仙豆
第1楼2010/02/22
ANSI/ASTM E424-2002 片材的太阳能量传输性和反射性(陆地上)的试验方法(Test Methods for Solar Energy Transmittance and Reflectance (Terrestrial) of Sheet Materials )
ANSI/ASAE S 423-1993 太阳能环境加热器的热性能试验(Thermal Performance Testing of Solar Ambient Air Heaters)
ANSI/ASHRAE 109-1986 测定含有沸液的平板太阳能收集器的热性能的测试方法(Methods of Testing to Determine the Thermal Performance of Flat Plate Solar Collectors Containing a Boiling Liquid)
ANSI/ASHRAE 93-1986 测定太阳能采集器热性能的试验方法(Solar Collectors, Method of Testing to Determine the Thermal Performance of)
ANSI/ASHRAE 96-1980 测定无釉平板液体型太阳能收集器的热性能的试验方法(Unglazed, Flat-Plate, Liquid-Type Solar Collectors, Methods of Testing to Determine Thermal Performance of)
仙豆
第2楼2010/02/22
ASTM D 3667-1985 平板太阳能集热器用橡胶密封件(Rubber Seals Used in Flat-Plate Solar Collectors)
ASTM D 3771-2003 聚集型太阳能加热器用橡胶密封件的标准规范(Standard Specification for Rubber Seals Used in Concentrating Solar Collectors)
ASTM D 3832-1979 太阳能系统中同液体接触的橡胶密封件规格(Rubber Seals Contacting Liquids in Solar Energy Systems)
ASTM D 3903-2003 太阳能系统的热空气传递用橡胶密封件的标准规范(Standard Specification for Rubber Seals Used in Air-Heat Transport of Solar Energy Systems)
ASTM D 3952-1987 太阳能系统用橡胶软管(Rubber Hose Used in Solar Energy Systems)
ASTM E 1056-1985 一家和两家住房用太阳能家用热水设备的安装和维护(Installation and Service of Solar Domestic Water Heating Systems for One- and Two-Family Dwellings)
ASTM E 1084-1986 用阳光测试薄板材料的太阳能传递性(地面上)的试验方法(Test Method for Solar Transmittance (Terrestrial) of Sheet Materials Using Sunlight)
ASTM E 1089-1986 均匀的静气压差下平板太阳能收集器的透水性的试验方法(Test Method for Water Penetration of Flat Plate Solar Collectors by Uniform Static Air Pressure Difference)
ASTM E 1160-1987 太阳能家用热水系统的现场检查和操作验证(On-Site Inspection and Verification of Operation of Solar Domestic Hot Water Systems)
ASTM E 1175-1987 用大直经积分球测定材料的太阳能或光反射性,透明性和吸收性的试验方法(Test Method for Determining Solar or Photopic Reflectance, Transmittance and Absorptance of Materials Using a Large Diameter Integrating Sphere)
ASTM E 1328-2003 与光电太阳能转换相关的标准术语(Standard Terminology Relating to Photovoltaic Solar Energy Conversion)
ASTM E 424-1971 簿板材料的太阳能传播和反射的试验方法(Test Methods for Solar Energy Transmittance and Reflectance (Terrestrial) of Sheet Materials)
ASTM E 490a-2000 标准太阳能常数和气团起始阳光能光谱辐照表(Standard Solar Constant and Zero Air Mass Solar Spectral Irradiance Tables)
ASTM E 683-1991 一家和两家住房用太阳能空间加热系统的安装和维护(Installation and Service of Solar Space Heating Systems for One- and Two-Family Dwellings)
ASTM E 712-1980 太阳能加热和制冷系统中贮存液体用金属容器材料的实验室遮蔽(Laboratory Screening of Metallic Containment Materials for Use with Liquids in Solar Heating and Cooling Systems)
