肖筱 2009/09/15
Atomic Absorption Spectrophotometer examples of the periodic verification (Jinhu County, Jiangsu Province, environmental monitoring 211600) Abstract: Periodic verification is simple to use and with considerable credibility of the method, can result in equipment failure of the measuring equipment or reference standards, benchmarks, transmission standards or working standards and standard substances (reference material) in some of the parameters in the the two adjacent periodic verification / calibration time interval between checks to determine whether the facilities maintained when the calibration or test the accuracy of testing and calibration to ensure the quality of the results, and to detect and correct equipment due to drift , aging, damage, sample contamination, and other unknown causes inaccurate to ensure that equipment in use during the period remained in good condition, To maintain the credibility of test results. I have read a lot of information and documentation after the unit conducted an atomic absorption spectrophotometer during the verification result is that the indicators are in line with the standard. Keywords: Atomic absorption, periodic verification
nikkyz888 2009/09/15
上专门的免费翻译网站呀,当然语法上自己是要修改下的
chemistryren 2009/09/15
谷哥有翻译功能,单需要自己组织。
vanvan 2009/09/15
四楼的貌似比较强
wang1019009 2009/09/16
文章比较长 还需要专业词汇才行 有点难
肖筱
第4楼2009/09/15
名字长了容易引起注意
第5楼2009/09/15
太强大了,虽然我一句都看不懂
