三菱仪器
第7楼2023/02/07
可参考离子燃烧色谱法AQF-2100H 测试水泥中的氯离子含量
Determination of fluorine, chlorine and sulfur in RDF (Refuse Derived Fuel)
AQF-2100H Sample size: 15 to 20mg
Sample boat: Quartz sample boat, TX2SBT
Additive: None
Pyrolysis tube: Quartz tube filled with quartz wool
Absorbent: 90ppm Hydrogen peroxide / water
Mode: Constant volume mode
HF-210 Heater Temp. Inlet: 900degC
Outlet: 1000degC
Gas flow Ar: 200 ml/min
O2: 400 ml/min
GA-210 Absorbent volume: 10 ml
Sampling loop: 100 ul
Absorption tube: For 10 ml
Water supply: 2
Ar flow for water supply: 100 ml/min