ASTM E 744-1985 加热设备用太阳能吸收材料的评定(Evaluating Solar Absorptive Materials for Thermal Applications)
ASTM E 745-1980 太阳能加热和制冷系统中用传热液体的金属容器材料的腐蚀模拟维护试验(Simulated Service Testing for Corrosion of Metallic Containment Materials for Use with Heat-Transfer Fluids in Solar Heating and Cooling Systems)
ASTM E 772-1987 有关太阳能转换的标准术语(Standard Terminology Relating to Solar Energy Conversion)
ASTM E 781-1986 暴露在有盖板的太阳能收集器中模拟滞流的条件下太阳能内存材料的吸收性评定(Evaluating Absorptive Solar Receiver Materials When Exposed to Conditions Simulating Stagnation in Solar Collectors with Cover Plates)
ASTM E 782-1995 在模拟操作模式下暴露于自然气候中的太阳能收集器覆盖材料的标准实施规程(Standard Practice for Exposure of Cover Materials for Solar Collectors to Natural Weathering Under Conditions Simulating Operational Mode)
ASTM E 822-1992 用发射冰球法测定太阳能收集器覆盖材料对冰雹冲击抗力的标准实施规程(Standard Practice for Determining Resistance of Solar Collector Covers to Hail by Impact With Propelled Ice Balls)
ASTM E 823-1981 太阳能收集器非操作暴露和检验(Nonoperational Exposure and Inspection of a Solar Collector)
ASTM E 861-1994 太阳能收集器用绝热材料评定的标准实施规程(Standard Practice for Evaluating Thermal Insulation Materials for Use in Solar Collectors)
ASTM E 881-1992 在模拟滞留模式下暴露于自然气候下的太阳能收集器挡盖材料的标准实施规程(Standard Practice for Exposure of Solar Collector Cover Materials to Natural Weathering Under Conditions Simulating Stagnation Mode)
ASTM E 904-1987 太阳能收集器用全天热性能数据的形成(Generating All-Day Thermal Performance Data for Solar Collectors)
ASTM E 905-1987 追踪强化太阳能收集器热性能的试验方法(Test Method for Determining Thermal Performance of Tracking Concentrating Solar Collectors)
ASTM E 971-1988 材料对太阳能辐射的光度透射比及反射比计算的标准实施规程(Standard Practice for Calculation of Photometric Transmittance and Reflectance of Materials to Solar Radiation)
ASTM E 972-1996 用阳光对薄板材料的太阳能光度透设比的测试方法(Standard Test Method for Solar Photometric Transmittance of Sheet Materials Using Sunlight)
仙豆
第3楼2010/02/22
BS 5918-1989 家用热水太阳能加热系统的实用规程(Code of practice for solar heating systems for domestic hot water)
BS 6785-1986 游泳池用太阳能加热装置实用规程(Code of practice for solar heating systems for swimming pools)
BS 6912-22.6-1996 土方机械安全.第22部分:操作者的密封环境.第6节:操作者用密封驾驶室太阳能加热效果的测定(Safety of earth-moving machinery - Operator enclosure environment - Determination of the effect of solar heating on the operator enclosure)
BS 7431-1991 太阳能热水器评定法.过滤器、连接管和配件用弹性材料(Method for assessing solar water heaters - Elastomeric materials for absorbers, connecting pipes and fittings)
BS DD ENV 12977-1-2001 太阳能系统和组件.客户建立系统.一般要求(Thermal solar systems and components - Custom built systems - General requirements)
BS DD ENV 12977-2-2001 太阳能系统和组件.客户建立系统.试验方法(Thermal solar systems and components - Custom built systems - Test methods)
