农残检测
雾非雾
第1楼2012/05/22
用英文没有搜索到美国的标准检测方法。
出来混迟早要还的
第2楼2012/05/26
CHLORFLUAZURON is not registered in US, so the default MRL is 0.01 ppm. Any method you could come up with should serve the purpose as long as the method is well validated at 0.01 ppm.
