04600-ZF Coated Capillary, Zero Flow, 100um ID by 100cm. $103.00 Order 04650-HF CE-100SA, Sulfonic Acid Coated Capillary, High Flow, 50um ID by 100cm $103.00 Order 04650-LF CE-100SA, Sulfonic Acid Coated Capillary, Low Flow, 50um ID by 100cm $103.00 Order 04650-MF CE100-SA Sulfonic Acid Coated Capillary, Medium Flow, 50um ID by 100cm. $103.00 Order 04650-ZF CE-100SA, Coated Capillary, Zero Flow, 50um ID by 100cm. $103.00 Order 04675-HF CE-100SA, Sulfonic Acid Coated Capillary, High Flow, 75um by 100cm. $103.00 Order 04675-LF CE-100SA, Sulfonic Acid Coated Capillary, Low Flow, 75um ID by 100cm $103.00 Order 04675-MF CE-100SA, Sulfonic Acid Coated Capillary, Medium Flow, 75um ID by 100cm. $103.00 Order 04675-ZF CE-100SA, Sulfonic Acid Coated Capillary, 75um ID 100CM, Zero Flow $103.00 Order 04025-C Capillary, Fused Silica, Untreated, 25um ID by 1M. $28.00 Order 04026-C Capillary, Fused Silica, Untreated, 25um ID by 10 Meters. $155.00 Order 04026-C25 Capillary, Fused Silica, Untreated, 25um ID by 25 Meters. $196.00 Order 04050-C Capillary, Fused Silica, Untreated, 50um ID by 1M $29.00 Order 04051-C Capillary, Fused Silica, Untreated, 50um ID by 10 Meters. $155.00 Order 04051-C25 Capillary, Fused Silica, Untreated, 50um ID by 25 Meters. $196.00 Order 04071-C Capillary, Fused Silica, Untreated, 75um ID by 10 Meters. $155.00 Order 04071-C25 Capillary, Fused Silica, Untreated, 75um ID by 25 Meters. $196.00 Order 04075-C Capillary, Fused Silica, Untreated, 75um ID by 1M. $28.00 Order 04150-C Capillary, Fused Silica, Untreated, 150um ID by 1M. $28.00 Order 04151-C Capillary, Fused Silica, Untreated, 150um ID by 10M. $155.00 Order 04151-C25 Capillary, Fused Silica, Untreated, 150um ID by 25M. $196.00 Order 04500-33 Pre-Made Bare Silica CE Capillary, 150um by 33cm cut with 2mm window. Pack of 3 Capillaries. $211.00 Order 04500-48 Pre-Made Bare Silica CE Capillary, 150um by 48.5cm cut with 2mm window. Pack of 3 Capillaries. $229.00 Order 04500-80 Pre-Made Bare Silica CE Capillary, 150um by 80.5cm cut with 2mm window. Pack of 3 Capillaries. $266.00 Order 04550-33 Pre-Made Bare Silica CE Capillary, 50um by 33cm cut with 2mm window. Pack of 3 Capillaries. $211.00 Order 04550-45 Pre-Made Bare Silica CE Capillary, 50um by 45cm cut with 2mm window. Pack of 3 Capillaries. $224.00 Order 04550-48 Pre-Made Bare Silica CE Capillary, 50um by 48.5cm cut with 2mm window. Pack of 3 Capillaries. $229.00 Order 04550-64 Pre-Made Bare Silica CE Capillary, 50um by 64.5cm cut with 2mm window. Pack of 3 Capillaries. $248.00 Order 04550-80 Pre-Made Bare Silica CE Capillary, 50um by 80.5cm cut with 2mm window. Pack of 3 Capillaries. $266.00 Order 04575-45 Pre-Made Bare Silica CE Capillary, 75um by 45cm cut with 2mm window. Pack of 3 Capillaries. $224.00 Order 04575-48 Pre-Made Bare Silica CE Capillary, 75um by 48.5cm cut with 2mm window. Pack of 3 Capillaries. $229.00 Order 04575-64 Pre-Made Bare Silica CE Capillary, 75um by 64.5cm cut with 2mm window. Pack of 3 Capillaries. $248.00 Order