BS DD ENV 12977-3-2001 太阳能系统和组件.客户建立系统.太阳能加热系统集热箱性能特征(Thermal solar systems and components - Custom built systems - Performance characterisation of stores for solar heating systems)
BS EN 12975-1-2000 热太阳能系统和组件.太阳能收集器.一般要求(Thermal solar systems and components - Solar collectors - General requirements)
BS EN 12975-2-2001 热太阳能系统和组件.太阳能收集器.试验方法(Thermal solar systems and components - Solar collectors - Test methods)
BS EN 12976-1-2001 太阳能热系统和组件.工厂制造系统.一般要求(Thermal solar systems and components - Factory made systems - General requirements)
BS EN 12976-2-2001 太阳能热系统和组件.工厂制造系统.试验方法(Thermal solar systems and components - Factory made systems - Test methods)
BS EN 60904-2-1993 光电器件.第2部分:基准太阳能电池的要求(Photovoltaic devices - Requirements for reference solar cells)
BS EN 60904-3-1993 光电器件.第3部分:带基准光谱辐照资料的地球光电太阳能器件的测量原理(Photovoltaic devices - Measurement principles for terrestrial photovoltaic (PV) solar devices with reference spectral irradiance data)
BS EN 60904-6-1995 光电器件.太阳能模式参数要求(Photovoltaic devices - Requirements for reference solar modules)
BS EN ISO 9488-2000 太阳能.词汇(Solar energy - Vocabulary)
BS ISO 14269-3-1998 农业和林业用拖拉机和自驱动机械.驾驶室环境.太阳能加热效果测定(Tractors and self-propelled machines for agriculture and forestry - Operator enclosure environment - Determination of effect of solar heating)
仙豆
第4楼2010/02/22
CNS13059-1 光电伏打组件(第一部:光电伏打电流─电压特性量测)[IEC 60904-1]
(Photovoltaic Devices Part 1:Measurement of Photovoltaic Current─Voltage Characteristics)
CNS13059-2 光电伏打组件(第二部:基准太阳电池之要求)[IEC 60904-2]
(Photovoltaic devices Part2:Requirements for reference solar cells)
CNS13059-3 光电伏打组件
(第三部:具光谱照射光参考数据之陆上光电伏打[PV]太阳组件量测原理)[IEC 60904-3]
(Photovoltaic Devices Part 3`75Measurement Principles for Terrestrial Photovoltaic`6rPV`6sSolar Devices With Reference Spectral Irradiance Data)
CNS13059-5 光电伏打组件(第五部:利用开路电压法决定光电伏打组件之等效电池温度)[IEC 60904-5]
Photovoltaic devices Part 5:Determination of the equivalent cell temperature (ECT) of photovoltaic (PV) devices by the opencircuit voltage method
CNS13059-6 光电伏打组件(第六部:基准太阳电池模块之要求)[IEC 60904-6]
Photovoltaic devices Par 6:Requirements for reference solar modules
CNS13059-7 光电伏打组件(第七部:光电伏打组件测试中所产生光谱不匹配误差之计算)[IEC 60904-7]
Photovoltaic devices Part 7:Computation of spectral mismatch error introduced in the testing of a photovoltaic device
CNS13059-8 光电伏打组件(第八部:光电伏打组件光谱响应之量测[IEC 60904-8]
Photovoltaic devices Part 8:Measurement of spectral response of aphotovoltaic (PV) device
CNS13059-9 光电伏打组件(第九部:太阳仿真器之性能要求)[IEC 60904-9]
Photovoltaic devices Part 9: Solar simulator performance requirements
CNS13059-10 光电伏打组件(第十部:线性量测法)[IEC 60904-10]
