zouhua1210
第6楼2011/07/09
Certified Reference Materials (CRMs) for both chemical and spectroscopic analysis are prepared and issued by the BUREAU OF ANALYSED SAMPLES LTD (BAS) . The company was formed in 1935 to ensure the continuation of the work of the British Chemical Standards (BCS) Movement which was started in 1916 as an informal association of chemists in the iron and steel industry .
http://www.basrid.co.uk/bas.htm
依据此文章,应该翻译为样品标准有限公司
ja19840616
第7楼2011/07/11
支持这个 网上找下后面应该还有个LTD的 应该是 分析标样制备公司 之类的
