1. ISO 4098:2006 Leather -- Chemical tests -- Determination of water-soluble matter, water-soluble inorganic matter and water-soluble organic matter
2. ISO 5398-1:2007 Leather -- Chemical determination of chromic oxide content -- Part 1: Quantification by titration
3. ISO 5398-2:2009 Leather -- Chemical determination of chromic oxide content -- Part 2: Quantification by colorimetric determination
4. ISO 5398-3:2007 Leather -- Chemical determination of chromic oxide content -- Part 3: Quantification by atomic absorption spectrometry
5. ISO 5398-4:2007 Leather -- Chemical determination of chromic oxide content -- Part 4: Quantification by inductively coupled plasma - optical emission spectrometer (ICP-OES)
6. ISO 17233:2002 Leather -- Physical and mechanical tests -- Determination of cold crack temperature of surface coatings
7. ISO 17227:2002 Leather -- Physical and mechanical tests -- Determination of dry heat resistance of leather
8. ISO 3380:2002 Leather -- Physical and mechanical tests -- Determination of shrinkage temperature up to 100 degrees C
9. ISO 2419:2006 Leather -- Physical and mechanical tests -- Sample preparation and conditioning
10. ISO 2417:2002 Leather -- Physical and mechanical tests -- Determination of the static absorption of water
灰米奇2011/01/02
[size=2][font=Tahoma]ISO 4098:2006 Leather -- Chemical tests -- Determination of water-soluble matter, water-soluble inorganic matter and water-soluble organic matter[/font][/size]