Photovoltaic devices Part 10:Methods of linearity measurement
CNS15011 太阳能-词汇(太阳热能)
Solar energy - Vocabulary (Solar thermal)
CNS15032 太阳能-比较参考日射强度计校正各种场日射强度计[ISO 9059]
Solar energy - Calibration of field pyrheliometers by comparison to a reference pyrheliometer
CNS15033 太阳能-量测半球太阳辐射与直接太阳辐射仪器之规格及分级[ISO9060]
Solar energy - Specification and classification of instruments for measuring hemispherical solar and direct solar radiation
CNS15065 太阳能-使用一个日射强度计校正全天空辐射计[ISO9846]
Solar energy - Calibration of a pyranometer using a pyrheliometer
CNS15066 太阳能-比较参考全天空辐射计校正场全天空辐射计[ISO9847]
Solar energy - Calibration of field pyranometers by comparison to a reference pyranometer
CNS15064-1 太阳能-在不同地球表面接收状况下之参考太阳光谱照射度-第1部:大气光程1﹒5下之直接垂直与半球太阳照射度[ISO9845-1]
Solar energy - Reference solar spectral irradiance at the ground at different receiving conditions - Part 1: Direct normal and hemispherical solar irradiance for air mass 1.5
CNS15113 太阳光电能源系统:名词与符号[IEC 61836]
Solar photovoltaic energy systems - Terms and symbols
CNS15114 结晶硅陆上太阳光电模块-设计确认和型式认可[IEC61215]
Crystalline silicon terrestrial photovoltaic (PV) modules - Design qualification and type approval
CNS15115 薄膜硅陆上太阳光电模块-设计确认和型式认可[IEC 61646]
Thin-film terrestrial photovoltaic (PV) modules - Design qualification and type approval
CNS15116 太阳光电模块紫外线测试[IEC 61345]
UV test for photovoltaic (PV) modules
CNS15117 太阳光电系统-电力调节器-量测效率之程序[IEC 61683]
Photovoltaic system - Power conditioner - Procedure for measuring efficiency
CNS15118-1 太阳光电模块之安全确认-第1部:构造要求[IEC 61730-1]
Photovoltaic (PV) module safety qualification - Part 1 : Requirements for construction
CNS15118-2 太阳光电模块之安全确认-第2部:测试要求[IEC 61730-1]
Photovoltaic (PV) module safety qualification - Part 2 : Requirements for testing
CNS15119 太阳光电系统之性能监测-量测、数据交换与分析指南[IEC 61724]
Photovoltaic system performance monitoring - Guidelines for measurement, data exchange and analysis
CNS15120 太阳光电发电系统用之二次电池-一般要求与测试方法[IEC 61427]
Secondary cells and batteries for solar photovoltaic energy systems - General requirements and methods of test
CNS15166 太阳能-场全天空辐射计-使用实务建议[ISO9901]
Solar Energy - Field Pyranometers - Recommended practice for use
CNS15195 陆上太阳光电发电系统-概述与指南[IEC 61277]
Terrestrial photovoltaic (PV) power generating systems - General and guide
CNS15196 太阳光电模块之盐雾腐蚀试验[IEC61701]
Salt mist corrosion testing of photovoltaic (PV) modules
CNS15197 太阳光电模块抗撞击损坏能力之测试(撞击抵抗力测试)[IEC61721]
Susceptibility of a photovoltaic (PV) module to accidental impact damage (Resistance to impact test)
CNS15198 结晶硅太阳光电数组之I-V特性现场量测[IEC61829]
Crystalline silicon photovoltaic (PV) array - On-site measurement of I-V characteristics
