尼康50i正置荧光显微镜配置清单 | ||
编号 | 描述 | 数量 |
MBA85020 | [50i 主体] 50i Main Body (100-240V) | 1 |
MXA20233 | [浸油] Immersion Oil A, 8cc | 1 |
MBF11300 | [电源线] Power Cord BE (220-240V) | 1 |
MBC71700 | [带两片样品夹的机械载物台] C-SR2 Rect. Mech. Stage w/Right Handle R2 W/ 2-Slides Specimen Holder W/ 1-Slide Specimen Holder | 1 |
MBB73106 | [三目头] Y-TFM2 Trinocular Tube "F2"AM | 1 |
MAK10105 | [10X目镜 带屈光度调节] CFI Eyepiece 10X AM | 2 |
MBP71300 | [六孔转换器] C-N Sextuple Nosepiece | 1 |
MBE84000 | [落射荧光附件] J-FL Epi-Fl Attachment | 1 |
MBE75010 | [集光镜] C-FC Epi-FL Collector Lens | 1 |
MBE75060 | [对中镜] C-FC Epi-FL Centering Tool | 1 |
MBE25301 | [灯室] Lamphouse HMX-3B | 1 |
MBF33342 | [汞灯座] Mercury Lamp Socket S 100W for HMX-3B | 1 |
MBF14342 | [汞灯] C-LHG1 Mercury Lamp HG-100W | 1 |
MBF12321 | [汞灯激发器] C-SHG1 Power Supply for Mercury Lamp HG-100W | 1 |
MBF11300 | [电源线] Power Cord BE | 1 |
MBE44500 | [蓝色激发滤光块] C-FL Epi-Fl Filter Cube N B-2A | 1 |
MBE45500 | [绿色激发滤光块] C-FL Epi-Fl Filter Cube N G-2A | 1 |
MBE41200 | [紫外激发滤光块] C-FL Epi-Fl Filter Cube N UV-2A | 1 |
MBL11300 | [旋出式消色差聚光器] Swing-out Condenser | 1 |
MRP00042 | [4X 平场消色差物镜] CFI Achromat 4X N.A. 0.10, W.D. 30.0 mm | 1 |
MRP00102 | [10X 平场消色差物镜] CFI Achromat Flat field 10X | 1 |
MRP00202 | [20X 平场消色差物镜] CFI Achromat Flat field LWD 20X | 1 |
MRP00402 | [40X 平场消色差物镜] CFI Achromat Flat field 40X | 1 |
MRP01902 | [100X 平场消色差物镜 油浸] CFI Achromat Flat field 100X oil | 1 |
MXA29010 | [D-SLR 系列F接口] D-SLR series F mount adapter | 1 |
MXA29011 | [D-SLR 系列F-TV管] D-SLR series F-TV Tube | 1 |
优惠美金价: | 10,356 | |
**** | 以上价格不含拍照用单反相机,但相机接口已配 |
Units | Description | Qty | |||||||||||
| 显微镜 | | |
| BX41 | Laboratory Microscope(研究级生物显微镜) | 1 | ||||||||||
显微镜镜体 | | |
BX41TF | Microscope frame for transmitted microscopy, including hexagonal driver AB8804, immersion oil 8cc and shield sticker AD4908(2pcs)Corresponded to RoHS, WEEE regulation | 1 | |||||||||||
三目镜筒 | | |
U-TR30-2 | Trinocular tube | 1 | |||||||||||
五孔物镜转盘 | | |
U-5RE-2 | Quintuple Revolving Nosepiece | 1 | |||||||||||
机械式载物台 | | |
U-SVRB-4 | Ceramic surface mechanical stage with right-hand low drivecontrol(long type) | 1 | |||||||||||
夹片器 | | |
U-HLDT-4 | Specimen holder for BX stage, left hand, for two specimens, thick type | 1 | |||||||||||
摆动式聚光镜 | | |
U-SC3 | Swing-out condenser N.A. 0.9-0.16 | 1 | |||||||||||
卤素灯灯室 | | |
U-LS30 | Lamp socket | 1 | |||||||||||
卤素灯灯泡 | | |
6V30WHAL | 30W Halogen bulb(Philips No. 5761) | 2 | |||||||||||
电源线 | | |
UYCP | Power cord | 1 | |||||||||||
防尘罩 | | |
COVER-018 | Dust cover Type 018 for BX2(L 510mm x W 320mm x H 530 mm) | 1 | |||||||||||
平场消色差物镜 | | |
PLN4X | Plan achromat objective 4X/0.1, WD 18.5 | 1 | |||||||||||
PLN10X | Plan achromat objective 10X/0.25, WD 10.6 | 1 | |||||||||||
PLN40X | Plan achromat objective 40X/0.65, WD 0.6(spring) | 1 | |||||||||||
PLN100XO | Plan achromat objective 100X/1.25, WD 0.15(spring, oil) | 1 | |||||||||||
目镜 | | |
WHN10X | Widefield eyepiece 10X | 2 | |||||||||||
滤色片 | | |
| 45-LBD-IF | Interference light balance daylight filter, 45mm dia. | 1 | ||||||||||
摄像头 | |||||||||||||
2、 | 数码图象采集系统 | 国产,1000万像素,含图象分析软件 |
数码摄像头 | |||||||||||||
TCA-10.0-N | Digital camera for microscope with 10M pixel CCD. | 1 | |||||||||||
视频接口 | | |
U-TV1X-2 | Direct image video port | 1 | |||||||||||
C型接口 | | |
| U-CMAD3 | C mount adapter | 1 | ||||||||||
价格合计: | ¥67,800.00 |
