsPC-1的凋亡,对比实验效果明显。为了满足更多研究工作的需求,建立一条高效的化学合成途径成为必要的手段。通过合理运用对映控制的不对称反应,我们可以获得分子中所有非常见的氨基酸单体,以及具有多个手性中心的酰基边链。在获得所有结构单元的基础上,我们计划运用现代固相合成技术,将这些单元加以组装,最终获得所需的天然化合物。这样的合成方法还可用于结构类似物等的平行合成,为构效关系研究创造可能。抗炎药是另一重要的领域,近年来化学界对海洋微生物的研究收获颇丰。年美国科学家Clardy在加里福尼亚海岸发现三个新的化合物Cyclomarins A,B,C,在体外和体内实验中均显示极好的抗炎活性,是目前遇见的最强有效的抗热带炎症化合物。这些化合物中同样带有数个非常见氨基酸。由于资源的限制,合成这些化合物将显得日益重要。我们计划利用不对称合成方法,获得更多的样品以及更多的衍生物、类似物等。这一研究课题长远的设想是期望合作研究并破译细菌中催化生产这些化合物的酶的基因, 并在廉价的表达系统中得以实施。目前的化学工作将为将来的发展作物质准备。
http://202.127.145.69/jgset/shengm/yzj3.htm