CNS15199 建筑物之电力安装-第7-712部:特别设立或地点之要求-太阳光电电力供应系统[IEC60364]
Electrical installations of buildings - Part 7-712: Requirements for special installations or locations - Solar photovoltaic (PV) power supply systems
仙豆
第5楼2010/02/22
EN 12975-1-2000 太阳能系统及构件太阳能收集器 第1部分一般要求(Thermal solar systems and components - Solar collectors - Part 1: General requirements)
EN 12975-2-2001 太阳能系统及构件 太阳能收集器第2部分试验方法(Thermal solar systems and components - Solar collectors - Part 2: Test methods )
EN 12976-1-2000 太阳能系统及构件 工厂预制系统 第1部分一般要求(Thermal solar systems and components - Factory made systems - Part 1: General requirements)
EN 12976-2-2000 太阳能系统及构件 工厂预制系统第2部分试验方法(Thermal solar systems and components - Factory made systems - Part 2: Test methods )
EN 60904-2-1993+A1-1998 光伏器件第2部分基准太阳能电池的要求(Photovoltaic devices; part 2: requirements for reference solar cells)[IEC 60904-2:1989]
EN ISO 9488-1999 太阳能词汇(Solar energy - Vocabulary)[ISO 9488:1999]
ENV 12977-1-2001 太阳能系统及构件 定制系统第1部分
一般要求(Thermal solar systems and components - Custom built systems - Part 1: General requirements)
ENV 12977-2-2001 太阳能系统及构件 定制系统第2部分试验方法(Thermal solar systems and components - Custom built systems - Part 2: Test methods)
ENV 12977-3-2001 太阳能系统及构件 定制系统第3部分太阳能供暖系统用内存性能(Thermal solar systems and components - Custom built systems - Part 3: Performance characterisation of stores
仙豆
第6楼2010/02/22
GB 11011-89 非晶硅太阳能电池性能测试的一般规定
GB 12632-90 单晶硅太阳能电池总规范
GB 2296-2001 太阳能电池型号命名方法
GB 2297-89 太阳能光伏能源系统术语
GB 50364-2005 民用建筑太阳能热水系统应用技术规范
GB 6495-86 地面用太阳能电池电性能测试方法
GB 6497-1986 地面用太阳能电池标定的一般规定
GB 9535-1998 陆地用太阳能电池组件环境试验方法(IEC61215)
GB/T 12936.1-1991 太阳能热利用术语第一部分(Solar energy—Thermal applications—Terminology part 1)
GB/T 12936.2-1991 太阳能热利用术语第二部分(Solar energy—Thermal applications—Terminology part 2)
GB/T 13877.3-2003 农林拖拉机和自走式机械封闭驾驶室第3部分: 太阳能加热系统效率的确定(Tractors and self-propelled machines for agriculture and forestry--Operator enclosure environment--Part 3: Determination of effect of solar heating)
GB/T 14007-92 陆地用太阳能电池组件总规范
GB/T 14008-92 海上用太阳能电池组件总规范
GB/T 14009-92 太阳能电池组件参数测量方法
GB/T 17683.1-1999 太阳能在地面不同接收条件下的太阳光谱辐照度标准第1部分
大气质量1.5的法向直接日射辐照度和半球向日射辐(Solar energy--Reference solar spectral irradiance at the ground at different receiving conditions--Part 1: Direct normal and hemispherical solar irradiance for air mass 1.5 )
GB/T 18210-2000 晶体硅光伏(PV)方阵I-V特性的现场测量
GB/T 18479-2001 地面用光伏(PV)发电系统 概述和导则
GB/T 19064-2003 家用太阳能光伏电源系统技术条件和试验方法(Solar home system specifications and test procedure)
GB/T 19813-2005 太阳能突起路标
