the temperature performance requirements necessitate the microwave decomposition system sense the temperature to within +/-2.5℃ and automatically adjust the microwave field output power within 2 seconds of sensing. EPA3052中对微波性能的要求,看了不大明白,是不是Sense少了S?温度性能要求需要微波消解系统感应+/-2.5℃内的温度变化,并在感应后2秒内自动调节输出功率
