ASTM C633 - 01(2008) Standard Test Method for Adhesion or Cohesion Strength of Thermal Spray Coatings http://www.astm.org/Standards/C633.htm 热喷涂层的粘附力或粘结强度的标准试验方法
ASTM E 1920-2003 Standard Guide for Metallographic Preparation of Thermal Sprayed Coatings 热喷涂层的金相制备标准指南
ASTM E 2109-2000 Test Methods for Determining Area Percentage Porosity in Thermal Sprayed Coatings 测定热喷涂层孔隙率的实验方法
iamfengyu(iamfengyu)发表:ASTM C633 - 01(2008) Standard Test Method for Adhesion or Cohesion Strength of Thermal Spray Coatings http://www.astm.org/Standards/C633.htm 热喷涂层的粘附力或粘结强度的标准试验方法
