2451504
第8楼2013/06/22
报告限和定量限,我们可以将2者处理为一样。不同文件的定义不同而已。既等于或大于校准曲线上最低浓度点所对应的样品中的目标物含量。
Limit of Quantitation:
‘(The content) equal to or greater than the lowest concentration point on the calibration curve.’
[AOAC - PVMC]
It is also known as Limit of Reporting:
‘The lowest concentration of an analyte that can be determined with acceptable precision
(repeatability) and accuracy under the stated conditions of the test.’
[NATA Tech Note #13]