GB/T 2680-1994 建筑玻璃可见光透射比、太阳光直接透射比、太阳能总透射比、紫外线透射比及有关窗玻璃参数的测定(Determination of light transmittance, solar direct transmittance, total solar energy transmittance and ultraviolet transmittance for glass in building and related glazing factors )
GB/T 5137.4-2001 汽车安全玻璃太阳能透射比测定方法(Road vehicles--safety glazing materials--Method for the determination of solar transmittance)
GB/T 6495.1-1996 光伏器件 第1部分
光伏电流-电压特性的测量;
GB/T 6495.2-1996 光伏器件 第2部分
标准太阳能电池的要求;
GB/T 6495.3-1996 光伏器件 第3部分
地面用光伏器件的测量原理及标准光谱辐照度数据;
GB/T 6495.4-1996 晶体硅光伏器件的I-V实测特性的温度和辐照度修正方法
仙豆
第7楼2010/02/22
IEC 60891 晶体硅光伏器件的I-V实测特性的温度和辐照度修正方法[GB/T 6495.4-1996]
IEC 60904-1 光伏电流-电压特性的测量(GB/T 6495.1-1996)
IEC 60904-10-1998 线性测量方法
IEC 60904-2-1989 光电器件.第2部分:基准太阳能电池的要求(Photovoltaic devices; part 2: requirements for reference solar cells)IEC60904-2标准太阳电池的要求[GB/T 6495.2-1996]
IEC 60904-2AMD 1-1998 光电器件.第2部分:标准太阳能电池的要求.修订件1(Photovoltaic devices - Part 2: Requirements for reference solar cells; Amendment 1)
IEC 60904-3-1989 地面用光伏器件的测量原理及标准光谱辐照度数据(Photovoltaic devices; part 3: measurement principles for terrestrial photovoltaic (PV) solar devices with reference spectral irradiance data)[GB/T 6495.3-1996]
IEC 60904-4 标准光伏器件校准程序
IEC 60904-5-1993 用开路电压法确定光伏(PV)器件的等效电池温度(ECT)
IEC 60904-6-1994 光电器件.第6部分:标准太阳能量参数要求(Photovoltaic devices - Part 6: Requirements for reference solar modules)
IEC 60904-6AMD 1-1998 光电器件.第6部分:标准太阳能量参数要求.第1次修订(Photovoltaic devices - Part 6: Requirements for reference solar modules; Amendment 1)
IEC 60904-7-1998 光伏器件测量过程中引起的光谱失配误差的计算
IEC 60904-8-1998 光伏器件光谱回应的测量
IEC 60904-9-1995 光电器件.第9部分:太阳能仿真器性能要求(Photovoltaic devices - Part 9: Solar simulator performance requirements)
IEC 61173-1992 光伏(PV)发电系统的过压保护导则
IEC 61194-1992 独立光伏系统的特性参数
IEC 61215-1993 地面用晶体硅光伏组件--设计鉴定和定型
IEC 61277-1995 地面用光伏(PV)发电系统--概述及导则
IEC 61345-1998 光伏组件的紫外试验
IEC 61646-1996 地面用薄膜型光伏组件设计鉴定和定型
IEC 61683-1999 光伏系统功率调节器效率测量步骤
IEC 61701-1995 光伏组件的盐雾腐蚀试验
IEC 61702-1995 直接耦合光伏扬水系统的评估
IEC 61721-1995 光伏组件对意外碰撞的承受能力
IEC 61724-1998 光伏系统性能监测测量、数据交换以及分析导则
IEC 61725-1997 日太阳辐射分析表达式
IEC 61727-1995 光伏系统电网接口的特性
IEC 61730-1 光伏系统安全鉴定-第一部分结构要求
IEC 61730-2 光伏系统安全鉴定-第二部分测试要求
IEC 61829-1995 晶体硅光伏方阵I-V特性的实地测量
IEC 61836-1997 太阳光伏能源术语和符号
IEC 61853 地面光伏组件性能测试和能量额定
IEC 62093 BOS部件-环境可靠性试验-设计鉴定和定型
IEC62108 聚光光伏接收器和组件-设计鉴定和定型
IEC 62109 用于光伏电源系统的静态逆变器和充电控制器的电安全
IEC 62111-1999 在偏远地区分散电气化中可重复使用的能源使用规范
IEC 62116 试验步骤-并网光伏发电系统功率调节器的隔离保护测量
IEC 62124 独立光伏系统-设计检验
IEC 62145 单晶硅地面组件-空白详细规范
IEC 62234 附设于建筑物与电网接驳光伏系统安全指引
IEC 62253 直接藕合光伏扬水系统-设计鉴定和定型申请
IEC 62257-1 偏远地区电气化的小型再生能源系统和混合系统的建议-偏远地区电气化概述
IEC 62257-2 偏远地区电气化的小型再生能源系统和混合系统的建议-对电气系统分布的要求
IEC 62257-3 远地区电气化的小型再生能源系统和混合系统的建议-发展计划和管理
IEEE 1262-1995 光伏组件的测试认证规范
IEEE1513 聚光型太阳能接收部分与模块的合格评定规章
