【Abstract】 Objective:To develop a RP-HPLC method for determination of Schizandrin in"Longlingchun Heji ".Methods:A DiamonsilTM C18 column was used,the mobile phase consisted of methanol,acetonitrile and water(35:35:60,v:v:v),the flow rate was 1.0 mL/min,the column temperature was controlledat 35℃and the UV detector was operated at 250 nm.Schizandrin in the "Longlingchun Heji"was determined by using external standard method.Result:The range of calibration curve for Schizandrin in the e... 更多还原 【关键词】 龙苓春合剂; 五味子醇甲; HPLC; 【Key words】 Longlingchun Heji; Schizandrin; HPLC;
