poplar_yang
第1楼2010/12/03
1.重做曲线后是否需要重置监控样通道并重新测量,及彻底重新设置监控样,重置其0时间计数值。no, please do not reset your monitor, otherwise your curves will change too
2.如果在曲线使用过程中我想修改监控样的数量,而不想重做校准曲线,怎么办,如果增减监控样数量是否会使校准曲线丢失。this depend on your software, functionally cannot change, but the curve you can do correction in compound
markon_yan
第2楼2010/12/03
1.i think reset is necessary , if you make your test curves. and at the same time ,reset the monitor for the others applications which you have done .
2.you can do it well . the function of the PANAtical software supplies it.
3.if you want to do something ,i think you can try , it will be helpful ..but you had best to back your userdata packs before you do anything .
