【求助】汽车内饰气味实验用的1L的玻璃瓶哪有卖的?
国外标准
  • 悬赏金额:15积分状态:未解决
  • 请见以下标准:
    GMW 3205
    3 Test Equipment
    3.2 One (1) test container is required for each coding plus a control container. The test container, lid and rack must not release or absorb any odorous volatiles. Only containers and lids of glass shall be permitted. The lid shall be sealed by means of a plain ground joint. Sealing grease or sealing rings shall not be used.
    Any necessary support shelves or racks within the container shall be made of glass or glazed ceramics. The use of suitable sized desiccators is recommended. The lid must form a vapor seal with the container.
    The test container including lid and possibly the insert shall be cleaned carefully prior to each test. It shall have no individual smell.
    欲做此气味实验,但是这种瓶子应该是专用的,不过市场上找不到相关产品,请问哪里可以买得到呢?
  • wangada
    第1楼2010/07/17
    我们也是新开的,也想问问
