reagentlife
第1楼2012/01/10
1.关于元素标液的选择:AAS标液还是ICP-MS标液?
AAS、HGAAS、AFS推荐使用AAS标液,价格便宜,ICP-OES/AES、ICP-MS推荐使用ICP-MS标液,同时ICP-MS标液 > AAS标液,ICP-MS标液可以替代AAS标液,但AAS标液不建议用在ICP分析上。为什么要这样选择?AAS标液与ICP-MS标液有什么区别?
1.AAS与ICP分析仪器之间的区别?
a.检测原理不同
AAS 不同元素会吸收不同波长的光
ICP 不同元素会发射不同波长的光
b.单次检测元素数量不同
AAS 1
ICP 70
c.仪器检测灵敏度不同
AAS 50-5000ppb
HGAAS 0.1-50ppb
ICP-AES/ICP-OES 1-100ppb
ICP-MS 0.001-5ppb
2.AAS标液与ICP-MS标液之间的区别?
a.用于配置标液的起始物质starting material选择不同:
AAS通常选择产品纯度在99.0%以上的优级纯的无机盐或者金属氧化物,剩余1%的杂质会带入其他元素杂质;
ICP-MS则选择纯度在99.99%甚至更高的无机盐或者金属氧化物;
b.基质matrix的选择不同
AAS标液通常选择ppm级别的优级纯酸,部分厂商也会选择用高级别的重蒸酸;
ICP-MS标液通常选择ppt级别的超纯酸;
结论:AAS元素分析灵敏度较ICP差,ICP受背景元素杂质干扰,所以ICP-MS应选择ICP-MS标液,在样品前处理用酸以及元素稀释上,ICP-AES/OES应选择ppb级别的超纯酸,ICP-MS应选择ppt级别的酸。
下面是国外专业元素标液生产商的回复,大家可以分享一下:
1°The difference between AAS standards and ICP-OES/MS standards is the starting material. AAS standards are typically made from ACS grade salts. This means the purity of the material is about 99%. The other 1% of the material can be trace amounts of other metals. The ICP-OES/MS standards are made from high purity metals salts or oxides typically 99.99% or better. This limits the amount of trace metals in a standard. AA does not have enough sensitivity to detect the impurities, ICP-OES/MS do. If your customer was to buy some AA single element standards and combine them to make a mix, they may issues if they use an ICP-OES/MS instrument.
2°There are different grade acids used for different techniques. AAS standard only need ACS grade acids. While some ICP-OES can use ACS Grade Acids the detection limits for ICP-OES instruments has improved greatly over the past 20 years. Because of this improvement I recommend that a company using ICP-OES should use the Trace metal grade acids and the ICP standards. For ICP-MS work only use the highest purity acids and standards available.
reagentlife
第5楼2012/01/10
5.实验室器皿如何清洗?
a.如果想要很干净的话,最好用酸煮;
在聚四氟乙烯的消解瓶,每次用之前大约移取5毫升的浓硝酸,然后放在150度的电热板上酸煮30min,加热后,酸就挥发了,从而带走瓶子上面的残留杂质;(备注:其他材质不耐受高温酸煮,如PP、PE等)
b.在10%浓度左右的硝酸(也有的选择20%的酸)浸泡过夜,不用的时候可以一直浸泡在稀酸中,适合各种材质实验室器皿;
当样品量较大时,大部分用户会选择用酸浸泡。
对于酸的种类的选择上,大部分情况下选择HNO3,如果分析N元素就不能选择HNO3了。
上述方法是我在与几个客户沟通下来后总结出来的,对于其他的清洗方法大家可以发上来讨论一下。
reagentlife
第8楼2012/01/13
我在原子吸收板块也有讨论,大家可以讨论一下,谢谢czcht的分享。
http://bbs.instrument.com.cn/shtml/20120110/3793972/
砂锅粥
第9楼2012/01/13
]我们买的是钢铁研究院的。
酸基本上能满足我们的要求。
