Atkins Physical Chemistry 6ed 光盘版包含Atkins Physical Chemistry 6ed中全部的数据部分和绝大部分的图像资料,以及动画教学,是牛津大学出版的辅助资料,文字介绍不是Atkins Physical Chemistry 6ed的,取自Concepts in Physical Chemistry by Peter Atkins。30M四个部分解压缩后总共183M。下面是光盘中的介绍性文字。
This CDROM is based upon Physical Chemistry, sixth edition. It has been designed to present the key ideas from the text in a concise and easily accessible way to aid reference and revision.
The content structure is the same as the text, being divided into the same Parts, Chapters, Sections and Key Ideas or Topics (see Finding the Information You Want). The CDROM also contains most of the figures and the complete Data Section from Physical Chemistry, sixth edition, as well as additional Group Theory tables (see Using the Tables Screen).
Most of the text and equations are taken from Concepts in Physical Chemistry by Peter Atkins.
Additional features include:
· Animations based on figures from Physical Chemistry, sixth edition . · Downloadable Resources section for downloading copies of figures, animations and tables for your own use . Technical Support
For further technical support contact Oxford University Press:
