洪星二锅头
第3楼2011/11/21
PDF#50-1518: QM=Star(+); d=Diffractometer; I=Diffractometer
Gallium Manganese Nickel
Ga Mn Ni2
Radiation=CuKa1 Lambda=1.5406 Filter=Graph
Calibration=Internal(Si) d-Cutoff=8.8 I/Ic(RIR)=
Ref= Kimmel, G., Ezer, Y., Sozinov, A., Ullakko, K., Nehama, E., Ben-Gurion Univ. of the Negev, Beer Sheva, Israel.
ICDD Grant-in-Aid (1999)
Cubic - (Unknown), Fm-3m (225) Z=4 mp=
Cell=5.821 Pearson=cF16 (Bi F3)
Density(c)=8.152 Density(m)=8.20A Mwt=242.06 Vol=197.24 F(8)=999.9(.0004,17)
Ref= Ibid.
d(A) I(f) I(v) h k l n^2 2-Theta Theta 1/(2d) 2pi/d
3.360 1.0 1.0 1 1 1 3 26.499 13.250 0.1488 1.8695
2.058 100.0 100.0 0 2 2 8 43.960 21.980 0.2430 3.0530
1.755 1.0 1.0 1 1 3 11 52.065 26.032 0.2849 3.5799
1.455 11.0 16.0 0 0 4 16 63.917 31.959 0.3436 4.3176
1.188 25.0 43.0 2 2 4 24 80.822 40.411 0.4208 5.2879
1.029 6.0 12.0 0 4 4 32 96.931 48.466 0.4859 6.1060
0.920 8.0 18.0 0 2 6 40 113.630 56.815 0.5433 6.8267
0.840 5.0 12.0 4 4 4 48 132.922 66.461 0.5951 7.4783
洪星二锅头
第4楼2011/11/21
PDF#65-0618: QM=Calculated; d=Calculated; I=Calculated
Ga Mn Ni2
Radiation=CuKa1 Lambda=1.54060 Filter=
Calibration= d-Cutoff= I/Ic(RIR)=11.10
Ref= Calculated from NIST using POWD-12++
Cell=5.823 Pearson=cF16 (Bi F3)
Density(c)=8.142 Density(m)=8.20A Mwt=242.06 Vol=197.44 F(19)=999.9(.0004,19)
Ref= K.Ooiwa, K.Endo & A.Shinogi
J. Magn. Magn. Mater., 104 2011- (1992)
Strong Line: 2.06/X 1.19/2 1.46/1 0.92/1 1.03/1 0.84/1 3.36/1 1.76/1 2.91/1 1.34/1
NOTE: N 60665 35730 No TF given for entry, B=1.0 assumed
3.361 1.3 0.8 1 1 1 3 26.491 13.245 0.1487 1.8689
2.911 0.4 0.3 2 0 0 4 30.682 15.341 0.1717 2.1581
2.058 100.0 100.0 2 2 0 8 43.944 21.972 0.2429 3.0520
1.755 0.6 0.7 3 1 1 11 52.046 26.023 0.2848 3.5787
1.681 0.1 0.1 2 2 2 12 54.547 27.273 0.2974 3.7379
1.455 11.6 16.4 4 0 0 16 63.893 31.947 0.3435 4.3161
1.335 0.2 0.3 3 3 1 19 70.424 35.212 0.3743 4.7034
1.302 0.2 0.3 4 2 0 20 72.539 36.270 0.3840 4.8256
1.188 17.6 30.5 4 2 2 24 80.790 40.395 0.4207 5.2862
1.120 0.1 0.2 5 1 1 27 86.843 43.421 0.4462 5.6068
1.029 4.4 8.8 4 4 0 32 96.887 48.444 0.4857 6.1039
0.984 0.1 0.2 5 3 1 35 102.997 51.499 0.5080 6.3836
0.970 0.1 0.2 4 4 2 36 105.064 52.532 0.5152 6.4742
0.920 5.7 12.7 6 2 0 40 113.571 56.786 0.5431 6.8244
0.888 0.1 0.2 5 3 3 43 120.323 60.162 0.5631 7.0757
0.877 0.1 0.2 6 2 2 44 122.675 61.338 0.5696 7.1575
0.840 1.5 3.7 4 4 4 48 132.833 66.417 0.5949 7.4757
0.815 0.1 0.3 7 1 1 51 141.708 70.854 0.6132 7.7058
0.807 0.1 0.3 6 4 0 52 145.070 72.535 0.6192 7.7810
洪星二锅头
第5楼2011/11/21
PDF#65-5328: QM=Calculated; d=Calculated; I=Calculated
Ga Mn Ni2
Calibration= d-Cutoff= I/Ic(RIR)=11.08
Cell=5.805 Pearson=cF16 (Bi F3)
Density(c)=8.218 Density(m)=8.20A Mwt=242.06 Vol=195.62 F(19)=999.9(.0002,19)
Ref= Kanomata, T., Shirakawa, K., Kaneko, T.
J. Magn. Magn. Mater., 65 76 (1987)
Strong Line: 2.05/X 1.19/2 1.45/1 0.92/1 1.03/1 0.84/1 3.35/1 1.75/1 2.90/1 1.33/1
NOTE: L 30480 14355 0 TF was not given, B set to 1.000 for calc.
The samples were sealed in evacuated tubes and melted ,then annealed and quenched.The reaction products were pulverized,mixed, heated again in vacuum and then quenched.
EFFECT OF HYDROSTATIC PRESSURE ON THE CURIE TEMPERATURE OF THE HEUSLER ALLOYS Ni2MnZ(Z=Al,Ga,In,Sn AND Sb)
3.351 1.3 0.8 1 1 1 3 26.574 13.287 0.1492 1.8747
2.902 0.4 0.3 2 0 0 4 30.780 15.390 0.1723 2.1647
2.052 100.0 100.0 2 2 0 8 44.087 22.044 0.2436 3.0614
1.750 0.6 0.7 3 1 1 11 52.220 26.110 0.2857 3.5898
1.675 0.1 0.1 2 2 2 12 54.730 27.365 0.2984 3.7495
1.451 11.5 16.3 4 0 0 16 64.115 32.057 0.3445 4.3295
1.331 0.2 0.3 3 3 1 19 70.675 35.338 0.3754 4.7180
1.298 0.2 0.3 4 2 0 20 72.800 36.400 0.3852 4.8405
1.184 17.2 29.8 4 2 2 24 81.092 40.546 0.4220 5.3025
1.117 0.1 0.2 5 1 1 27 87.180 43.590 0.4476 5.6242
1.026 4.3 8.6 4 4 0 32 97.288 48.644 0.4872 6.1228
0.981 0.1 0.2 5 3 1 35 103.445 51.722 0.5096 6.4034
0.967 0.1 0.2 6 0 0 36 105.529 52.764 0.5168 6.4942
0.917 5.7 12.7 6 2 0 40 114.116 57.058 0.5448 6.8455
0.885 0.1 0.2 5 3 3 43 120.946 60.473 0.5648 7.0976
0.875 0.1 0.2 6 2 2 44 123.329 61.664 0.5713 7.1797
0.837 1.5 3.7 4 4 4 48 133.654 66.827 0.5967 7.4989
0.812 0.1 0.3 7 1 1 51 142.744 71.372 0.6151 7.7297
0.805 0.1 0.3 6 4 0 52 146.218 73.109 0.6211 7.8051
