美国药典:
For determination of trace amounts of water (less than 1%), it is preferable to use Reagent with a water equivalency factor of not more than 2.0. Sodium tartrate may be used as a convenient water reference substance. Quickly add 75 to 125 mg of sodium tartrate (C4H4Na2O6·2H2O), accurately weighed by difference, and titrate to the endpoint. The water equivalence factor F, in mg of water per mL of reagent, is given by the formula:
2(18.02/230.08)(W/V)
in which 18.02 and 230.08 are the molecular weights of water and sodium tartrate dihydrate, respectively; W is the weight, in mg, of sodium tartrate dihydrate; and V is the volume, in mL, of the Reagent consumed in the second titration.
For the precise determination of significant amounts of water (1% or more), use Purified Water as the reference substance. Quickly add between 25 and 250 mg of water, accurately weighed by difference, from a weighing pipet or from a precalibrated syringe or micropipet, the amount taken being governed by the reagent strength and the buret size, as referred to under
Volumetric Apparatus
31![](mk:@MSITStore:E:\药典\USP\usp32_nf27_2009_roydan.chm::/pub/data/images/chars/rang.gif)
. Titrate to the endpoint. Calculate the water equivalence factor, F, in mg of water per mL of reagent, by the formula:
W/V
in which W is the weight, in mg, of the water; and V is the volume, in mL, of the reagent required.
中心意思是:
对于样品中要求水含量小于1%的,取75~125mg的酒石酸钠(C4H4Na2O6·2H2O)进行标定;
对于样品中要求水含量大于等于1%的,取25~250mg的水进行标定
xkcpu(xkcpu) 发表:加水的质量是多少呢,有什么依据没?
