sifu
第4楼2009/09/14
比如:The cylinder wall shall be examined using UE transducers capable of detecting the specified calibration
notches. The examination shall cover longitudinal defects in both circumferential directions (clockwise and
anti-clockwise) and transverse defects in both longitudinal directions (forward and backward) and consider
these defects to be located on the internal and external surfaces.
还有有的图示中出现了UE signal trace from calibration specimen wall
